Solved Wifi/Web Console issues
@bearer said in Wifi/Web Console issues:
@shaun said in Wifi/Web Console issues:
so its clearly reading from it.
No.
I dont have those details in the Config.g.
yes, thats correct, after you enter the details with M587 it is stored in the wifi modules flash memory. which is part of the reason the documentations tells you not to use M587 (to store wifi details) in config.g, the wifi module is not enabled at the time config.g is executed and saving the wifi details every time would put unnecessary wear on the wifi flash memory.
OK, so could you help me figure out why the wifi is not even coming on when i power the board? At which point is M552 S0 read from Flash?
M552 S0 = turn off networking, you do not want that in your config.g if you want networking.
config.g that contains this should connect if a ssid and pw is previously set.
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable Telnet -
What is the power supply? Do the rest of the lights and everything else come on?
When it is powered by the PSU, can you connect via USB as well and send M122 with the correct YAT line endings and report what the diagnostic replies with?
@phaedrux said in Wifi/Web Console issues:
Ill get this when i get home, PSU is as per vendor recommendations.
Red light by the USB power port, 2 more lights to the left of that. No blue wifi light.
Understood.
With the line endings of YAT changed we will be able to see the end of the diagnostic report which contains the wifi section. Without that we're kind of blind as to what's going on.
Can you also include the contents of config.g from the /sys folder on the SD card?
That contains your current configuration and what you will be editing going forward. It can be edited from the web interface once you can get reliably connected to it. Until then it may require pulling the SD card unfortunately.
Sure, when you set aside your assumptions as start doing as suggested. The output from M587 and all of the M122 output please.
M122
M587<CR>
M587: Failed to retrieve network list
ok
M122 <CR>
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
Board ID: 08DGM-9T6BU-FG3SN-6J9F4-3SD6R-TUZHF
Used output buffers: 1 of 24 (1 max)
Static ram: 25680
Dynamic ram: 93244 of which 0 recycled
Exception stack ram used: 304
Never used ram: 11844
Tasks: NETWORK(ready,1876) HEAT(blocked,1236) MAIN(running,4184) IDLE(ready,160)
Owned mutexes:
Last reset 00:00:55 ago, cause: power up
Last software reset at 2019-09-02 22:49, reason: User, spinning module GCodes, available RAM 11844 bytes (slot 3)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04433000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
Error status: 0
Free file entries: 10
MCU temperature: min 26.5, current 30.2, max 30.5
Supply voltage: min 0.6, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
Driver 0: ok, SG min/max not available
Driver 1: ok, SG min/max not available
Driver 2: ok, SG min/max not available
Driver 3: ok, SG min/max not available
Driver 4: ok, SG min/max not available
Cache data hit count 101580001
Slowest loop: 0.16ms; fastest: 0.06ms
Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
=== DDARing ===
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is ready with "M122 " in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 0.15ms; fastest: 0.00ms
HTTP sessions: 0 of 8- WiFi -
Network state is disabled
WiFi module is disabled
Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485
m552 s0
ok
WiFi module started
m122
Used output buffers: 1 of 24 (10 max)
Static ram: 25680
Dynamic ram: 93288 of which 0 recycled
Never used ram: 11800
Tasks: NETWORK(ready,1656) HEAT(blocked,1236) MAIN(running,3768) IDLE(ready,160)
Owned mutexes:
Last reset 00:04:05 ago, cause: power up
Error status: 0
MCU temperature: min 30.2, current 31.6, max 31.7
Supply voltage: min 1.7, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
Cache data hit count 461723815
Slowest loop: 99.34ms; fastest: 0.06ms
=== DDARing ===
Segments left: 0
serial is ready with "m122" in state(s) 0
=== Network ===
Slowest loop: 1.22ms; fastest: 0.00ms
HTTP sessions: 0 of 8 - WiFi -
Network state is running
WiFi module is idle
WiFi firmware version 1.23
WiFi MAC address 84:f3:eb:41:4e:f8
WiFi Vcc 3.39, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 30176
ok
m587
Remembered networks:
Spiffy IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
ok
M587 s"Spiffy" p"Password1"
ok
M587
ok
m122
Static ram: 25680
Tasks: NETWORK(ready,1656) HEAT(blocked,1236) MAIN(running,3756) IDLE(ready,160)
Owned mutexes:
Last reset 00:05:15 ago, cause: power up
Error status: 0
MCU temperature: min 31.4, current 32.3, max 32.4
Cache data hit count 602028484
Slowest loop: 0.33ms; fastest: 0.06ms
=== DDARing ===
Segments left: 0
=== Network ===
Slowest loop: 0.14ms; fastest: 0.00ms
WiFi module is idle
ok
- WiFi -
Rebooting device.....
