    Error: M141 "No Chamber Heater Has Been Configured for Slot 0"
    2.2k
    • jsn0327undefined
      jsn0327 @jsn0327
      The second screenshot didn't upload to the original post, so here it is.
        droftarts administrators
        It's because you're slicing with Cura. See this thread: https://forum.duet3d.com/topic/11546/cura-4-2-1-to-duet2wifi-plugin-problem
        I said: "I had this the other day, I think it's a new addition. Cura is adding an M141 command. While it produces an annoying popup, it is effectively ignored if you don't have a chamber heater. Disable it by opening Print settings in Cura and find "Build Volume Temperature" (usually hidden), and set it to 0C. Then it won't put the M141 in the gcode."
        • Spannersundefined
          Spanners
          If your using the Cura slicer, in the profile settings there is a setting called “Build Volume Temperature” under Material, change this to a value of 0 stops the error message.
          • jsn0327undefined
            jsn0327
            Awesome, thanks a lot for the quick answer! Any idea why I'm not getting statistics for the file that i'm printing?
            • jsn0327undefined
              jsn0327
              After changing the temp in Cura, I no longer get the M141 error. I do get a M900 is not supported message though; although it is in blue and not red like the Error. Is that another Cura setting? I set my gcode flavor to RepRap in Cura. Is that correct? I saw an option in the web configurator to make the firmware look like Marlin. What's the purpose of that?
              • Spannersundefined
                Spanners
                You must have a M900 command somewhere in your config files, the M900 is not a valid Reprap gcode.
                see this link ...
                https://reprap.org/wiki/G-code#M900_Set_Linear_Advance_Scaling_Factors
                  Phaedrux Moderator @jsn0327
                  @jsn0327 said in Error: M141 "No Chamber Heater Has Been Configured for Slot 0":
                  I'm guessing you have the linear advance plugin installed for Cura as well.
                  • jsn0327undefined
                    jsn0327
                    Yes i do. I turned it off and no longer get the error. I still do not receive any statistics during the print. Everything shows n/a. How do I enable those? The attached screenshot is what i'm talking about.
                      What version of firmware and DWC are you running?
                      jsn0327undefined 1 Reply Last reply Reply Quote 0
                      • jsn0327undefined
                        jsn0327 @Phaedrux
                        @phaedrux
                        Duet2 WiFi
                        Firmware Version: 2.04RC1 (2019-07-14b1)
                        WiFi Server Version: 1.23
                        Web Interface Version: 1.22.6
                        I went ahead and opened another thread on the issue to get more visibility.
                        https://forum.duet3d.com/topic/11640/all-stats-display-n-a-when-printing-file
