    PID Tuning Number of Cycles
    2.1k
    • GeorgeMundefined
      GeorgeM
      Also I had the bed at printing temp and near the nozzle.
        So the bed was powered when tuning the hotend?
        Try without and see if the values are much different.
        Also, are you tuning from cold state?
        • GeorgeMundefined
          GeorgeM
          Yes from a cold state. When this print is done I will try again without the bed powered.
            If the results are the same you could experiment with reducing the dead time. It's at 1.1 in the value you provided. Try 2. I think that may help smooth out the waves.
            • GeorgeMundefined
              GeorgeM
              Well I went through a number of tunings today. I have to set the PWM to .7 or lower to get rid of any waves. Also I decided to use the M500 command and use the config-override.g file to eliminate any transcribing errors to the config.g.
                What is the heater cartridge?
                GeorgeMundefined 1 Reply Last reply Reply Quote 0
                • GeorgeMundefined
                  GeorgeM @Phaedrux
                  @phaedrux 24v E3d
                    What wattage?
                      T3P3Tony administrators
                      @GeorgeM I note that you have "D10" as part of the M307 command. is that what M303 gave you as an output?
                      Also check you config-override.g to see if there is not a different M307 in there
                      (note edited as I highlighed B0 instead of D10 originally)
                      • GeorgeMundefined
                        GeorgeM @T3P3Tony
                        @t3p3tony I dont remember now if that was from the M307 command or from the documentation.
                        • GeorgeMundefined
                          GeorgeM @Phaedrux
                          @phaedrux Don't know. How/where would I find that?
                            @GeorgeM please run M303 again and post the results
                            https://duet3d.dozuki.com/Wiki/Gcode#Section_M303_Run_heater_tuning
                            You should read the documentation here that was linked already:
                            https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
                            It looks form the original M307 you posted that the tuning value is not what you had configured
                            GeorgeMundefined 2 Replies Last reply Reply Quote 0
                            • GeorgeMundefined
                              GeorgeM @T3P3Tony
                              @t3p3tony I'm not home currently. Will redo tomorrow.
                              • GeorgeMundefined
                                GeorgeM @T3P3Tony
                                @T3P3Tony Ok, I'm back at it again. It looks like things have gotten confusing so I would like to step back and iterate what my setup is.
                                My printer is a BLV Cube build ala https://www.thingiverse.com/thing:3382718
                                Equipment is:
                                24v power supply
                                Duet 2 WiFi
                                Zesty Nimble extruder
                                Genuine E3D V6 All Metal Hotend with 24v heater (measures 14.4 on resistance)
                                Tests conducted with silicone sock on and parts fan on.
                                First test with PWM at 1
                                8:07:05 AMM307 H1
                                Heater 1 model: gain 549.0, time constant 262.4, dead time 8.0, max PWM 1.00, calibration voltage 23.7, mode PID, inverted no, frequency default
                                Computed PID parameters for setpoint change: P10.7, I0.234, D59.7
                                Computed PID parameters for load change: P10.
                                8:04:31 AMWarning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 573C.
                                Auto tune heater 1 completed in 395 sec
                                Use M307 H1 to see the result, or M500 to save the result in config-override.g
                                8:00:29 AMAuto tune phase 3, peak temperature was 259.6
                                8:00:21 AMAuto tune phase 2, heater off
                                7:58:01 AMAuto tune phase 1, heater on
                                7:57:55 AMM303 H1 S250 P1
                                Second test with PWM at .8
                                Heater 1 model: gain 285.7, time constant 172.4, dead time 3.9, max PWM 0.80, calibration voltage 23.8, mode PID, inverted no, frequency default
                                Computed PID parameters for setpoint change: P27.6, I1.066, D75.4
                                Computed PID parameters for load change: P27.
                                8:44:00 AMAuto tune heater 1 completed in 447 sec
                                8:41:22 AMAuto tune phase 3, peak temperature was 252.6
                                8:41:18 AMAuto tune phase 2, heater off
                                8:36:38 AMAuto tune phase 1, heater on
                                8:36:33 AMM303 H1 S250 P0.8
                                Auto tuning heater 1 using target temperature 250.0°C and PWM 0.80 - do not leave printer unattended
                                Third test with PWM at .7
                                eater 1 model: gain 234.7, time constant 160.1, dead time 6.4, max PWM 0.70, calibration voltage 23.7, mode PID, inverted no, frequency default
                                Computed PID parameters for setpoint change: P19.0, I0.595, D85.2
                                Computed PID parameters for load change: P19.
                                9:01:38 AMM307
                                9:01:12 AMM307
                                8:59:27 AMAuto tune heater 1 completed in 573 sec
                                8:56:59 AMAuto tune phase 3, peak temperature was 251.0
                                8:56:55 AMAuto tune phase 2, heater off
                                8:49:59 AMAuto tune phase 1, heater on
                                8:49:53 AMM303 H1 S250 P0.7
                                Auto tuning heater 1 using target temperature 250.0°C and PWM 0.70 - do not leave printer unattended
                                Only after running with the results of PWM 0.7 was the temperature stable. Others showed continuous fluctuations.
