    Maestro config not being executed on startup
    874
    • JoshLundefined
      JoshL
      I get these two errors:
      Error: M911: No power fail script provided
      Error: G0/G1: insufficient axes homed
        A Former User
        not too familiar with how the firmware handles errors, but does it make a difference to move the network config block up to over the M911 command? or commenting out the offending lines with a ;
        • JoshLundefined
          JoshL
          Ah yep so I got rid of the M911 line from the config and that's fixed it. The error must have been stopping the Duet from reading the rest of the config file. Thanks heaps for the help.
            A Former User
            fyi https://forum.duet3d.com/topic/7773/forum-feature-mark-as-question-solved/
              droftarts administrators
              @joshl said in Maestro config not being executed on startup:
              M911 S21 R23 P'M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000' ; set voltage thresholds and actions to run on power loss
              I can't see anything particularly wrong with this line, except you've used single quotes rather than double quotes. However, you probably need to set up the sys/resurrect-prologue.g file.
              See here for more details: https://duet3d.dozuki.com/Wiki/Setting_up_to_resume_a_print_after_a_power_failure
              themelleundefined 1 Reply Last reply Reply Quote 0
              • themelleundefined
                themelle @droftarts
                @droftarts said in Maestro config not being executed on startup:
                According to https://duet3d.dozuki.com/Wiki/Gcode#Section_M911_Configure_auto_save_on_loss_of_power you need to use double quotes for the P parameter.
                The message Error: G0/G1: insufficient axes homed leads me to think that the single-quoted P parameter command line from the M911command is being interpreted and executed at config.g runtime as there is a G1 command in there.
                  A Former User @themelle
                  @themelle that seems to be the explanation, I was wondering where the G0/G1 line was.
                    A Former User @JoshL
                    including going through RepRap firmware configuration tool to generate a config file.
                    Did the RRF configurator generate the M911 line with single quotes? If so that should probably be filed as a bug
                      A Former User @A Former User
                      @bearer said in Maestro config not being executed on startup:
                      it is a bug @chrishamm 👆
                        A Former User
                        I would move the whole network section of g code to almost the top of the config.g file so that the network gets started first...
                          A Former User
                          @calvinx said in Maestro config not being executed on startup:
                          seems it was further up earlier, but changed recently, and the quotes bug was introduced at the same time. wonder if that is the reason for the sudden increase in threads with network issues.
                          anyways, hopefully the quotes will be fixed and the network moved back to the top shortly.
                            The position of the network command shouldn't matter, but the wrong quotes for the power loss recovery halting the execution of the config certainly is a problem.
                            Oddly, if the network section hadn't been moved down it would have been much harder to spot the wrong quote problem.
                              A Former User @Phaedrux
                              @phaedrux said in Maestro config not being executed on startup:
                              for users who find it difficult to use the serial terminal it does matter when errors are introduced, further complicated by the missmatch between default EOL in the firmware and the recommended terminal.
                              if the network were given "priority" at the top, and the web interface and/or paneldue would indicate that config.g was terminated due to an error everyone wins.
                                @bearer No argument there.
                                One helpful trick for issues like this is to send M98 Pconfig.g which will re-execute config.g as a macro, and any error messages will be echoed back, unlike at startup. I do wish that any startup errors would get punted to the console as well, but currently that's not the case.
                                • MrsDelishundefined
                                  MrsDelish
                                  I find Arduino IDE serial monitor really quick and easy to use to talk to Duets and other boards, it has a drop down menu to set line endings and baud rate on the serial window.
