    rfm - RepRapFirmware FileManager [duetbackup successor]
    83
    10.3k
    • wilrikerundefined
      wilriker @Jacotheron
      @jacotheron I found something that might be the reason for the error message you are seeing. I uploaded a possible fix to my Dropbox. Can you please test if this issue still occurs in that version?
      Manuel
      My Tool Collection
      • Jacotheronundefined
        Jacotheron
        I have just tested the new version, and it worked - no issues found. The devices file was made and saved.
        • wilrikerundefined
          @jacotheron Thanks for confirming. I will do an official bug fix release tomorrow.
          Manuel
          My Tool Collection
          • wilrikerundefined
            wilriker
            Release v1.0.1
            Bug fix release to fix the issue where on Windows rfm.toml would not be overwritten. Get it at GitHub Releases page.
            Manuel
            My Tool Collection
            • gtj0undefined
              gtj0
              Hey Manuel, rfm has been working great for me but is there any chance you could automatically exclude the "System Volume Information" directory or maybe save excludes in the rfm.toml file?
              wilrikerundefined 2 Replies Last reply Reply Quote 0
              • wilrikerundefined
                wilriker @gtj0
                @gtj0 I'll think about something.
                Meanwhile you can also use rfm to just delete this stupid folder. It doesn't serve any purpose in the first place. I don't think that removable media are supposed to even have this folder.
                Manuel
                My Tool Collection
                • wilrikerundefined
                  wilriker @gtj0
                  @gtj0 Here you go
                  Release v1.1.0-RC1
                  Get it at the GitHub Releases page.
                  This release implements the persisting of -exclude parameter values in rfm.toml. These parameters will be persisted separately for backup and upload command so they do not confuse each other.
                  A new keyword reset has been added as a recognized value for the -exclude parameter to delete all persisted excludes for the current command, i.e.
                  rfm backup -exclude reset ...
                  will remove all persisted excludes for the backup command. Further -exclude parameter after that (even in the same command) will add new excludes.
                  Note that order is relevant, i.e.
                  rfm backup -exclude 0:/gcodes -exclude reset backup-dir 0:/
                  will backup everything in 0:/ since the given exclude for 0:/gcodes was reset by the following -exclude reset parameter.
                  Manuel
                  My Tool Collection
                  • gtj0undefined
                    gtj0
                    Is -removeLocal working?
                    ./rfm backup -domain duet0 -removeLocal /tmp/duet0 /
                    Removing no longer existing files in /tmp/duet0/gcodes
                    But it doesn't actually remove any files from the local filesystem.
                    • wilrikerundefined
                      wilriker @gtj0
                      @gtj0 Last time I checked it worked. It will only remove local files that do not exist anymore on remote (like -delete for rsync). I will check tomorrow if something is broken with it.
                      Manuel
                      My Tool Collection
                      • wilrikerundefined
                        wilriker @gtj0
                        @gtj0 You were right, -removeLocal was broken for removed files (it worked for removed directories). So here is
                        Release v1.1.0-RC2
                        This fixes broken -removeLocal parameter of the backup sub-command that did not delete files locally.
                        Manuel
                        My Tool Collection
                        gtj0undefined 1 Reply Last reply Reply Quote 2
                        • 3mmundefined
                          3mm
                          Hi wilriker,
                          I hate to sound stupid, but how do I use it? Where do I put the files? And how do I access it? My system is Windaze 7 PC and a DUET-EtherNet controller.
                          Thanks in advance...3mm
                          There are 10 types of people: Those who understand binary and those who don't.
                          • gtj0undefined
                            gtj0 @wilriker
                            @wilriker
                            Yep, -removeLocal now works.
                            You can't specify the remote directory as 0:/ any more though. Not sure if this is intentional or not.
                            $ ./rfm backup -domain duet0 /tmp/duet0 0:/
                            2019/07/30 05:49:53 Fetching filelist for 0:/0:
                            2019/07/30 05:49:53 Directory not found
                            Doesn't matter to me, not sure if it's matter to others.
                            • wilrikerundefined
                              wilriker @3mm
                              @3mm You download the release for your operating system. For Windows that would be rfm-windows_amd64.zip. Then you unpack that to a location of your choice. It is a command-line tool so you have to open cmd and navigate to the directory where you unpacked rfm to (alternatively: in Explorer right click while holding shift in the directory where rfm.exe is located - this should provide a context-menu entry to open a command line in this directory).
                              There you can simply run
                              rfm help
                              to get an overview and the available sub-commands. With
                              rfm help <subcommand>
                              you can see individual parameters of each sub-command.
                              Manuel
                              My Tool Collection
                              3mmundefined 1 Reply Last reply Reply Quote 0
                              • wilrikerundefined
                                wilriker @gtj0
                                @gtj0 said in rfm - RepRapFirmware FileManager [duetbackup successor]:
                                @wilriker
                                No, that's a bug. 🤦 I'll look into that.
                                Manuel
                                My Tool Collection
                                • wilrikerundefined
                                  wilriker @gtj0
                                  @gtj0 Found it and fixed it.
                                  Release v1.1.0-RC3
                                  This can be found as usual on GitHub Releases page.
                                  Another bug fix. There was a regression introduced in v1.1.0-RC1 where it was no longer possible to specify the root directory of the SD card as 0:/. This is fixed in this release.
                                  Also this release candidate is intended to be the last one before final release of this version.
                                  Manuel
                                  My Tool Collection
                                  • 3mmundefined
                                    3mm @wilriker
                                    @wilriker
                                    Thank you very much!
                                    3mm
                                    • wilrikerundefined
                                      wilriker
                                      Arch User Repository Package
                                      For Arch Linux users: I have submitted a package to install rfm via AUR: https://aur.archlinux.org/packages/rfm/
                                      This is available for x86_64, arm, armv6h, armv7h and aarch64.
                                      Manuel
                                      My Tool Collection
                                      • wilrikerundefined
                                        wilriker
                                        Release v1.1.0
                                        v1.1.0 has existed Release Candidate stage and is now available at GitHub Releases page or via Arch User Repository.
                                        Reiterating the changes:
                                        Bug Fixes
                                        • -removeLocal was broken for files (working for directories though)
                                        • Sub-command upload would fail most of the times (this was fixed between RC3 and this version)
                                        Manuel
                                        My Tool Collection
                                        • fmaundefined
                                          fma
                                          I'm trying to use your script, but I always get 'invalid character '<' looking for beginning of value' error. What am I doing wrong?
                                          I'm using the amd64 version...
                                          Frédéric
                                          • wilrikerundefined
                                            wilriker @fma
                                            @fma This happens if the Duet responded with an HTML error page instead of a JSON error. I've seen this happen more often recently but so far have not found the cause.
                                            Are you using the latest v1.1.0 final release above?
                                            Also which sub-command does this happen for? Also you can use the parameter -debug to see the actual response coming from the Duet. This might give a hint what's going wrong.
                                            Manuel
                                            My Tool Collection
