    Anycubic I3 Mega Mod questions
    5.2k
    • pauleddundefined
      pauledd @jay_s_uk
      @jay_s_uk said in Anycubic I3 Mega Mod questions:
      M584
      Okay, so I'll try now two seperate drivers for the Z-axis.
      Z+ stepper (the left one) is plugged into the outer "Z" and I put both
      jumpers back on the inner one. Z- stepper (the right one) is now in E1.
      Endstop Z+ is in Z and Endstop Z- is in E1.
      So I change these commands in my "Drives" section in config.g:
      ;M584 X0 Y1 Z2 E3 ;old
      M584 X0 Y1 Z2:4 E3 ;new
      Now, do I need to change anything else? Or applies "steps per mm , accelerations etc..." automatically to both Z-drivers?
      And do I have to change something in the "endstop" section? It currently
      have this code:
      M574 X1 Y1 Z1 S0
      ----- human being without Windows™ ------
      • pauleddundefined
        pauledd
        Ok, I'll try to follow this guide:
        https://duet3d.dozuki.com/Guide/Independent+Z+motors+and+endstop+switches/18?lang=en
        • pauleddundefined
          pauledd
          Well, this of cause didnt work...
          If I press "Home Z" both Z-Steppers start to move down.
          They both hit the endstop and the right stepper (E1) stops moving
          but the left stepper (plugged in Z) keeps on moving and makes a great
          loud rattling noise. So I immediately press the emergency stop button.
          I checked both enstops (Z & E1), both leds lit on if pressed.
          Under "Machine Properties" the Z endstops shows correctly "yes"
          if pressed. The other E1 endstop is not in that list. Instead I have an E0 endstop which is unconnected on my board...
          My config.g:
          M208 X0 Y0 Z0 U0 S1                          ; set axis minima
          M208 X210 Y210 Z205 U205 S0                    ; set axis maxima
          M584 X0 Y1 Z2:4 U4 E3 P3                          ; set drive mapping
          M574 X1 Y1 Z1 U1 S0                          ; set active low and disabled endstops
          G90                                       ; send absolute coordinates...
          M83                                       ; ...but relative extruder moves
          M550 P"Pauls Duet"                        ; set printer name
          M552 S1                                   ; enable network
          M586 P0 S1                                ; enable HTTP
          M586 P1 S0                                ; disable FTP
          M586 P2 S1                                ; enable Telnet
          M569 P0 S0                                ; physical drive 0 goes backwards
          M569 P1 S0                                ; physical drive 1 goes backwards
          M569 P2 S1                                ; physical drive 2 goes forwards
          M569 P3 S1                                ; physical drive 3 goes forwards
          M569 P4 S1				  ; Z- physical drive 4 goes forwards
          M350 X16 Y16 Z16 U16 E16 I1                   ; configure microstepping with interpolation
          M92 X80.00 Y80.00 Z400.00 U400.00 E92.60          ; set steps per mm
          M566 X900.00 Y900.00 Z12.00 Z12.00  E120.00       ; set maximum instantaneous speed changes (mm/min)
          M203 X30000.00 Y30000.00 Z360.00 U360.00 E1200.00 ; set maximum speeds (mm/min)
          M201 X8000.00 Y8000.00 Z50.00 U50.00 E250.00     ; set accelerations (mm/s^2)
          M906 X1200 Y1200 Z1200 U1200 E1200 I30          ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                   ; Set idle timeout
          M558 P0 H40 F120 T3000                    ; disable Z probe but set dive height, probe speed and travel speed
          M557 X15:210 Y15:195 S20                  ; define mesh grid
          M305 P0 T100000 B4725 C7.060000e-8 R4700  ; set thermistor + ADC parameters for heater 0
          M143 H0 S90                               ; set temperature limit for heater 0 to 90C
          M305 P1 T100000 B4725 C7.060000e-8 R4700  ; set thermistor + ADC parameters for heater 1
          M143 H1 S245                              ; set temperature limit for heater 1 to 245C
          M106 P0 S0 I0 F500 H-1                    ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P1 S1 I0 F500 H1 T45                 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
          M563 P0 D0 H1 F0                          ; define tool 0
          G10 P0 X0 Y0 Z0                           ; set tool 0 axis offsets
          G10 P0 R0 S0                              ; set initial tool 0 active and standby temperatures to 0C
          ; Custom settings
          M552 S1
          My homeall.g
          G1 Z30 F3000 H2     	; lift Z relative to current position
          G1 X-215 Y-215 F1800 H1 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 X5 Y5 F3000          ; go back a few mm
          G1 X-215 Y-215 F360 H1  ; move slowly to X and Y axis endstops once more (second pass)
          M98 homez.g
          My homez.g
          ; split Z motor control to Z and U
          ; for it to work we have to show U (param P4) in the UI
          M584 Z2 U4 P4
          ; Move Z and U  down until the switches triggers
          G1 Z-205 U-205 F1000 H1
          ; back to combined axes and hidden U
          M584 Z2:4 P3
          ; Back to absolute positioning
          G90
          ; Tell the firmware where we are
          G92 Z0
          ; lift Z after probing
          G91
          G1 Z10 F1000
          G90
          • grizewaldundefined
            grizewald
            If you have axes X, Y and Z and then you create a fourth axis, the end stop for that fourth axis will be the first unused end stop in order. So, if you don't have your second Z end stop connected to the E0 end stop input, then you should connect it there.
