Single Setup for Duet 3
Maybe post some of the errors?
@4lathe error shown in journal was
Cannot assign requested address /var/run/duet.sock -
@4lathe that came right after
Request starting HTTP/1.1 GET http://127.0.0.1/ -
@4lathe actually others are just a repetition of that error.
@4lathe said in Single Setup for Duet 3:
i think that would suggest you either don't have permissions, or its already in use. did you use
sudo
to run as root? -
@bearer I was logged in as pi when I executed all the dozuki instructions. Many of those use sudo. I did have to add sudo in front of one of the commands though.
@4lathe DSF wont serve anything is the Duet is not connected.
@T3P3Tony ahhhhh. What was that error? Any good way to test that the web server is running?
So I just setup my rpi4 in advance of receiving my duet 3 this week
Ah, as tony says, thats not gonna work. everything depends on DuetControlServer, and it won't start without the Duet3 connected.
@bearer ok so just leave it for now?
yeah, might as well, you won't be able to verify the software anyways.
Although I'm puzzled by the fact that you say you get a HTTP 500 error if the Duet3 isn't connected, which is why I glossed over that bit initially.
@bearer no idea.
@bearer said in Single Setup for Duet 3:
The DuetWebServer will start but it communicates with the DuetControlServer via that /var/run/duet.sock socket which is created by the DuetControlServer and that won't even start if it doesn't get a response from the Duet3 via the SPI bus. So when you access the web server, it responds with a 500 because it can't connect to that socket.
@gtj0 ah, must have changed the behavior at some point then, previously it would terminate right away if started manually without DuetControlServer; and the systemd service won't even start.
Anyways, moot point, gotta wait for the board in any case.
@bearer thx much for the explanation.
