    Presentation of the CR-3D C1 with Duet Electronics
    My Duet controlled machine
    1.5k
    • taconiteundefined
      taconite
      Maybe cause you cant't have a custom UI on the PanelDue (or ist that possible)?
      Custom ANET A8
      Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
      All I do here is under this license: CC BY-NC-SA
      • Vetiundefined
        Veti
        @taconite said in Presentation of the CR-3D C1 with Duet Electronics:
        the source code is available and can be customised.
        taconiteundefined 1 Reply Last reply Reply Quote 0
        • taconiteundefined
          taconite @Veti
          @veti yeah sure it is but it is not that easy (or is it)?🙈
          Custom ANET A8
          • Vetiundefined
            Veti @taconite
            @taconite
            you asked if its possible, not if its easy. ☺
            • taconiteundefined
              taconite
              true.
              @CR3D what magnetic build plattform are you using that it can stand 120°C. Is it a magnetic flex plate or spring steel?
              Custom ANET A8
              CR3Dundefined 1 Reply Last reply Reply Quote 0
                A Former User
                I think the lack of ease to modify the PanelDue interface is one of the reasons for the next generation Duet using a Raspberry Pi as well. Wide range of touch screens and simpler to adapt DWC. Not sure why OP went with Repeteir instead of DWC, maybe prior experience? Maybe he felt offering integrated slicing was a added value?
                • oliofundefined
                  oliof
                  @bearer Repetier host has an integrated slicer? That would indeed be an up-side I would immediately understand to motivate this decision.
                    A Former User @oliof
                    @oliof said in Presentation of the CR-3D C1 with Duet Electronics:
                    seems its a feature of the pro version of repetier server (never tried it, went with octoprint instead at the time)
                    https://www.repetier-server.com/version-comparison/
                    • Danalundefined
                      Danal @taconite
                      A tablet (or similar) with DWC was also suggested. Or almost anything but a USB interfaced, last millenium, legacy, hamstrung... you get the drift...
                      • CR3Dundefined
                        CR3D @oliof
                        Sorry Guys... I was not available for a few days!
                        @oliof
                        I use the raspberry pi with repetier server, because the touch and web interface is really clean and easy!
                        It is simply very clear and now in the near future there will be a program to manage all the printers in one interface. and that makes a lot of sense in printing-farms!
                        And it is not Repetier-Host... it is repetier-Server! But it´s quite the same, both with usb connection!
                        -> Question: Is it possible to bring the DWC to the raspberry pi?
                        @CaLviNx
                        Thank you for your honest opinion! and I can understand it very well, because I often ask the same question! yes it is actually stupid if you throttled down the performance of duet! But unfortunately it really is the case that the companies prefer this surface and thus accept the performance restrictions.
                        @bearer
                        Yes in the next time there will be an integrated slicer from repetier!
                        Christian from CR-3D
                        Homepage:
                        www.cr-3d.de
                        Facebook:
                        https://www.facebook.com/cr3d.official
                        Our Discord Server
                        https://discord.gg/SxRaPNuRdA
                        Thingiverse Profile:
                        https://www.thingiverse.com/cr-3d_official/about
                        • CR3Dundefined
                          CR3D @taconite
                          @taconite
                          Yes the build plattform can stand 120°C. There is a magnetic sheet and then a spring steel with the print surface on it... 😉
                          Homepage:
                          www.cr-3d.de
                          Facebook:
                          Our Discord Server
                            A Former User @A Former User
                            @cr3d said in Presentation of the CR-3D C1 with Duet Electronics:
                            see https://forum.duet3d.com/topic/11540/duet-3-mainboard-6hc-initial-production-run/85
                            (i.e. dwc is already on the pi, but 2nd gen duet support is more of a maybe. 3rd gen is ready to rumble)