            That's why it's showing you an E0 end stop.
            • pauleddundefined
              pauledd
              @grizewald thanks 👍
              Works now!
              What I did:
              • replugged Z(-) stepper into E0 and Z-endstop into E0
              config.g:
              • moving the M584 code above M208 code
              • changed M584 to M584 X0 Y1 Z2:3 U3 E4 P3
              • corrected M566 to M566 X900.00 Y900.00 Z12.00 U12.00 E120.00
              homeall.g:
              • changed M98 to M98 Phomez.g
              homez.g:
              G1 Z10 F3000 H2   ; lift Z relative 10mm
              M584 Z2:3 U3 P4
              G1 Z-205 U-205 F100 H1
              M584 Z2:3 U3 P3
              G90
              G92 Z0
              G91
              G1 Z10 F1000
              G90
              Tomorrow I have the fans on my list ☺
                grizewald
                Great! You're making good progress.
                It doesn't matter if you had the second Z motor in E1 or E0, just that you moved the end stop to the next free one in order. It's actually simpler to leave the first extruder in E0 and put the second Z motor in E1 as the firmware expects that you will use E0 for the first extruder.
                In the end though, it doesn't really matter, as long as you describe everything correctly for the firmware. It certainly beats re-compiling and flashing firmware every time you want to make a configuration change!
                • pauleddundefined
                  pauledd
                  Fans are workin!
                  Of cause I forgot to put the V_FAN jumper on V_IN as I wondered
                  why nothing moves...
                  Just for those who stew over how to connect the Anycubic (FAN1) connector, that's how I wired it to the Duet:
                  • pauleddundefined
                    pauledd
                    Hotbed is working!
                    I measured the current to the hotbed alone and that gave me about 14.3A while heating up to 55°C. The 15A fuse got hot to about 65°C but once the bed reached 55°C it cooled down to about 50°C.
                    Should I go for a 20A fuse?
                      jay_s_uk
                      It might be worth thinking about an SSR to control the heated bed so you're not putting all the power through the duet.
                      • pauleddundefined
                        pauledd
                        Yes, I consider that if everything else works perfectly.
                        • pauleddundefined
                          pauledd
                          Hotend works too!
                          But now three steps back to Z-Axis problem 😠
                          Z+ stepper (left) again crashed onto the endstop while doing a Home Z, the Z+ endstop led was even lit up...
                          By the way and quite strange, If I trigger both Z endstopps
                          earlier with my fingers the homing process finishes every time successfully. I'll try to fiddle a bit more, maybe I get behind that mystery. Maybe I twist both endstops to see if one is kind of faulty...
                          • pauleddundefined
                            pauledd
                            Z Axis Problem still not solved but at least the last crash was some time ago... I now monitor the Z endstops IO pins with my oscilloscope to find out if there is something strange if it crashes again.
                            But I couldnt resist to print my first testcube that came out good, with a LOT room 😁 for optimization.
                            Thermal situation while printing the cube:
                            (steppers set to 1.2A)
                            https://www.youtube.com/watch?v=Dd4siLtXD9I&feature=youtu.be
                            • pauleddundefined
                              pauledd
                              I noticed something weird if I do a "HOME-Z". That might be the reason
                              for crashing Z-axis into endstops or my understanding of that process is wrong/incomplete. Just as a side note, I changed the endstops with new ones and checked the endstop signals on my oscilloscope but this did not solve the crashing problem...
                              What I observed:
                              I move the Z axis up a bit so that I can test both endstops without crashing the axis onto them.
                              I press HOME-Z.
