    Wifi/Web Console issues
    2.6k
      T3P3Tony administrators @A Former User
      @bearer good point, or at least send both.
      • Shaunundefined
        Shaun @T3P3Tony
        @t3p3tony Let me clarify, WIFI now connects when i run M552 S0 then M552 S1. Webconsole also responds pretty quickly.
        When moving the board to the printer i power it without connecting it or placing it into anything. Simply laying it down in the foam from inside the shipping box. The wifi blue light doesnt even blink once.
        Signal strength isnt a problem, i checked the strength many times as i use to have the Pi there without any issues.
        Do you have any suggestions in getting the wifi fired up without having to send code to the board via YAT
        • Shaunundefined
          Shaun @A Former User
          @bearer I hear you, but i only managed to get a stable connection once i added her SID and Password to Config.json so its clearly reading from it. I dont have those details in the Config.g.
          • Shaunundefined
            Shaun @T3P3Tony
            @t3p3tony said in Wifi/Web Console issues:
            @Shaun I just see you have posted part of M122 above. If you set YAT to use the correct line endings you will get nicer output that wont be truncated.
            Go to Terminal/Settings/Text Settings and change the EOL sequence to <LF>.
            Noted
              A Former User @Shaun
              @shaun said in Wifi/Web Console issues:
              No.
              yes, thats correct, after you enter the details with M587 it is stored in the wifi modules flash memory. which is part of the reason the documentations tells you not to use M587 (to store wifi details) in config.g, the wifi module is not enabled at the time config.g is executed and saving the wifi details every time would put unnecessary wear on the wifi flash memory.
              Shaunundefined 1 Reply Last reply Reply Quote 1
              • Shaunundefined
                @bearer said in Wifi/Web Console issues:
                No.
                OK, so could you help me figure out why the wifi is not even coming on when i power the board? At which point is M552 S0 read from Flash?
                Phaedruxundefined A Former User? 2 Replies Last reply Reply Quote 0
                • MrsDelishundefined
                  MrsDelish
                  M552 S0 = turn off networking, you do not want that in your config.g if you want networking.
                  config.g that contains this should connect if a ssid and pw is previously set.
                  M552 S1 ; enable network
                  M586 P0 S1 ; enable HTTP
                  M586 P1 S0 ; disable FTP
                  M586 P2 S0 ; disable Telnet
                  gcode wiki M552
                    Phaedrux Moderator @Shaun
                    What is the power supply? Do the rest of the lights and everything else come on?
                    When it is powered by the PSU, can you connect via USB as well and send M122 with the correct YAT line endings and report what the diagnostic replies with?
                    • Shaunundefined
                      Shaun @Phaedrux
                      @phaedrux said in Wifi/Web Console issues:
                      Ill get this when i get home, PSU is as per vendor recommendations.
                      Red light by the USB power port, 2 more lights to the left of that. No blue wifi light.
                        Understood.
                        With the line endings of YAT changed we will be able to see the end of the diagnostic report which contains the wifi section. Without that we're kind of blind as to what's going on.
                        Can you also include the contents of config.g from the /sys folder on the SD card?
                        That contains your current configuration and what you will be editing going forward. It can be edited from the web interface once you can get reliably connected to it. Until then it may require pulling the SD card unfortunately.
                          Sure, when you set aside your assumptions as start doing as suggested. The output from M587 and all of the M122 output please.
                          Shaunundefined 1 Reply Last reply Reply Quote 0
                          • Shaunundefined
                            M122
                            M587<CR>
                            M587: Failed to retrieve network list
                            ok
                            M122 <CR>
                            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
                            Board ID: 08DGM-9T6BU-FG3SN-6J9F4-3SD6R-TUZHF
                            Used output buffers: 1 of 24 (1 max)
                            Static ram: 25680
                            Dynamic ram: 93244 of which 0 recycled
                            Exception stack ram used: 304
                            Never used ram: 11844
                            Tasks: NETWORK(ready,1876) HEAT(blocked,1236) MAIN(running,4184) IDLE(ready,160)
                            Owned mutexes:
                            Last reset 00:00:55 ago, cause: power up
                            Last software reset at 2019-09-02 22:49, reason: User, spinning module GCodes, available RAM 11844 bytes (slot 3)
                            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04433000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                            Error status: 0
                            Free file entries: 10
                            MCU temperature: min 26.5, current 30.2, max 30.5
                            Supply voltage: min 0.6, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
                            Driver 0: ok, SG min/max not available
                            Driver 1: ok, SG min/max not available
                            Driver 2: ok, SG min/max not available
                            Driver 3: ok, SG min/max not available
                            Driver 4: ok, SG min/max not available
                            Cache data hit count 101580001
                            Slowest loop: 0.16ms; fastest: 0.06ms
                            Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                            === DDARing ===
                            Segments left: 0
                            Movement lock held by null
                            http is idle in state(s) 0
                            telnet is idle in state(s) 0
                            file is idle in state(s) 0
                            serial is ready with "M122 " in state(s) 0
                            aux is idle in state(s) 0
                            daemon is idle in state(s) 0
                            queue is idle in state(s) 0
                            Code queue is empty.
