    Pay for config / json files for my corexy printer build.
    67
    5.6k
    • zaptaundefined
      zapta
      Does this help? https://forum.duet3d.com/topic/6760/stop-g
      Stevoundefined 1 Reply Last reply Reply Quote 0
      • Stevoundefined
        Stevo @zapta
        @zapta thank you !
        • Stevoundefined
          Stevo
          Evening all just wondered if one of you kind folk could cast an eye over my config file to see if it could be improved in any way please speeds and placement of codes within the file.
          As always your comments greatly received
          ; generated by RepRapFirmware Configuration Tool v2 on Tue Jul 23 2019 21:10:42 GMT+0100 (BST)
          M669 K1 ; Select CoreXY mode
          M550 P"CORE XY" ; Set machine name
          M552 S1 ; Enable network
          ;*** Access point is configured manually via M587
          M586 P0 S1 ; Enable HTTP
          M586 P1 S0 ; Disable FTP
          M586 P2 S0 ; Disable Telnet
          M569 P0 S1 ; Physical drive 0 goes forwards
          M569 P1 S1 ; Physical drive 1 goes forwards
          M569 P2 S0 ; Physical drive 2 goes backwards
          M569 P3 S1 ; Physical drive 3 goes forwards
          M92 X80.00 Y80.00 Z1600.00 E415.00 ; Set steps per mm
          M566 X900.00 Y900.00 Z30.00 E2400 ; Set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z144.00 E1200.00 ; Set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
          M906 X800.00 Y800.00 Z2000.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X-220 Y-220 Z0 S1 ; Set axis minima
          M208 X220 Y220 Z660 S0 ; Set axis maxima
          M574 X1 Y1 S0 ; Set active low and disabled endstops
          M574 Z1 S2 ; Define Z to use Probe. Home to Min.
          M558 P5 H5 F500 T4000 X0 Y0 Z1 ; Set Z probe type/mode 5. Not using on XY, but using it on Z.
          G31 P25 X2 Y32 Z0.0 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
          ; BLTOUCH PREP
          G4 S1
          M280 P7 S160 I1 ; Alarm Release and Push-Pin UP just in case it's in alarm and deployed
          G4 S1
          M402 ; Retract probe just in case it's down
          M574 Z1 S2 ; Set endstops controlled by probe
          M307 H7 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
          M558 P9 H15 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
          G31 P500 X32 Y2 Z0.96 ; Set Z probe trigger value, offset and trigger height
          M557 X220:220 Y-220:220 S20 ; Define mesh grid
          M140 H-1 ; Disable heated bed
          M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
          M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
          M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
          M563 P0 D0 H1 ; Define tool 0
          ; BLTOUCH PREP
          G4 S1
          G4 S1
          T0 ; Select first tool
            deckingman @Stevo
            @stevo If I was being really pedantic I'd say that you have disabled thermostatic mode for your part cooling fan (M106 P0 H-1) which is fine, but the comment after says "Thermostatic control is turned on" (should say "off").
            But I'm not feeling pedantic so I won't make that comment.
            Seriously, nothing leaps out as being obviously amiss. I think you are at the stage of playing around with things to see if the end result looks any better or can be printed faster without degrading quality. One good thing about Duet is that you can play around with things "one the fly".
            If you want, you can give your heaters and fans names for example such as "Hot end" rather than the default "heater 1" (M305 "S") or "Part fan" rather than "fan 0" (M106 "C").
            You could try firmware retraction (G10 /G11). It won't work any better than your slicer but you can play around with it "on the fly" which is a far easier way to tune the retraction settings.
            You could also play around with pressure advance (M572).
            • Stevoundefined
              Stevo
              Thank you for the input always appreciated !
              • Stevoundefined
                Stevo
                I have been tinkering with the driver speed settings in the config file only would this have any effect on the bltouch operation as when the x and y axis has homed and the head moves to the centre the bed raises a little before the bltouch has lowered the pin then changes its mind and lowers the bed.
                The bltouch then flashes red
                  You can add a bit of a pause delay to the probe movements with M558 R0.5. This gives the BLTouch a half second chance to settle before starting to probe.
                  • Stevoundefined
                    Stevo
                    Afternoon everyone,
                    I wonder if I could seek some clarification please Part cooling fan and hot end fan operate as they should during the print apart from the part cooling fan not turning off when the print has finished which I'm guessing I need to add a line to my S3D end code this is what I have in the config g file .
                    M106 P0 S0 I0 F500 H-1 ; Part cooling fan
                    M106 P1 S1 I0 F500 H1 T35 ; Hot end fan set to come on and off at 35
                    and S3D end code.
                    G91 ; relative positioning
                    M104 S0 ; extruder heater off
                    G1 E-1 F300 ; retract the filament
                    G1 Z15 F1000 S2 ; lift Z relative to current position
                    G1 S1 Y-445 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                    G1 Y5 F1000 ; go back a few mm
                    G1 S1 Y-445 F360 ; move slowly to Y axis endstop once more (second pass)
                    G1 S1 X-445 F1800 ; move quickly to X axis endstop and stop there (first pass)
                    G1 X5 F1000 ; go back a few mm
                    G1 S1 X-445 F360 ; move slowly to X axis endstop once more (second pass)
                    G90 ; absolute positioning
                    M84 ;steppers off
                    G90 ;absolute positioning
                      deckingman @Stevo
                      @stevo Add "M106 S0" to your end gcode.
                      • Stevoundefined
                        Stevo
                        Thank you
                        • Stevoundefined
                          Stevo
                          Just wanted to thank all those that have and continue to help me on my build thought I would share a pic of last nights print.
                          Still trying to get my head around the intricacies of S3D some good and some bad lol
                          zaptaundefined deckingmanundefined 2 Replies Last reply Reply Quote 2
                            Looking good.
                            • zaptaundefined
                              zapta @Stevo
                              @stevo, looks very good. Maybe now you can help me achieving similar print quality 😉
                                deckingman @Stevo
                                @stevo Glad to see the progress you've made since 26th June. All without paying a bean too. ☺ I hope you understand why we pointed you in the right directions for you to do it yourself, rather than take your money and do it for you. If you haven't done so already, you'll soon be helping others with the knowledge that you have now gained.
                                • Stevoundefined
                                  Stevo
                                  Thanks again everyone for your continued help much appreciated and will hopefully be confident enough to help others.
