Support for MKS mini 12864 LCD panel
Hi all,
Would like to know if the duet wifi supports the MKS mini LCD panel or any other LCD panel like Full graphics controller, etc.
Its just a economical option, and has front sd card loading which I find more convenient.
Thanks
Hussain. -
no the duet wifi is missing functionality required for the support.
only the duet maestro has support for a 12864 lcd. -
Thanks for the reply,
Does the duet support any other touch screen apart from the panel due.
Or is the UI on panel due modifiable ?
Regards,
Hussain -
The source code for the Panel Due is open source and available on GitHub.
There's also this for repurposing a tablet as customizable display.
There also exists (incomplete) firmware so that the MKS tft panel can be used similar to a PanelDue, see https://forum.duet3d.com/topic/2593/mks-tft32-duet for details (the firmware needs some undisclosed fix to work with recent versions of RRF though)
@doctrucker said in Support for MKS mini 12864 LCD panel:
The current firmware is at https://github.com/dc42/PanelDueFirmware.
Thank you all for your replies !
Will look into these !
