    Cura 4.2.1 Config help
    40
    2.4k
    • Danalundefined
      Danal
      Good stuff! Thanks for the complete answers. Everything looks OK in the first set of answers.
      Regarding the G-Code:
      @Shaun said in Cura 4.2.1 Config help:
      ;LAYER:0
      M107
      M566 X480 Y480
      G0 F6000 X126.088 Y126.295 Z0.2
      ;TYPE:SKIRT
      G1 F2700 E1
      G1 F1200 X126.478 Y125.911 E0.02002
      ;LAYER:1
      M140 S60
      M106 S85
      ;TYPE:WALL-INNER
      ;MESH:Golf_Green_Marker.stl
      G1 F2700 E1
      G1 F1350 X139.677 Y146.891 E0.01563
      We may not have enough of this file. Layer 0 (which will become the skirt) is being printed at 0.2 above the bed, which is fine (and you said this layer works). We need enough of the file to see the Z commands for the next several layers.
      Please find ;LAYER:0 through ;LAYER:5 and post that.
      Shaunundefined 1 Reply Last reply Reply Quote 1
      • Shaunundefined
        Shaun @Danal
        @Danal Thanks, i knew i should i emailed the gcode to work so that i can update this.
        Ill get to this as soon as i get home. I tried a different file last night and the same problem.
        • JuJuDeltaundefined
          JuJuDelta @Shaun
          "but when it starts the skirt is printed to perfection. Now this is where i get stumped, as soon as the nozzle moves to start the actual job it doesnt lower down enough to get to the bed. The result is a mess. "
          I get the exact same thing, so watching this thread with interest.
          T3DP3D Kossel XL+, Duet2Wifi, PanelDue 7i, RRF V3.2, Fl3xdrive, SmartEffector, Berd Air annulus, Cura 4.x, PrusaSlicer, RPi WiFi Camera, Heated Chamber
            droftarts administrators
            Quick guess as to what's going on: you're using 'Z Hop When Retracted' (in 'Travel' section in Cura, you may need to turn this on to see it), for which the speed is set by 'Z Hop Speed' (in 'Speed' section, which you may also need to turn on) is higher than the axis can actually travel. This shouldn't be a problem, as the firmware will slow it down to the speed the axis can travel, except that you have set that speed too high in config.g, so it skips steps.
            @Shaun Can you post your config.g as well, so we can see what the Z axis speed is set to?
            @JuJuDelta Is it your Kossel (from your signature) that's doing this? Delta printers shouldn't usually have this problem, as they can move in all three dimensions at pretty much full speed.
            Shaunundefined 1 Reply Last reply Reply Quote 0
            • Shaunundefined
              Shaun @droftarts
              @droftarts here you go
              M350Z16 I0 ; configure microstepping without interpolation
              M350X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation
              M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
              M906 X950 Y950 Z950 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
                Your Z axis is limited to 180mm/min (3mm/s), which I think is the stock setting; my Cartesian machine (though dual Z motors) is set the same, and your other motor settings are stock. It may be that you need to test if it can actually do these speeds; it's possible there's more weight on the Z axis, so it actually has to be lower. Or, as you've got 4000 steps per mm (0.5mm pitch on your Z leadscrew, I think), at full speed the motor has to do 6 revolutions per second to move 3mm; it may just not physically be able to do this.
                Try sending G1 Z10 F180 then G1 Z-10 F180 to check movement. If you do this at Z=0, you should be able to see if it returns to the same place. If it doesn't, try lowering the feedrate from F180 until it does move reliably.
                In Cura, the Z Hop speed is set to 10mm/s, which my delta can do, but my Cartesian machine definitely can't! But the config.g setting will limit it to 3mm/s. I don't usually have Z Hop turned on on my Cartesian printer, as the slow Z movement can cause as many, though different, printing problems as having it switched off.
                If this doesn't help, can you upload the gcode as @Danal suggested, then we can see what it's actually doing during a print.
