    Unable to start up
    762
      So just to confirm, when you had the board out of the printer and connected only to USB terminal you were able to get the wifi module to turn on and connect to the wifi network and get an ip address?
      • Gost101undefined
        Gost101
        Yes, however upon connecting it back to the 3d printer neither the usb terminal or the wifi module work (The blue status light for the wifi module does not status (turn on-solid blue), and the usb is not detected by my PC).
          Do any lights come on when you're connected to the printer PSU?
          Are there perhaps any shorts?
          Can you try with the endstops disconnected?
          • Gost101undefined
            Gost101
            PSU on = LED VIN (Blue) and LED = +5V (Red), while USB =LED +5V (Red) and the LED to the left of the USb terminal (Red), Both PSU and USB = LED VIN (Blue), LED = +5V (Red), and LED to the left of the USb terminal (Red). No shorts. I've trouble shooted all day. ALL wires have to be disconnected. Is it possible that I have a defective board?
              I'm unable to determine that. Perhaps @dc42 will have some insight.
              I can't figure why it would work on the bench, but not work in the printer other than there being a short.
              • Gost101undefined
                Gost101
                lol, this sucks.
                  T3P3Tony administrators @Gost101
                  @gost101 bit of a pain to test but can you try connecting it step by step. If you get it in you printer but with only USB connected and confirm WiFi works, then connect things one at a time and check.
                  I agree with @Phaedrux this sounds like something you are plugging in is causing an issue.
                  • Gost101undefined
                    Gost101
                    Cool beans, increased trouble shooting will start tomorrow later today. I will be back sometime tomorrow with the results.
                    • Gost101undefined
                      Gost101
                      There was a short, on the z stop. However now I will begin troubleshooting as to why the motors are not working.
                        By default motors won't move until they are homed.
                        See here for an example of hardware commissioning steps: https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
