    Duet maestro and weirdness on start gcode
    1.6k
    • Agniusmundefined
      Agniusm @Veti
      @veti here is the beginning of the gcode:
      ; external perimeters extrusion width = 0.42mm
      ; perimeters extrusion width = 0.42mm
      ; infill extrusion width = 0.50mm
      ; solid infill extrusion width = 0.42mm
      ; top infill extrusion width = 0.42mm
      ; first layer extrusion width = 0.42mm
      M107
      G28 W ; home all without mesh bed level
      G0 Z70 F500 ; get head above bed to keep it cool
      M106 P1 S255 ; Turn on fan
      M140 S75 ; set bed temp
      M104 S180
      M190 S75 ; wait for bed temp
      M104 S180
      G28 W ; home all without mesh bed leveing
      G29 S0 ; mesh bed leveling
      M106 S0 ; Turn off fan
      M104 S235 ; set extruder temp
      M109 S235 ; wait for extruder temp
      G1 Y0.0 F5000 ; go outside print area
      G92 E0 ; reset extrusion distance
      G1 X70.0 E9 F1000 ; intro line
      G1 X140 E12.5 F1000 ; intro line
      M572 D0 S0.07 ; Pressure advance
      ; Filament gcode
      G21 ; set units to millimeters
      G90 ; use absolute coordinates
      M83 ; use relative distances for extrusion
      G1 E-1.00000 F2100.00000
      G1 Z0.250 F9000.000
      ; PURGING FINISHED
      G1 X130.316 Y151.203
      G1 E1.00000 F2100.00000
      M204 S1000
      G1 F900
      G1 X183.884 Y151.203 E1.95815
      G1 X183.884 Y164.498 E0.48600
      G1 X130.316 Y164.498 E1.95816
      G1 X130.316 Y151.263 E0.48380
      G1 X130.682 Y151.569 F9000.000
      G1 F900
      G1 X183.518 Y151.569 E1.93137
      G1 X183.518 Y164.131 E0.45921
      G1 X130.682 Y164.131 E1.93137
      G1 X130.682 Y151.629 E0.45702
      G1 X131.049 Y151.935 F9000.000
      It does not contain full G1 Y0 X2 Z0.5 F7000 ; go outside print area command with set x coordinate but since i added it, has same outcome.
      dc42undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @Agniusm
        @agniusm said in Duet maestro and weirdness on start gcode:
        Why the W parameter?
        Agniusmundefined 1 Reply Last reply Reply Quote 0
        • Agniusmundefined
          Agniusm @dc42
          @dc42 It was from prusa start script but its not there now. No change still. Probably had no effect anyway.
            Phaedrux Moderator @Agniusm
            I say again, it looks like you're missing G90 and G91 commands here. G1 Y0 makes no sense in the context of a relative move. But the next movements are to extrude a prime like, which would require a relative move.
              What firmware versions are your Duet WiFi and Duet maestro running?
              Are there any error messages on the GCode Console when this happens?
              • Agniusmundefined
                Agniusm
                Maestro on 2.02RC5. My duet wifi(eth now) runs 2.03 but it have never done that but start script is almost the same.
                I have not noticed any errors in the gcode console but i will keep an eye.
                It finishes mesh bed compensation, and then sort of glitches 1mm or so and stays at that last spot
                • Agniusmundefined
                  Agniusm
                  here is the video:
                  https://youtu.be/Eaedp-ZMEvg
                  I have updated to 2.03 and still same.
                  • Vetiundefined
                    Veti
                    you never answered Phaedrux post about switching to absolute positioning for those moves.
                    • Agniusmundefined
                      Agniusm @Veti
                      @veti I dont know why would it be different as my duet wifi works ok with the same script.
                      P.S. OK. I have figured it out.
                      I have placed my move to the fron of the bed before these:
                      M104 S[first_layer_temperature] ; set extruder temp
                      M109 S[first_layer_temperature] ; wait for extruder temp
                      and now it works
                      • Agniusmundefined
                        Agniusm
                        Case closed;
                        • Agniusmundefined
                          Agniusm
                          Re-opened. Looks like it does it random. I don't know what is happening. Whenever i sliced with the new start script it went and did how it suppose to. Now prints finished and i started same file again and it again remained at the back of the bed and purged mid air.
                          • Vetiundefined
                            Veti
                            as Phaedrux has said multible times in this thread, you need to make sure that when the code is executed it needs to be in absolute positioning . so add the correct G90 and G91 commands to your code.
                            • Agniusmundefined
                              Agniusm @Veti
                              @veti do i need to add it just for that move or the whole start script?
                              • Vetiundefined
                                Veti
                                try with a G90 at the beginning
                                  deckingman @Agniusm
                                  @agniusm By way of explanation, a relative move such as G1 X10, Y10 will move the print head by 10mm positive in both the X and Y directions. Whereas in absolute mode, that same G1 X10 Y10 will move the print head to the position which is 10mm in both X and Y from the homed position (usually 0,0).
                                  So for example if the print head started at X50 , Y60 then relative G1 X10 Y10 will move the print head another 10mm in each direction and it will end up at X60 Y70. But in absolute mode starting with the print head in that same position of X50 Y60 that same G1 X10 Y10 command will move the print to X10 Y10 so it will move minus 40mm in X and minus 50mm in Y.
                                  In actual fact, all moves have to be relative to some point in space. So absolute moves mean go to an XY position relative to the homed position. Therefore it follows that if the homed position hasn't been established, then any absolute moves aren't going to work properly.
                                  In summary, use relative to move by an amount, use absolute to move to a position (relative to the homed position).
                                  Agniusmundefined 1 Reply Last reply Reply Quote 2
                                    Phaedrux Moderator @Phaedrux
                                    @phaedrux said in Duet maestro and weirdness on start gcode:
                                    So the snippet above would become
                                    G90 ; absolute positioning
                                    G1 Y0 X0 F5000 ; go outside print area
                                    G91 ; relative positioning
                                    • Agniusmundefined
                                      Agniusm @deckingman
                                      @deckingman Thanks. Yes, i am familiar with what those command do and how they work.
                                      Adding G90 at the begining of the move and G91 after seems to have solved the problem, at least on couple prints i did so far.
                                      Thanks