m122
Static ram: 25680
Exception stack ram used: 244
Never used ram: 11904
Tasks: NETWORK(ready,1876) HEAT(blocked,1236) MAIN(running,4468) IDLE(ready,160)
Owned mutexes:
Last reset 00:00:37 ago, cause: power up
Error status: 0
MCU temperature: min 31.1, current 33.0, max 33.2
Supply voltage: min 1.5, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
Cache data hit count 68946894
Slowest loop: 0.15ms; fastest: 0.06ms
=== DDARing ===
Segments left: 0
=== Network ===
ok
Config.g
; generated by RepRapFirmware Configuration Tool v2.0.0 on Sun Sep 01 2019 16:01:34 GMT+0100 (British Summer Time); General preferences
M550 P"CR10" ; set printer name
M911 S10 R11 P'M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000' ; set voltage thresholds and actions to run on power loss; Drives
M350Z16 I0 ; configure microstepping without interpolation
M350X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
M906 X950 Y950 Z950 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X300 Y300 Z400 S0 ; set axis maxima; Endstops
M574 X1 Y1 Z1 S1 ; set active high endstops
M574 Z1 S3 ; set endstops controlled by motor stall detection; Z-Probe
M558 P5 H5 F0 T6000 ; set Z probe type to switch and the dive height + speeds
G31 P0 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M106 P0 S0 I0 F500 H T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P1 S1 I0 F500 H-1 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P2 S1 I0 F500 H-1 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Network
M586 P2 S0 ; disable Telnet; Custom settings are not defined
m115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b2
okAnything else?
- WiFi -
Does it make any difference using
M552 S1 P"Spiffy"
if you have a look at the markdown page, especially the code block, you'll be able to make the output a lot easier to read
https://commonmark.org/help/ -
From the console can you please send the following:
M552 S0 M588 S"*" M587 s"Spiffy" p"Password1" M552 S1 M122
This will take the wifi module to idle, clear all saved SSIDs, re-add your SSID, and re-enable the module and hopefully connect. Then the diagnostic should show the connection stats.
How far away is the access point from the printer?
Do your other devices get a strong signal in that area?
Is the access point 2.4Ghz? 5Ghz won't work. -
m122
Static ram: 25680
Tasks: NETWORK(ready,1244) HEAT(blocked,1236) MAIN(running,4468) IDLE(ready,160)
Owned mutexes:
Last reset 00:12:58 ago, cause: power up
Error status: 0
MCU temperature: min 32.6, current 35.4, max 35.5
Cache data hit count 2516579683
Slowest loop: 99.70ms; fastest: 0.06ms
=== DDARing ===
Segments left: 0
=== Network ===
Slowest loop: 15.36ms; fastest: 0.00ms
WiFi Vcc 3.39, reset reason Exception
WiFi flash size 4194304, free heap 23696
WiFi IP address 192.168.0.19
WiFi signal strength -60dBm, reconnections 0, sleep mode modem
ok
So now my problem is still powering down and then moving the board to my printer. wifi remains disabled
- WiFi -
I suspect this is the problem. -60 is already on the low end. When you move to the printer location I suspect the signal is too weak for it to connect.
You may find this helpful: https://duet3d.dozuki.com/Wiki/WiFi_disconnections_and_AJAX_timeout_errors
Thanks but i think you misunderstood. the wifi is disabled after power cycle.
Can you check this?
I don't think it's disabled, I think it's trying to find an SSID and cannot, so it stops.
It's working and connecting reliably when you're powered via USB, correct?
If you have M552 S1 in config.g and you do not also have another M552 command in there that cancels it, then when it has finished running config.g is will do a site scan and connect to the strongest network that you have told it about via M587. So:
Make sure there is exactly one M552 command in config.g and it has parameter S1.
Retype that line in case it contains hidden characters.
When you start the Duet, look out for the blue LED on the WiFi module flashing.
If it tries to connect but fails, the state falls back to Idle, not Disabled. State Disabled is what you get if you never used M552 to enable the WiFi module, or if you send M552 S-1.
@phaedrux At my desk, i power cycle the board and the wifi doesnt light up. check the config and wifi disabled.
there in lies my problem.
Thanks for all the help, ive managed to resolve this issue myself. Nothing like recompiling the Config.g from scratch.
I assume you mean run through the configurator again to get a new set of configs?
It's not so complicated once you're connected. The config.g is just a plain text file with gcode commands. You can edit it right from the web interface.
Something i noticed which may or may not have a bearing on things, I thought that in the config.g that the network section was always generally at the start of the file, in this gents case it was well down his list.
So does the duet execute the g code in the order in which its in the file or is it irrelevant and you can put the g code in any order at all ?
