    ferruled connectors
    27
    1.8k
    • swrightlastundefined
      swrightlast
      Could someone post pics of their wired board, in particular where to use the ferruled connectors?
      • Vetiundefined
        Veti
        the ferule connectors are for the cable for voltage in, the hotend and the heated bed
        • PaulHewundefined
          PaulHew
          Basically, anything with a screw down connection
          HTH
            swrightlast
            Thanks for the speedy reply!
              The ferrules are important for the VIN power and heated bed. Less so for the hot end heater connection.
              • Dugeeundefined
                Dugee
                what size are these ferrules? I need to replace mine at the heated bad
                  A Former User
                  @Dugee Ferrules are sized for the wire, not the terminal.
                  • Dugeeundefined
                    Dugee
                    One of the reasons I like the general 3d community is that you can ask the stupid/obvious question without being patronised or belittled. Everyone is always keen to help the beginner.
                    Many thanks.
                      T3P3Tony administrators
                      I have added a note about ferrules to the documentation:
                      https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_Ferrules
                        A Former User
                        Risky business specifying size according to colour; while there are a few standards to choose from, you can also get almost any size in any colour. While it'll be correct for the ones supplied by Duet3d the end user can easily end up with a different size if ordering new ones based on colour.
                        T3P3Tonyundefined zaptaundefined 2 Replies Last reply Reply Quote 1
                          T3P3Tony administrators @A Former User
                          @bearer exactly why i have the mm^2 in the documentation.
                            A Former User @T3P3Tony
                            @T3P3Tony yes, maybe i should have been clearer; I'd put the size first to emphasize size instead of colour.
                              @bearer fair enough - I have updated it to make it clearer.
                              • mihaitinteaundefined
                                mihaitintea
                                But how do I correctly fit those ferruled connectors into the terminals ? Do I flatten them first with pliers before putting them into the terminals and tighten the terminals' screws, or do I put the ferruled connectors as they originally are ("cylindrical", not mechanically deformed -- flattened) into the teminals and force-screw the terminals's screws until they mechanically flatten the ferruled connectors ?
                                JoergS5undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                • JoergS5undefined
                                  JoergS5 @mihaitintea
                                  This post is deleted!
                                  • Vetiundefined
                                    Veti
                                    they are meant to be used with a ferrule crimp tool.
                                      Phaedrux Moderator @mihaitintea
                                      @mihaitintea Pliers don't really work very well. Ideally you'd use crimpers meant for ferrules that compress them in all directions to create a tight pinch. Pliers or vice grips can be used, but you risk damaging the wires or creating a poor mechanical crimp.
                                      https://www.google.com/search?q=crimping+bootlace+ferrules&oq=crimping+boot&aqs=chrome.1.69i57j0l5.6576j0j7&sourceid=chrome&ie=UTF-8
                                        I use a ferrule crimping tool that I bought from Maplin, who sadly went bust. A search on eBay UK turned up this https://www.ebay.co.uk/itm/Ferrule-Crimper-Cable-Tube-Crimping-Plier-Tool-1200X-Wire-Terminal-Connector-Set/392118937290 and several other listings for similar products.
                                          A Former User
                                          There is a wide range of types of crimping tools, while I tend to prefer the sort of D shaped dies the smallest terminals used on the Duet works best with square type of crimpers, and not the type that create extremely serrated sides.
                                          So the type dc42 links to is probably the best bet.
                                            swrightlast
                                            Bought a ferrule crimping tool.....problem solved.
