    New RepRapFirmware 3.0 early beta
    Firmware wishlist
    14
    79
    8.7k
      dc42 administrators @gtj0
      @gtj0 said in New RepRapFirmware 3.0 early beta:
      @dc42 using the tip of the current RRF v3-dev...
      Sent: M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 C0 R4700
      Sent: M308 S0
      Sensor 0 type Thermistor using pin bedtemp, last error: sensor not ready, T:100000.0 B:4138.0 C:0.00e+0 R:4700.0 L:0 H:0
      Sent: M308 S2 Y"thermistor" P"e1temp" A"HotEnd" T100000 B4725 C7.06e-8
      Sent: M308 S2
      Sensor 2 (HotEnd) type Thermistor using pin e1temp, last error: sensor not ready, T:100000.0 B:4725.0 C:7.06e-8 R:4700.0 L:0 H:0
      Is there something wrong with this M308 syntax? All temps are 2000.0
      There are some reported bugs in the current v3-dev. In particular, you need a quarter second delay between creating a sensor using M308 and creating a heater that uses it. I also have a report that configuring thermistors using M308 doesn't work (at least on Duet 3), which I am about to investigate.
      • gtj0undefined
        gtj0 @dc42
        @dc42 said in New RepRapFirmware 3.0 early beta:
        No problem. Thanks!
        If there's anything I can do to help, let me know. Specific bugs needing to be squashed, testing, etc.
          I've just committed new source code to fix a number of RRF3 bugs, including issues with temperature readings.
          • gtj0undefined
            gtj0 @dc42
            Yep, temps now read correctly. Thanks!
              dc42 administrators @smoki3
              @smoki3 said in New RepRapFirmware 3.0 early beta:
              It was definitely not like this on 2.02 and the older 3.0.
              And its a really wired behaviour. Because I use:
              ; tfree0.g
              ; called when tool 0 is freed
              ; generated by RepRapFirmware Configuration Tool on Wed Sep 19 2018 21:12:53 GMT+0200 (Mitteleuropäische Sommerzeit)
              G91
              G1 Z10 F7200
              G90
              G53 G1 X0 F25000 ;XPOS
              G53 G1 Y190
              G53 G1 Y195 F5000
              M400
              M98 P"/macros/Toolhead/1. Toolhead unlock"
              G4 P320
              G53 G1 Y207 F5000
              M400
              G53 G1 Y165 F25000
              M400
              ; tpre1.g
              ; called before tool 0 is selected
              G1 X76 F25000
              M400
              G1 Y192
              M400
              G4 P400
              G1 Y207 F5000
              M116 P3
              M400
              M98 P"/macros/Toolhead/2. Toolhead lock"
              G4 P260
              G1 Y150 F15000
              The I only expect that only a X movement is done while the start of the tpre1.g but it first moves in X and Y.
              @smoki3, I am looking into this but I need your config.g file, also the toolhead unlock files that you call from the tool change files.
              smoki3undefined 1 Reply Last reply Reply Quote 0
              • smoki3undefined
                smoki3
                @dc42 I will provide it until next week. I am on vacation
                • gtj0undefined
                  gtj0
                  @dc42 Homing seems to be broken at the moment.
                  If the axis is already homed and it's endstop is triggered, you can't run the homing sequence again without getting a Error: G0/G1: insufficient axes homed and the axis changing state to unhomed.
                  Example... Here's my CoreXY homex.g file...
                  G91               ; relative positioning
                  G1 H1 X-490 F3600 ; move quickly to X axis endstop and stop there (first pass)
                  G1 X5 F3600       ; go back a few mm
                  G1 H1 X-490 F360  ; move slowly to X axis endstop once more (second pass)
                  G90               ; absolute positioning
                  If the endstop isn't triggered the homing sequence runs. If it's already homed, I get the error.
                  Also, when it does work, it sometimes reports the tool at a small distance from 0. For instance, if I home X, sometimes the tool is reported at 0.000, sometimes, 0.105, sometimes 0.038, etc.
                  • gtj0undefined
                    gtj0
                    Oh, here's another one. I'm not sure of this is related to the tool offset discussion but when RRF initializes, the Z axis height displays the offset from the heightmap so as you move the X or Y axes, the Z axis position display changes.
