    25.95mm/rev, min -33% max 162% over 9615.6mm
    Filament Monitor
    1.4k
    • nurooundefined
      nuroo
      more data:
      M591 D0
      Duet3D rotating magnet filament monitor v2 on input 3, disabled, sensitivity 24.94mm/rev, allow 80% to 130%, check every 3.0mm, current pos 149.4, measured sensitivity 25.30mm/rev, min 0% max 114% over 11368.0mm
        T3P3Tony administrators @nuroo
        @nuroo with that filament path - that might be the range of what the filament monitor is actually seeing as there will be loads of elasticity in the feed tube. short retractions probably hardly move the monitor. Have you tried with it close to the extruder like @themelle
        themelleundefined 1 Reply Last reply Reply Quote 0
        • themelleundefined
          themelle @T3P3Tony
          @T3P3Tony The measured maximum value may be quite accurate, but 0 or negative numbers as minimum values do not really make any sense (at least to me), do they? 😉
          As @nuroo and me are having comparable issues (min values way to low, frame and/or pol errors in sensor communication) with different sensor placements I assume we are either missing something fundamental setup-wise, or there is an issue with the sensor itself, the way it is wired up, or how robust the firmwares' communications portions are. I do have high hopes to resolve those issues with you and @dc42 within an acceptable time frame, and in turn may contribute to make the Duet rotating magnet sensor more reliable for every user out there.
          • samlogan87undefined
            samlogan87
            Hmm maybe I shouldn’t have just ordered one 😬
            Custom Core-XY
            • themelleundefined
              themelle @samlogan87
              @samlogan87 Of course you should - the more of it in the wild, the better to resolve any random issues. It's a quite well designed product, and I am confident that it will perform as expected, once we have a larger user base and therefore more feedback as to what works and what (and more importantly: why) not.
                samlogan87
                Yeah I do agree, it’s more just if changes need to be made to the firmware on the sensor I am a bit screwed. I am really keen to get one so I guess we will see what happens when it arrives
                Regards
                Sam
                Custom Core-XY
                • nurooundefined
                  nuroo
                  @T3P3Tony im not sure I want to move the sensor above extruder. Certainly not ideal for a corexy setup. Already moving the mass of extruder, stepper motor, hotend etc around..... I didnt realize this sensor needed to be close to the extruder when I bought it. Is that requirement listed on product page?
                  Can we not account for different setups in firmware with options for a setup like this.
                    samlogan87
                    @nuroo I will be in the same boat. Mine will have to go at the end of 650mm of tube. I am running a flex3drive and mounting the sensor on the carriage with the drive tube in the way will be impossible
                    Regards
                    Sam
                    Custom Core-XY
                      The filament monitor must be right next to the extruder drive input or output. Any other arrangement allows the filament to flex too much in the tubing between the two, in particular when the direction of motion reverses.
                      • nurooundefined
                        nuroo
                        Well ok. I need to make an extension and try again. I wish this requirement was noted to customer on product page or wiki. I'll report back.
                        • nurooundefined
                          nuroo
                          New Setup
                          === Filament sensors ===
                          Extruder 0: pos 188.09, ok, measured sens 24.89mm/rev min 95% max 103% over 1015.3mm, errs: frame 0 parity 0 ovrun 0 pol 1 ovdue 0
                          M591 D0
                          Duet3D rotating magnet filament monitor v2 on input 3, disabled, sensitivity 24.80mm/rev, allow 70% to 130%, check every 3.0mm, current pos 44.6, measured sensitivity 24.90mm/rev, min 95% max 103% over 1021.3mm
                          much better numbers, but will I get false positives when I enable sensor?
                          M591 D0 P3 C3 S1 R100:110 L24.90 E3.0 ;
                          • nurooundefined
                            nuroo
                            2 successful prints, no false positives with new setup.
                            M591 D0 P3 C3 S1 R90:110 L24.96 E3.0 ;
                            now to try a real filament outage
                            • themelleundefined
                              themelle @nuroo
                              @nuroo Congratulations on getting it to work as intended!
                              Now I'm left alone again with my "frame errors"/"sensor has stopped working" problem.
                              May try to send it back to Filastruder as I am out of ideas now 😞
                                @nuroo said in 25.95mm/rev, min -33% max 162% over 9615.6mm:
                                I am glad you got it working and thanks for the feedback, i have updated the installation section of the documentation to note the requirement: https://duet3d.dozuki.com/Wiki/Duet3dFilamentMonitor_RotatingMagnetVersion#Section_Installation
                                @themelle i think asking filastruder to swap it will be a good test to see if this is a board that passed testing but is marginal in your setup.
                                • themelleundefined
                                  themelle @T3P3Tony
                                  @t3p3tony Thanks for your honest feedback.
                                  May I direct Filastruder support to your post confirming a warranty swap?
                                    T3P3Tony administrators @themelle
                                    @themelle yes
                                    • themelleundefined
                                      themelle @T3P3Tony
                                      @t3p3tony Thank you!
                                      • nurooundefined
                                        nuroo
                                        Well I thought I was good to go with correct setup.
                                        2 small 1 hour long prints no false positives. 11hour print - false trigger to little movement, about 5 hours in. Had to disable sensor so I didn't have to sit there having to keep resuming print.
                                        • nurooundefined
                                          nuroo
                                          Are there any other troubleshooting measures I could try?
                                          • themelleundefined
                                            themelle @nuroo
                                            @nuroo I got my sensor swapped as it seemed to be faulty. Since then I have been getting much better values - but I am running 70-130% allowed movement to compensate for spike values.
                                            Maybe you also should loosen the grip a little bit 🙂
