    Need help to define Z max endstop
    1.3k
    • Vetiundefined
      Veti
      post your homez script
      • Olivierundefined
        Olivier
        ; homez.g
        ; called to home the Z axis
        ; generated by RepRapFirmware Configuration Tool on Tue Oct 02 2018 19:18:29 GMT+0200 (heure d’été d’Europe centrale)
        G91 ; relative positioning
        G1 Z10 F2000 S2 ; lift Z relative to current position
        G90 ; absolute positioning
        G1 X140 Y140 F2000 S2 ; go to first probe point
        M98 Pdeployprobe.g
        M98 Pretractprobe.g
        G1 S2 Z10 F2000 ; lift Z relative to current position
        • Vetiundefined
          Veti
          that script is set up to use a probe to homez not the endstop at max.
          • Olivierundefined
            Olivier
            I have a bltouch, but I want also add a switch to lower the bed at the end of the print (like ultimaker)
            • Vetiundefined
              Veti
              you can either have a probe or an endstop, not both.
              see
              https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_Set_endstop_configuration
              Snnn Endstop type: 0 = active low endstop input, 1 = active high endstop input, 2 = Z probe, 3 = motor load detection
              • Olivierundefined
                Olivier
                Ok thank you. I will find another solution.
                • Vetiundefined
                  Veti
                  what are you trying to achieve?
                  • Olivierundefined
                    Olivier
                    Hypercube evolution 🙂
                    • Vetiundefined
                      Veti
                      what are you trying to achieve with the z max endstop?
                        T3P3Tony administrators @Olivier
                        @olivier Rather than using a switch, if you just want to lower the bed then send it to that specific position at the end of the print: G1 Zzzz Fnnnn
                        You don't need a switch because the printer knows where Z is at the end of the print.
                        • Olivierundefined
                          Olivier
                          Hi @T3P3Tony ,
                          Yes but I would like to add a user macro "down the bed" without homing (for exemple after a power failure).
                          Maybe it's possible with stall detection ?
                            @olivier It may be possible with stall detection. but if you just want a macro and you have a switch then just write the macro to move and stop when the switch is sensed, wrap the movement in a line to configure that switch as the Z endstop and then configure it back to the probe after the movement has finished.
                            • Olivierundefined
                              Olivier
                              I tryed to do that but without good result,
                              Could you just write this 2 or 3 lines ? Thank you for your help.
                                @olivier If you determine the Z axis setting to use a switch at Z max (i think you have already done that) then the macro would be something like:
                                Z_Max_home.g macro in /macros/
                                M574 Z2 S0
                                G1 Z300 F<something sensible> H1
                                M574 <whatever you have in your config.g to setup for the BL touch>
                                Note i have not tried this so you will need to experiment a bit and have your hand on the power button as things move!
                                Olivierundefined 1 Reply Last reply Reply Quote 0
                                • Olivierundefined
                                  Olivier @T3P3Tony
                                  @t3p3tony said in Need help to define Z max endstop:
                                  M574 Z2 S0
                                  Bed going down but don't stop when I press the switch. The endstop LED react correctly
                                  • Vetiundefined
                                    Veti @Olivier
                                    @olivier
                                    add S1 to the G1 command
                                    • Olivierundefined
                                      Olivier @Veti
                                      @veti It dont move at all with S1
                                      • Vetiundefined
                                        Veti
                                        @olivier said in Need help to define Z max endstop:
                                        M574 Z2 S0
                                        try changing this to
                                        M574 Z2 S1
                                        • Olivierundefined
                                          Olivier @Veti
                                          @veti Same problem... 😞
                                            @olivier @veti S1/H1 are interchangable in G1