                    • NoSkillzEngineerundefined
                      NoSkillzEngineer
                      Too bad the duet forum can't be merged with like a Discord server, that would be pretty cool and pretty convenient with how you can like tag or pin people or everyone in that particular thread, I'd be way more active on a Discord server, just saying, phone mobile notifications for the discord app are kinda nice, I have it notify my only when someone specifically tags me.
                      Not sure if you're interested in this at all, but I have have access to a few industrial machines, I found a way to get the list of the supported G-Codes and M-Codes in Fanuc's controllers. I have access to a 2014 Doosan Puma GT2100 CNC lathe and idk what year Doosan DNM 5700 mill and a very large and rather new Haas GR712 and two ProtoTrak controllers.
                      Perhaps I'm unfamiliar with the specific intent of the Duet 3.0, but I vaguely remember a conversation with you about standardizing the G-Codes at least, as M-Codes tend to be manufacturer and/or machine application specific. I'll get lists/pictures of all the G-Codes and M-Codes if you want and if there's any other information you want/need from the Fanuc controllers (kinda wanna reverse engineer their controller myself cuz they are the standard for industrial CNC controllers). It's for several networking and interface ports, can't imagine it would be that hard to get code from the controllers:)
                      Anything you wanna know about some of the industrial controllers we have in our shop??
                      Oh, and this is something cool I discovered is Macro B Programming on Fanuc controllers. Click here for a PDF on my Google drive about Macro B Programming inside Fanuc controllers
                      It allows parametric hand programming for canned cycles like G71 on a CNC lathe which is a roughing operation.
                      link to pictures of my program I created in a couple minutes
                      grizewaldundefined 1 Reply Last reply Reply Quote 1
                      • grizewaldundefined
                        grizewald @NoSkillzEngineer
                        @noskillzengineer said in New RepRapFirmware 3.0 early beta:
                        I for one would object to this very much, for several reasons:
                        1. The T&C for using Discord are "all your comments belong to us".
                        2. Mobile devices with their ultra slow on-screen keyboards are an incredibly frustrating experience for reading and creating textual and graphic content. Give me a computer with a proper keyboard every time.
                        3. Things like Discord servers and F***book are awful for storing information in a form where you can search for it and organise it in a structured way. They might be good for people with an attention span of minutes, but not for structured discussions.
                        4. Discord and other such platforms are not indexed by web search engines, making any information that they hold even more inaccessible.
                        NoSkillzEngineerundefined 1 Reply Last reply Reply Quote 1
                        • gtj0undefined
                          gtj0
                          @dc42 Just FYI... The current v3-dev RRF branch isn't building for the Duet2...