                              Z axis moves slowly down. I press the right endstop first, nothing happens, both steppers continue moving until I press the left endstop.
                              (that would produce a crash if endstops are triggered with delay).
                              Now I test HOME-Z again but this time I press left endstop first.
                              As I trigger left endstop the RIGHT stepper stops, the left one keeps moving until I trigger the right endstop.
                              (that would produce a crash too if there is a delay between both endstop triggering...)
                              Is my understanding wrong and this is the intended procedure or is there something wrong?
                              Shouldn't stop the left stepper if I trigger the left endstop and vice versa? Is this maybe a software problem?
                              I also recorded a video, you might have problems to see the steppers stop because they move quite slowly...
                              https://youtu.be/qJ-i4Jgc1WA
                              grizewaldundefined 1 Reply Last reply Reply Quote 0
                                grizewald @pauledd
                                @pauledd How about posting your current config.g and homing files? Also, can you confirm which end stop inputs and motor outputs you have the two Z motors and two Z end stop switches connected to?
                                • pauleddundefined
                                  pauledd
                                  Sure.
                                  Z+ stepper --> Z
                                  Z- stepper --> E0
                                  Z+ endstop --> Z-STOP
                                  Z- endstop --> E0-STOP
                                  config.g:
                                  M584 X0 Y1 Z2:3 U3 E4 P3                          ; set drive mapping
                                  M208 X-115:107.5 Y-107.5:107.5 Z0:205 U0:205
                                  M92 X80.02 Y80.07 Z398.00 U398.00 E92.60          ; set steps per mm
                                  M566 X900.00 Y900.00 Z12.00 U12.00 E120.00       ; set maximum instantaneous speed changes (mm/min)
                                  M203 X4000 Y4000 Z360.00 U360.00 E1200.00 ; set maximum speeds (mm/min)
                                  M201 X2000.00 Y2000.00 Z50.00 U50.00 E250.00     ; set accelerations (mm/s^2)
                                  M84 S10                                   ; Set idle timeout
                                  ; Custom settings
                                  M552 S1
                                  homeall.g:
                                  G1 Z10 F3000 H2     	; lift Z relative to current position
                                  M98 Phomez.g
                                  home.x:
                                  G1 X-215 F1800 H1 ; move quickly to X axis endstop and stop there (first pass)
                                  G1 X5 F1800       ; go back a few mm
                                  G1 X-215 F360 H1  ; move slowly to X axis endstop once more (second pass)
                                  G1 Z-10 F1800 H2  ; lower Z again
                                  G90               ; absolute positioning
                                  home.y:
                                  G1 Y-215 F1800 H1 ; move quickly to Y axis endstop and stop there (first pass)
                                  G1 Y5 F1800       ; go back a few mm
                                  G1 Y-215 F360 H1  ; move slowly to Y axis endstop once more (second pass)
                                  home.z:
                                  M98 Phomex.g	  ; home X first to move head outside
                                  M584 Z2:3 U3 P4
                                  M584 Z2:3 U3 P3
                                  G90
                                  G92 Z0
                                  G91
                                  G1 Z10 F1000
                                  G90
                                    grizewald @pauledd
                                    @pauledd In your homez.g you have:
                                    M584 Z2:3 U3 P4
                                    M584 Z2:3 U3 P3
                                    That should be:
                                    M584 Z2 U3 P4
                                    M584 Z2:3 P3
                                    • pauleddundefined
                                      pauledd
                                      @grizewald
                                      Thanks a lot! I changed the lines to your suggestions.
                                      If I now HOME-Z and I trigger the left endstop the right stepper stops moving and the left stepper keeps moving until I trigger the right endstop.
                                      And vice versa if I trigger the the right endstop first the left stepper stops moving and the right stepper keeps moving until I trigger the left endstop.
                                      So the behaviour is now much more kind of correct but exactly the opposite of what I expected, that is to say left endstop stops left stepper, right endstop stops right stepper. I double checked that I didnt twist the endstops accidentally but they are in the correct socket as drawn in the image above.
                                      Shall I twist them simply to make them behave correctly or is there still somewhere a misconfiguration perceivable
                                      grizewaldundefined 1 Reply Last reply Reply Quote 1
                                        grizewald @pauledd
                                        @pauledd I'd just try swapping them and see if it works!
                                        • pauleddundefined
                                          pauledd
                                          Seems to work, will test extensively tomorrow but I am quite optimistic, thanks so far 👍
                                            grizewald
                                            Good news!