                            === Network ===
                            Slowest loop: 0.15ms; fastest: 0.00ms
                            HTTP sessions: 0 of 8
                            • WiFi -
                              Network state is disabled
                              WiFi module is disabled
                              Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485
                              m552 s0
                              ok
                              WiFi module started
                              m122
                              Used output buffers: 1 of 24 (10 max)
                              Static ram: 25680
                              Dynamic ram: 93288 of which 0 recycled
                              Never used ram: 11800
                              Tasks: NETWORK(ready,1656) HEAT(blocked,1236) MAIN(running,3768) IDLE(ready,160)
                              Owned mutexes:
                              Last reset 00:04:05 ago, cause: power up
                              Error status: 0
                              MCU temperature: min 30.2, current 31.6, max 31.7
                              Supply voltage: min 1.7, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
                              Cache data hit count 461723815
                              Slowest loop: 99.34ms; fastest: 0.06ms
                              === DDARing ===
                              Segments left: 0
                              serial is ready with "m122" in state(s) 0
                              === Network ===
                              Slowest loop: 1.22ms; fastest: 0.00ms
                            • WiFi -
                              Network state is running
                              WiFi module is idle
                              WiFi firmware version 1.23
                              WiFi MAC address 84:f3:eb:41:4e:f8
                              WiFi Vcc 3.39, reset reason Turned on by main processor
                              WiFi flash size 4194304, free heap 30176
                              ok
                              m587
                              Remembered networks:
                              Spiffy IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
                              ok
                              M587 s"Spiffy" p"Password1"
                              ok
                              M587
                              ok
                              m122
                              Static ram: 25680
                              Tasks: NETWORK(ready,1656) HEAT(blocked,1236) MAIN(running,3756) IDLE(ready,160)
                              Owned mutexes:
                              Last reset 00:05:15 ago, cause: power up
                              Error status: 0
                              MCU temperature: min 31.4, current 32.3, max 32.4
                              Cache data hit count 602028484
                              Slowest loop: 0.33ms; fastest: 0.06ms
                              === DDARing ===
                              Segments left: 0
                              === Network ===
                              Slowest loop: 0.14ms; fastest: 0.00ms
                            • WiFi -
                              WiFi module is idle
                              ok
                            • Shaunundefined
                              Shaun
                              Rebooting device.....
                              m122
                              Static ram: 25680
                              Exception stack ram used: 244
                              Never used ram: 11904
                              Tasks: NETWORK(ready,1876) HEAT(blocked,1236) MAIN(running,4468) IDLE(ready,160)
                              Owned mutexes:
                              Last reset 00:00:37 ago, cause: power up
                              Error status: 0
                              MCU temperature: min 31.1, current 33.0, max 33.2
                              Supply voltage: min 1.5, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
                              Cache data hit count 68946894
                              Slowest loop: 0.15ms; fastest: 0.06ms
                              === DDARing ===
                              Segments left: 0
                              === Network ===
                              • WiFi -
                                ok
                              Config.g
                              ; generated by RepRapFirmware Configuration Tool v2.0.0 on Sun Sep 01 2019 16:01:34 GMT+0100 (British Summer Time)
                              M550 P"CR10" ; set printer name
                              M911 S10 R11 P'M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000' ; set voltage thresholds and actions to run on power loss
                              M350Z16 I0 ; configure microstepping without interpolation
                              M350X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation
                              M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
                              M906 X950 Y950 Z950 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
                              M84 S30 ; Set idle timeout
                              M208 X300 Y300 Z400 S0 ; set axis maxima
                              M574 X1 Y1 Z1 S1 ; set active high endstops
                              M574 Z1 S3 ; set endstops controlled by motor stall detection
                              M558 P5 H5 F0 T6000 ; set Z probe type to switch and the dive height + speeds
                              G31 P0 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
                              M106 P0 S0 I0 F500 H T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                              M106 P1 S1 I0 F500 H-1 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
                              M106 P2 S1 I0 F500 H-1 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
                              m115
                              FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b2
                              ok
                              Anything else?
                                A Former User
                                Does it make any difference using M552 S1 P"Spiffy"
                                if you have a look at the markdown page, especially the code block, you'll be able to make the output a lot easier to read
                                https://commonmark.org/help/
                                  From the console can you please send the following:
                                  M552 S0
                                  M588 S"*"
                                  M552 S1
                                  M122
                                  This will take the wifi module to idle, clear all saved SSIDs, re-add your SSID, and re-enable the module and hopefully connect. Then the diagnostic should show the connection stats.
                                  How far away is the access point from the printer?
                                  Do your other devices get a strong signal in that area?
                                  Is the access point 2.4Ghz? 5Ghz won't work.
                                  • Shaunundefined
                                    Shaun
                                    m122
                                    Static ram: 25680
                                    Tasks: NETWORK(ready,1244) HEAT(blocked,1236) MAIN(running,4468) IDLE(ready,160)
                                    Owned mutexes:
                                    Last reset 00:12:58 ago, cause: power up
                                    Error status: 0
                                    MCU temperature: min 32.6, current 35.4, max 35.5
                                    Cache data hit count 2516579683
                                    Slowest loop: 99.70ms; fastest: 0.06ms
                                    === DDARing ===
                                    Segments left: 0
                                    === Network ===
                                    Slowest loop: 15.36ms; fastest: 0.00ms
                                    • WiFi -
                                      WiFi Vcc 3.39, reset reason Exception
                                      WiFi flash size 4194304, free heap 23696
                                      WiFi IP address 192.168.0.19
                                      WiFi signal strength -60dBm, reconnections 0, sleep mode modem
                                      ok
                                    So now my problem is still powering down and then moving the board to my printer. wifi remains disabled
                                      I suspect this is the problem. -60 is already on the low end. When you move to the printer location I suspect the signal is too weak for it to connect.
                                      You may find this helpful: https://duet3d.dozuki.com/Wiki/WiFi_disconnections_and_AJAX_timeout_errors
                                      • Shaunundefined
                                        Shaun @Phaedrux
                                        @phaedrux
                                        Thanks but i think you misunderstood. the wifi is disabled after power cycle.
                                          Can you check this?
                                            I don't think it's disabled, I think it's trying to find an SSID and cannot, so it stops.
                                            It's working and connecting reliably when you're powered via USB, correct?
