rfm - RepRapFirmware FileManager [duetbackup successor]
Release v1.0.1
Bug fix release to fix the issue where on Windows
rfm.toml
would not be overwritten. Get it at GitHub Releases page. -
Hey Manuel, rfm has been working great for me but is there any chance you could automatically exclude the "System Volume Information" directory or maybe save excludes in the rfm.toml file?
@gtj0 I'll think about something.
Meanwhile you can also use
rfm
to just delete this stupid folder. It doesn't serve any purpose in the first place. I don't think that removable media are supposed to even have this folder. -
@gtj0 Here you go
Release v1.1.0-RC1
Get it at the GitHub Releases page.
This release implements the persisting of
-exclude
parameter values inrfm.toml
. These parameters will be persisted separately forbackup
andupload
command so they do not confuse each other.A new keyword
reset
has been added as a recognized value for the-exclude
parameter to delete all persisted excludes for the current command, i.e.rfm backup -exclude reset ...
will remove all persisted excludes for the
backup
command. Further-exclude
parameter after that (even in the same command) will add new excludes.Note that order is relevant, i.e.
rfm backup -exclude 0:/gcodes -exclude reset backup-dir 0:/
will backup everything in 0:/ since the given exclude for
0:/gcodes
was reset by the following-exclude reset
parameter. -
Is -removeLocal working?
./rfm backup -domain duet0 -removeLocal /tmp/duet0 /
Removing no longer existing files in /tmp/duet0/gcodes
But it doesn't actually remove any files from the local filesystem.
@gtj0 Last time I checked it worked. It will only remove local files that do not exist anymore on remote (like
-delete
forrsync
). I will check tomorrow if something is broken with it. -
@gtj0 You were right,
-removeLocal
was broken for removed files (it worked for removed directories). So here isRelease v1.1.0-RC2
This fixes broken
-removeLocal
parameter of thebackup
sub-command that did not delete files locally.Get it at the GitHub Releases page.
Hi wilriker,
I hate to sound stupid, but how do I use it? Where do I put the files? And how do I access it? My system is Windaze 7 PC and a DUET-EtherNet controller.
Thanks in advance...3mm
Yep, -removeLocal now works.
You can't specify the remote directory as0:/
any more though. Not sure if this is intentional or not.$ ./rfm backup -domain duet0 /tmp/duet0 0:/ 2019/07/30 05:49:53 Fetching filelist for 0:/0: 2019/07/30 05:49:53 Directory not found
Doesn't matter to me, not sure if it's matter to others.
@3mm You download the release for your operating system. For Windows that would be
rfm-windows_amd64.zip
. Then you unpack that to a location of your choice. It is a command-line tool so you have to opencmd
and navigate to the directory where you unpackedrfm
to (alternatively: in Explorer right click while holding shift in the directory whererfm.exe
is located - this should provide a context-menu entry to open a command line in this directory).There you can simply run
rfm help
to get an overview and the available sub-commands. With
rfm help <subcommand>
you can see individual parameters of each sub-command.
@gtj0 said in rfm - RepRapFirmware FileManager [duetbackup successor]:
No, that's a bug.
I'll look into that.
@gtj0 Found it and fixed it.
Release v1.1.0-RC3
This can be found as usual on GitHub Releases page.
Another bug fix. There was a regression introduced in
v1.1.0-RC1
where it was no longer possible to specify the root directory of the SD card as0:/
. This is fixed in this release.Also this release candidate is intended to be the last one before final release of this version.
Arch User Repository Package
For Arch Linux users: I have submitted a package to install
rfm
via AUR: https://aur.archlinux.org/packages/rfm/This is available for
x86_64
,arm
,armv6h
,armv7h
andaarch64
Release v1.1.0
v1.1.0 has existed Release Candidate stage and is now available at GitHub Releases page or via Arch User Repository.
Reiterating the changes:
This release implements the persisting of-exclude
andupload
reset
backup
0:/gcodes
parameter.Bug Fixes
-removeLocal
was broken for files (working for directories though)- Sub-command
upload
would fail most of the times (this was fixed between RC3 and this version)
I'm trying to use your script, but I always get 'invalid character '<' looking for beginning of value' error. What am I doing wrong?
I'm using the amd64 version...
@fma This happens if the Duet responded with an HTML error page instead of a JSON error. I've seen this happen more often recently but so far have not found the cause.
Are you using the latest v1.1.0 final release above?
Also which sub-command does this happen for? Also you can use the parameter
-debug
to see the actual response coming from the Duet. This might give a hint what's going wrong. -
Yes, I'm using the final release.
The error happens with all commands, and
-debug
does not give much info:./rfm ls 0:/ -debug 0:: 2019/08/18 12:52:40 invalid character '<' looking for beginning of value
BTW, does it require a specific version of RRF? Im' running 2.02RC2...
@fma It should work with any version of RRF. Though the
-debug
parameter has to come before the location to list (in this case) or more general: before any parameter that does not have its own-something
prefix. -
My bad, I made a mistake in the device name! All seems to work fine
Thanks for your help.