                          arm-none-eabi-gcc -L"/usr/src/3d/dc42/workspace/CoreNG/SAM4E8E" -L"/usr/src/3d/dc42/workspace/CoreNG/SAM4E8E" -L"/usr/src/3d/dc42/workspace/FreeRTOS/SAM4E" -L"/usr/src/3d/dc42/workspace/RRFLibraries/SAM4E_RTOS" -Os --specs=nano.specs -Wl,--gc-sections -Wl,--fatal-warnings -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard -T"/usr/src/3d/dc42/workspace/CoreNG/variants/duetNG/linker_scripts/gcc/flash.ld" -Wl,-Map,"/usr/src/3d/dc42/workspace/RepRapFirmware/Duet2_RTOS/Duet2CombinedFirmware.map" -o "Duet2CombinedFirmware.elf" -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--entry=Reset_Handler -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group "/usr/src/3d/dc42/workspace/CoreNG/SAM4E8E/cores/arduino/syscalls.o"  ./src/Tools/Filament.o ./src/Tools/Spindle.o ./src/Tools/Tool.o  ./src/Storage/CRC32.o ./src/Storage/FileInfoParser.o ./src/Storage/FileStore.o ./src/Storage/MassStorage.o  ./src/ObjectModel/ObjectModel.o  ./src/Networking/W5500Ethernet/Wiznet/Internet/DHCP/dhcp.o  ./src/Networking/W5500Ethernet/Wiznet/Ethernet/W5500/w5500.o  ./src/Networking/W5500Ethernet/Wiznet/Ethernet/WizSpi.o ./src/Networking/W5500Ethernet/Wiznet/Ethernet/socketlib.o ./src/Networking/W5500Ethernet/Wiznet/Ethernet/wizchip_conf.o  ./src/Networking/W5500Ethernet/W5500Interface.o ./src/Networking/W5500Ethernet/W5500Socket.o  ./src/Networking/ESP8266WiFi/WiFiInterface.o ./src/Networking/ESP8266WiFi/WiFiSocket.o ./src/Networking/ESP8266WiFi/WifiFirmwareUploader.o  ./src/Networking/FirmwareUpdater.o ./src/Networking/FtpResponder.o ./src/Networking/HttpResponder.o ./src/Networking/Network.o ./src/Networking/NetworkBuffer.o ./src/Networking/NetworkResponder.o ./src/Networking/TelnetResponder.o ./src/Networking/UploadingNetworkResponder.o  ./src/Movement/StepperDrivers/DriverMode.o ./src/Movement/StepperDrivers/TMC22xx.o ./src/Movement/StepperDrivers/TMC2660.o ./src/Movement/StepperDrivers/TMC51xx.o  ./src/Movement/Kinematics/CoreKinematics.o ./src/Movement/Kinematics/HangprinterKinematics.o ./src/Movement/Kinematics/Kinematics.o ./src/Movement/Kinematics/LinearDeltaKinematics.o ./src/Movement/Kinematics/PolarKinematics.o ./src/Movement/Kinematics/RotaryDeltaKinematics.o ./src/Movement/Kinematics/ScaraKinematics.o ./src/Movement/Kinematics/ZLeadscrewKinematics.o  ./src/Movement/HeightControl/HeightController.o  ./src/Movement/BedProbing/Grid.o ./src/Movement/BedProbing/RandomProbePointSet.o  ./src/Movement/DDA.o ./src/Movement/DDARing.o ./src/Movement/DriveMovement.o ./src/Movement/Move.o ./src/Movement/RawMove.o ./src/Movement/StepTimer.o  ./src/Libraries/sha1/sha1.o  ./src/Libraries/Fatfs/diskio.o ./src/Libraries/Fatfs/fattime_rtc.o ./src/Libraries/Fatfs/ff.o ./src/Libraries/Fatfs/ffunicode.o  ./src/Heating/Sensors/CpuTemperatureSensor.o ./src/Heating/Sensors/CurrentLoopTemperatureSensor.o ./src/Heating/Sensors/DhtSensor.o ./src/Heating/Sensors/LinearAnalogSensor.o ./src/Heating/Sensors/RemoteSensor.o ./src/Heating/Sensors/RtdSensor31865.o ./src/Heating/Sensors/SensorWithPort.o ./src/Heating/Sensors/SpiTemperatureSensor.o ./src/Heating/Sensors/TemperatureSensor.o ./src/Heating/Sensors/Thermistor.o ./src/Heating/Sensors/ThermocoupleSensor31855.o ./src/Heating/Sensors/ThermocoupleSensor31856.o ./src/Heating/Sensors/TmcDriverTemperatureSensor.o  ./src/Heating/FOPDT.o ./src/Heating/Heat.o ./src/Heating/Heater.o ./src/Heating/HeaterProtection.o ./src/Heating/LocalHeater.o ./src/Heating/RemoteHeater.o ./src/Heating/TemperatureError.o  ./src/Hardware/DmacManager.o ./src/Hardware/I2C.o ./src/Hardware/IoPorts.o  ./src/GCodes/GCodeBuffer/BinaryParser.o ./src/GCodes/GCodeBuffer/GCodeBuffer.o ./src/GCodes/GCodeBuffer/StringParser.o  ./src/GCodes/GCodeChannel.o ./src/GCodes/GCodeInput.o ./src/GCodes/GCodeMachineState.o ./src/GCodes/GCodeQueue.o ./src/GCodes/GCodes.o ./src/GCodes/GCodes2.o ./src/GCodes/GCodes3.o ./src/GCodes/GCodes4.o ./src/GCodes/RestorePoint.o ./src/GCodes/Trigger.o  ./src/FilamentMonitors/Duet3DFilamentMonitor.o ./src/FilamentMonitors/FilamentMonitor.o ./src/FilamentMonitors/LaserFilamentMonitor.o ./src/FilamentMonitors/PulsedFilamentMonitor.o ./src/FilamentMonitors/RotatingMagnetFilamentMonitor.o ./src/FilamentMonitors/SimpleFilamentMonitor.o  ./src/Fans/DotStarLed.o ./src/Fans/Fan.o  ./src/Endstops/Endstop.o ./src/Endstops/EndstopsManager.o ./src/Endstops/ZProbe.o ./src/Endstops/ZProbeProgrammer.o  ./src/DuetNG/DueXn.o ./src/DuetNG/Pins_DuetNG.o ./src/DuetNG/SX1509.o  ./src/Display/ST7920/glcd11x14.o ./src/Display/ST7920/glcd7x11.o ./src/Display/ST7920/lcd7920.o  ./src/Display/Display.o ./src/Display/Menu.o ./src/Display/MenuItem.o ./src/Display/RotaryEncoder.o  ./src/CAN/CanInterface.o ./src/CAN/CanMessageGenericConstructor.o ./src/CAN/CanMotion.o ./src/CAN/CommandProcessor.o  ./src/Logger.o ./src/OutputMemory.o ./src/Platform.o ./src/PortControl.o ./src/PrintMonitor.o ./src/RepRap.o ./src/RepRapFirmware.o ./src/Roland.o ./src/Scanner.o ./src/SoftTimer.o ./src/Tasks.o   -lCoreNG -lCoreNG -lFreeRTOS -lRRFLibraries -Wl,--end-group -lm
                          /opt/x-tools/gcc-arm-none-eabi-8-2018-q4-major/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld: ./src/RepRap.o: in function `RepRap::GetStatusCharacter() const':
                          RepRap.cpp:(.text._ZNK6RepRap18GetStatusCharacterEv+0x26): warning: undefined reference to `Platform::HasVinPower() const
                          Could you update us on which branches of the various projects currently go together for the Duet2 and Duet3 and which configurations go together for the Duet3 as I can't get that to build either.
                          Also, there's a typo in src/Heating/RemoteHeater.cpp 🙂
                          #include <CanMessageformats.h> should be
                          #include <CanMessageFormats.h>
                            NoSkillzEngineer @grizewald
                            @grizewald Hmmm, I didn't know that about the comments and content. I also was not considering the retrieval of information or the storing of it, I was thinking purely communication specific. I use Swype for my phone and there is no way I can type faster on a keyboard, no way. A phone, specifically an android one, also utilizes Google's Talk-To-Text which you can more or less speak normally and it'll beat most far typers with minimal errors in most dialects, with exceptions of course. Just a quick thought, I don't care to go into chrome and logon each time and go to the website specifically to go into the forum. Their own app (built with flutter) could also be an alternative. ¯_(ツ)_/¯
                            grizewaldundefined 1 Reply Last reply Reply Quote 0
                              I use a keyboard all day long and can type 120 words per minute, so predictive text input is still slower for me. I can't bring myself to sit talking to an inanimate object and I'd look pretty stupid doing that in front of other people. 🙂
                                Now fixed. For RRF3 use the v3-dev branch of RepRapFirmware and the dev branches of everything else (except CANlib which doesn't have a dev branch).
                                • gtj0undefined
                                  gtj0
                                  @dc42 Homing still seems to be an issue as well as the "slightly off" home positions.
                                  • wilrikerundefined
                                    wilriker @dc42
                                    The case-issue is still not fixed in latest v3-dev branch (I also sent a Pull Request a couple of days ago). EDIT: That was an issue with not correctly fetching the latest changes.