                                Results of each test were saved with M500.
                                Results are saved in config-override.g
                                Nothing is saved in config.g
                                M501 is called out at end of config.g
                                Here is config.g
                                ; generated by RepRapFirmware Configuration Tool v2 on Wed Aug 14 2019 07:35:06 GMT-0600 (Mountain Daylight Time)
                                M667 S1 ; Select CoreXY mode
                                M550 P"BLV Cube" ; Set machine name
                                M552 S1 ; Enable network
                                M586 P0 S1 ; Enable HTTP
                                M586 P1 S0 ; Disable FTP
                                M586 P2 S0 ; Disable Telnet
                                M569 P0 S0 ; Drive 0 X goes backwards
                                M569 P1 S0 ; Drive 1 Y goes backwards
                                M569 P2 S0 ; Drive 2 Z goes backwards
                                M569 P3 S1 ; Drive 3 E1 goes forward
                                M569 P4 S0 ; Drive 4 U goes backward
                                M92 X100.54 Y100.54 Z400.21 U400.21 E2892.00 ; Set steps per mm
                                M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation
                                M350 E16 I0 ; Configure microstepping witout inerpolation
                                M566 X400.00 Y400.00 Z100.00 U100 E80.00 ; Set maximum instantaneous speed changes (mm/min) was 480 for x and y
                                M203 X10000.00 Y10000.00 Z6000.00 U6000.00 E8000.00 ; Set maximum speeds (mm/min)
                                M201 X600.00 Y600.00 Z30.00 U30.00 E100.00 ; Set accelerations (mm/s^2) was 800 for x and y
                                M906 X1200.00 Y1200.00 Z800.00 U800.00 E500.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
                                M584 X0 Y1 Z2:4 ; two Z motors connected to driver outputs Z and E1
                                M671 X-20:310 Y0:0 S2 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                                M208 X-5:305 Y0:300 ; X carriage moves from -5 to 305, Y bed goes from 0 to 300
                                M84 S30 ; Set idle timeout
                                M208 X-25 Y-30 Z0 S1 ; Set axis minima
                                M208 X300 Y300 Z300 S0 ; Set axis maxima
                                M574 X1 Y1 S1 ; Set active high endstops
                                M574 Z1 S2 ; Set endstops controlled by probe
                                M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
                                M558 P9 H5 F120 S.02 T7000 ; Set Z probe type to bltouch and the dive height + speeds
                                ;M558 P9 H5 F120 T7000
                                G31 P500 X30 Y-10 Z1.5 ; Set Z probe trigger value, offset and trigger height
                                M557 X15:285 Y10:275 P4 ; Define mesh grid
                                M305 P1 T100000 B4725 C7.06e-8 ; Set thermistor + ADC parameters for heater 1
                                M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                M106 P1 S0 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                M563 P0 D0 H1 ; Define tool 0
                                M501 ; Load saved parameters from non-volatile memory
                                Here is config-override.g
                                ; config-override.g file generated in response to M500 at 2019-09-09 09:02
                                ; Heater model parameters
                                M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B0
                                M307 H1 A234.7 C160.1 D6.4 S0.70 V23.7 B0
                                M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                G10 L2 P1 X0.00 Y0.00 Z0.00
                                G10 L2 P2 X0.00 Y0.00 Z0.00
                                G10 L2 P3 X0.00 Y0.00 Z0.00
                                G10 L2 P4 X0.00 Y0.00 Z0.00
                                G10 L2 P5 X0.00 Y0.00 Z0.00
                                G10 L2 P6 X0.00 Y0.00 Z0.00
                                G10 L2 P7 X0.00 Y0.00 Z0.00
                                G10 L2 P8 X0.00 Y0.00 Z0.00
                                G10 L2 P9 X0.00 Y0.00 Z0.00
                                  @GeorgeM thanks - that setup should work without reducing PWM. When @dc42 gets a chance maybe he can add to this.
                                  BTW -its not related but you should not have M587 in your config.g
                                  GeorgeMundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                  • GeorgeMundefined
                                    GeorgeM @T3P3Tony
                                    @T3P3Tony Thanks, I missed that.
                                      dc42 administrators @T3P3Tony
                                      @t3p3tony said in PID Tuning Number of Cycles:
                                      Yes, that should work. If you send M307 H0 from the GCode console, it should show that it is using the heater 0 parameters that were saved to config-override.g. Similarly for M307 H1.
                                        T3P3Tony administrators @dc42
                                        @dc42 that part is working. the issue is the oscillation with the results from M303 with a PWM value of >0.7
                                        @GeorgeM it would be helpful if you could post some images of the temperature graph to show this oscillation at PWM 1 and 0.7
                                          If the temperature oscillates, that normally means that tuning has under-measured the M307 D parameter. It can be fixed by increasing the D parameter. Try a 50% increase.
                                          • GeorgeMundefined
                                            GeorgeM
                                            Well, just like going to the auto mechanic, today I disasembled the hotend, cleaned it up, put it back together and redid the PID with PWM of 1. I still got the error of overheating but in doing my first test print the temp seams stable. Only oscillating about .5d.
