    ferruled connectors
    27
    1.8k
    • Vetiundefined
      Veti
      they are meant to be used with a ferrule crimp tool.
        Phaedrux Moderator @mihaitintea
        @mihaitintea Pliers don't really work very well. Ideally you'd use crimpers meant for ferrules that compress them in all directions to create a tight pinch. Pliers or vice grips can be used, but you risk damaging the wires or creating a poor mechanical crimp.
        https://www.google.com/search?q=crimping+bootlace+ferrules&oq=crimping+boot&aqs=chrome.1.69i57j0l5.6576j0j7&sourceid=chrome&ie=UTF-8
          I use a ferrule crimping tool that I bought from Maplin, who sadly went bust. A search on eBay UK turned up this https://www.ebay.co.uk/itm/Ferrule-Crimper-Cable-Tube-Crimping-Plier-Tool-1200X-Wire-Terminal-Connector-Set/392118937290 and several other listings for similar products.
            A Former User
            There is a wide range of types of crimping tools, while I tend to prefer the sort of D shaped dies the smallest terminals used on the Duet works best with square type of crimpers, and not the type that create extremely serrated sides.
            So the type dc42 links to is probably the best bet.
            • swrightlastundefined
              swrightlast
              Bought a ferrule crimping tool.....problem solved.
              • mihaitinteaundefined
                mihaitintea
                Hello
                Thanks for the answers but I believe I did not make myself very well understood.
                The ferrule connectors that I am talking about are already crimped to the wires, from the factory.
                I was talking about tightening the ferrule connectors into the Duet3D board terminal blocks.
                The out-of-the-box ferrule connector is a hollow tube. One end of this tube is factory-crimped to the wire, and the other end of this tube is free and goes into Duet's terminal blocks.
                Do I tighten this free end of the tube in the Duet board's terminal block until the tube gets mechanically deformed ? Or do I do the flattening myself (e.g., using pliers) until the connector gets shaped as a flat rectangle, and put that flattened end of the connector in Duet's terminal blocks and then tighten those screws ?
                Which way is best ? In time, which of these variants is the most reliable (i.e., does not need to be pereiodically verified and tightened again)
                Thanks and regards
                A Former User? grizewaldundefined 2 Replies Last reply Reply Quote 0
                  A Former User @mihaitintea
                  @mihaitintea said in ferruled connectors:
                  Yes, after crimping the ferrule onto the wire it will have one of several shapes; this goes straight into the terminal block and you tighten down the screw in the terminal according to the torque for the terminal. If that results in the ferrule further deforming then thats ok.
                  • grizewaldundefined
                    grizewald @mihaitintea
                    Here's the kind of ferrule that you should be using:
                    One end is insulated to prevent any chance of a short. The wire is then stripped so that the wire is the same length as the exposed metal part of the ferrule. The wire is inserted into the ferrule and crimped.
                    If the manufacturer didn't strip the wire long enough, so that metal tube is not filled all the way to the end with wire, simply cut the end of the ferrule off with some side cutters so that you can see the crimped wire at the end of the metal tube.
                    Then insert the ferrule into the connector and tighten down the retaining screw while supporting the connector against the force of tightening the screw down.
                      mihaitintea
                      Dear Sir,
                      Thank you so much for the detailed explanation. That kind of knowledge is either gathered from advice as you provided (truly kindly and for free), or hard-learned through -- hopefully not ! -- unfortunate experiences. Fire risk is something that should be taken seriously and thoroughly adviced by whoever is selling whatever may expose buyers to it -- including Amp-consuming devices such as 3D printers.
                      Many thanks and wish you the best.
                      Truly yours
                      Mihai
                      • zaptaundefined
                        zapta @A Former User
                        @bearer said in ferruled connectors:
                        Risky business specifying size according to colour...
                        I use the smallest ferrule that fits the wire.
                          A Former User @zapta
                          @zapta said in ferruled connectors:
                          That works, but if it happens to be orange, telling others to go buy orange ones isn't a failsafe method was the point I was trying to make. While there are a few standards or conventions, its not a single global standard.
                          • zaptaundefined
                            @bearer, that's correct. Sometimes even the same kit has different sizes for the same color
                            https://www.aliexpress.com/item/33040940850.html
