    Need help to define Z max endstop
    1.4k
    • Vetiundefined
      Veti
      what are you trying to achieve?
      • Olivierundefined
        Olivier
        Hypercube evolution 🙂
        • Vetiundefined
          Veti
          what are you trying to achieve with the z max endstop?
            T3P3Tony administrators @Olivier
            @olivier Rather than using a switch, if you just want to lower the bed then send it to that specific position at the end of the print: G1 Zzzz Fnnnn
            You don't need a switch because the printer knows where Z is at the end of the print.
            • Olivierundefined
              Olivier
              Hi @T3P3Tony ,
              Yes but I would like to add a user macro "down the bed" without homing (for exemple after a power failure).
              Maybe it's possible with stall detection ?
                @olivier It may be possible with stall detection. but if you just want a macro and you have a switch then just write the macro to move and stop when the switch is sensed, wrap the movement in a line to configure that switch as the Z endstop and then configure it back to the probe after the movement has finished.
                • Olivierundefined
                  Olivier
                  I tryed to do that but without good result,
                  Could you just write this 2 or 3 lines ? Thank you for your help.
                    @olivier If you determine the Z axis setting to use a switch at Z max (i think you have already done that) then the macro would be something like:
                    Z_Max_home.g macro in /macros/
                    M574 Z2 S0
                    G1 Z300 F<something sensible> H1
                    M574 <whatever you have in your config.g to setup for the BL touch>
                    Note i have not tried this so you will need to experiment a bit and have your hand on the power button as things move!
                    Olivierundefined 1 Reply Last reply Reply Quote 0
                    • Olivierundefined
                      Olivier @T3P3Tony
                      @t3p3tony said in Need help to define Z max endstop:
                      M574 Z2 S0
                      Bed going down but don't stop when I press the switch. The endstop LED react correctly
                      • Vetiundefined
                        Veti @Olivier
                        @olivier
                        add S1 to the G1 command
                        • Olivierundefined
                          Olivier @Veti
                          @veti It dont move at all with S1
                          • Vetiundefined
                            Veti
                            @olivier said in Need help to define Z max endstop:
                            M574 Z2 S0
                            try changing this to
                            M574 Z2 S1
                            • Olivierundefined
                              Olivier @Veti
                              @veti Same problem... 😞
                                @olivier @veti S1/H1 are interchangable in G1
                                  T3P3Tony administrators @T3P3Tony
                                  @Olivier what does M119 show when you have the Z switch triggered?
                                  • Olivierundefined
                                    Olivier @T3P3Tony
                                    @t3p3tony
                                    M119
                                    Endstops - X: not stopped, Y: not stopped, Z: at min stop, Z probe: at min stop
                                    • Vetiundefined
                                      Veti @Olivier
                                      @olivier
                                      issue the command
                                      M574 Z2 S0
                                      check M119 when the endstop is not triggerd
                                      hold endstop
                                      check M119 again
                                      • Olivierundefined
                                        Olivier @Veti
                                        @veti said in Need help to define Z max endstop:
                                        M574 Z2 S0
                                        14:12:13M119
                                        Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: not stopped
                                        14:12:04M119
                                        Endstops - X: not stopped, Y: not stopped, Z: at max stop, Z probe: not stopped
                                        14:11:58M574 Z2 S0
                                        • Olivierundefined
                                          Olivier
                                          My macro :
                                          M574 Z2 S0
                                          G1 Z300 F3000
                                          M574 Z1 S2 ; Set endstops controlled by probe
                                          It was inverted so I put the command M574 Z2 S1 but it not stop anyway...
                                          • Vetiundefined
                                            Veti
                                            There is no endstop command in your macro and it seems you need to invert the endstop
                                            try
                                            M574 Z2 S1
                                            G1 Z300 F3000 H1
                                            M574 Z1 S2