                                    More problematic for me is that I cannot build RRF 3 for DUET3_V05 (or DUET3_V06). It bombards me with linker errors:
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/libFreeRTOS.a(tasks.o): in function `prvIdleTask':
                                    /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:3266: warning: undefined reference to `vPortYield'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/libFreeRTOS.a(tasks.o): in function `prvAddCurrentTaskToDelayedList':
                                    /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:4929: warning: undefined reference to `portRESET_READY_PRIORITY'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/libFreeRTOS.a(tasks.o): in function `prvAddNewTaskToReadyList':
                                    /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:1084: warning: undefined reference to `portRECORD_READY_PRIORITY'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:1096: warning: undefined reference to `vPortYield'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/libFreeRTOS.a(tasks.o): in function `vTaskDelete':
                                    /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:1125: warning: undefined reference to `portRESET_READY_PRIORITY'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:1190: warning: undefined reference to `vPortYield'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/libFreeRTOS.a(tasks.o): in function `xTaskIncrementTick':
                                    /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:2676: warning: undefined reference to `portRECORD_READY_PRIORITY'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/libFreeRTOS.a(tasks.o): in function `xTaskResumeAll':
                                    /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:2134: warning: undefined reference to `portRECORD_READY_PRIORITY'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:2196: warning: undefined reference to `vPortYield'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/libFreeRTOS.a(tasks.o): in function `vTaskDelayUntil':
                                    /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:1275: warning: undefined reference to `vPortYield'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/libFreeRTOS.a(tasks.o): in function `vTaskDelay':
                                    /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:1320: warning: undefined reference to `vPortYield'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:1320: warning: undefined reference to `vPortYield'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/libFreeRTOS.a(tasks.o): in function `vTaskSwitchContext':
                                    /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:2896: warning: undefined reference to `portGET_HIGHEST_PRIORITY'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/libFreeRTOS.a(tasks.o): in function `vTaskSuspend':
                                    /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:1646: warning: undefined reference to `portRESET_READY_PRIORITY'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:1699: warning: undefined reference to `vPortYield'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/libFreeRTOS.a(tasks.o): in function `xTaskRemoveFromEventList':
                                    /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:3009: warning: undefined reference to `portRECORD_READY_PRIORITY'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/libFreeRTOS.a(tasks.o): in function `xTaskPriorityInherit':
                                    /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:3834: warning: undefined reference to `portRESET_READY_PRIORITY'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:3843: warning: undefined reference to `portRECORD_READY_PRIORITY'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/libFreeRTOS.a(tasks.o): in function `xTaskPriorityDisinherit':
                                    /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:3933: warning: undefined reference to `portRECORD_READY_PRIORITY'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:3917: warning: undefined reference to `portRESET_READY_PRIORITY'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/libFreeRTOS.a(tasks.o): in function `vTaskPriorityDisinheritAfterTimeout':
                                    /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:4042: warning: undefined reference to `portRECORD_READY_PRIORITY'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:4035: warning: undefined reference to `portRESET_READY_PRIORITY'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/libFreeRTOS.a(tasks.o): in function `ulTaskNotifyTake':
                                    /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:4433: warning: undefined reference to `vPortYield'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/libFreeRTOS.a(tasks.o): in function `xTaskGenericNotify':
                                    /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:4619: warning: undefined reference to `portRECORD_READY_PRIORITY'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:4644: warning: undefined reference to `vPortYield'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/libFreeRTOS.a(tasks.o): in function `vTaskNotifyGiveFromISR':
                                    /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:4818: warning: undefined reference to `ulSetInterruptMaskFromISR'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:4839: warning: undefined reference to `portRECORD_READY_PRIORITY'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/../src/tasks.c:4870: warning: undefined reference to `vClearInterruptMaskFromISR'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/libFreeRTOS.a(queue.o): in function `xQueueGenericReset':
                                    /home/manuel/github/FreeRTOS/SAME70/../src/queue.c:274: warning: undefined reference to `vPortYield'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/libFreeRTOS.a(queue.o): in function `xQueueGenericSend':
                                    /home/manuel/github/FreeRTOS/SAME70/../src/queue.c:901: warning: undefined reference to `vPortYield'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/../src/queue.c:767: warning: undefined reference to `vPortYield'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/libFreeRTOS.a(queue.o): in function `xQueueSemaphoreTake':
                                    /home/manuel/github/FreeRTOS/SAME70/../src/queue.c:1538: warning: undefined reference to `vPortYield'
                                    /usr/lib/gcc/arm-none-eabi/9.2.0/../../../../arm-none-eabi/bin/ld: /home/manuel/github/FreeRTOS/SAME70/../src/queue.c:1450: warning: undefined reference to `vPortYield'
                                    Manuel
                                    My Tool Collection
                                    • gtj0undefined
                                      gtj0 @wilriker
                                      @wilriker said in New RepRapFirmware 3.0 early beta:
                                      Yeah same here .
                                      • martinkundefined
                                        martink
                                        The SAME70 configuration include paths for FreeRTOS include src/portable/GCC/ARM_CM0. Changing that to src/portable/GCC/ARM_CM7/r0p1 helps. I haven't tried using the resulting firmware binary.
                                        wilrikerundefined dc42undefined 2 Replies Last reply Reply Quote 1
                                        • wilrikerundefined
                                          wilriker @martink
                                          @martink Thanks for spotting that! This fixes linker errors. And it flashs fine so far.
                                          Manuel
                                          My Tool Collection
                                            dc42 administrators @martink
                                            @martink said in New RepRapFirmware 3.0 early beta:
                                            Thanks, fixed in latest commit.