                • Shaunundefined
                  Shaun @droftarts
                  @droftarts said in Cura 4.2.1 Config help:
                  Super, ill try drop the speed and also removing z hop.
                  • Shaunundefined
                    Shaun
                    Morning, ok so changed the speed and removed the rim. This time is printed but the layers where way to far apart leading me to the conclusion that my Z steps are way off.
                    My Config.g
                    ; Configuration file for Duet WiFi (firmware version 2.03) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.0.3 on Fri Sep 13 2019 19:45:33 GMT+0100 (British Summer Time)
                    M550 P"CR10" ; set printer name
                    M552 S1 ; enable network
                    M586 P0 S1 ; enable HTTP
                    M586 P1 S0 ; disable FTP
                    M586 P2 S0 ; disable Telnet
                    M92 X80.00 Y80.00 Z4000.00 E1222.00 ; set steps per mm
                    M201 X500.00 Y500.00 Z10.00 E250.00 ; set accelerations (mm/s^2)
                    M208 X280 Y280 Z350 S0 ; set axis maxima
                    ;M557 X10:280 Y35:270 S12.6 ; Define mesh grid for full bed print
                    ;G31 X-43.2 Y31.9 Z2.132 P25
                    M574 X1 Y1 Z1 S1 ; set active high endstops
                    ;M558 P5 X0 Y0 Z1 H7 F500 T4000 ; Set Z Probe to type Switch or Digital output where Z probe connector is used
                    ;M31 P25 X0 Y0 Z1 ; Set Z probe trigger value, offset and trigger height
                    ;M574 Z1 S2 ; set endstops controlled by probe
                    M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                    M558 P5 H1 F500 T5000 ; set Z probe type to bltouch and the dive height + speeds
                    G31 P25 X8.5 Y-50 Z0.38 ; set Z probe trigger value, offset and trigger height
                    M557 X5:205 Y5:205 S10 ; define mesh grid
                    M143 H1 S260 ; set temperature limit for heater 1 to 260C
                    ;Disable Heater to free up PWM channel
                    M307 H7 A-1 C-1 D-1 ; disable heater for BLTouch
                    M106 P0 S1 I0 F500 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                    M106 P1 S1 I0 F500 H1 T150 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                    M501
                    grizewaldundefined 1 Reply Last reply Reply Quote 0
                    • grizewaldundefined
                      grizewald @Shaun
                      4000 steps per millimetre on Z looks like an order of magnitude too high...
                      wilrikerundefined Shaunundefined 2 Replies Last reply Reply Quote 0
                      • wilrikerundefined
                        wilriker @grizewald
                        @grizewald said in Cura 4.2.1 Config help:
                        With the sole exception that he is using a M5 threaded rod. But yes, more common these days are TR8x8 lead-screws which have 400 steps/mm.
                        Manuel
                        My Tool Collection
                        • Shaunundefined
                          Shaun @grizewald
                          Aaaahh yes that should be 400. My fat fingers again. Will fix and test.
                          grizewaldundefined 1 Reply Last reply Reply Quote 1
                            Funnily enough I use M5 rod on mine, so Z4000 looked right to me! I think I remember thinking "I wonder what a CR10 has for leadscrews?" at the time I wrote it, but then forgot!
                            @Shaun You can probably turn the speeds for Z back up now, as the motor will probably be able to lift the Z much faster now, assuming it has enough torque to move the Z that fast. But do test it at it's maximum speed.
                            • Shaunundefined
                              Shaun
                              Could this be it?
                              ;FLAVOR:RepRap
                              ;TIME:194
                              ;Filament used: 0.0936418m
                              ;Layer height: 0.2
                              ;MINX:131.371
                              ;MINY:132.221
                              ;MINZ:0.2
                              ;MAXX:148.663
                              ;MAXY:148.664
                              ;MAXZ:10
                              ;Generated with Cura_SteamEngine 4.2.1
                              • wilrikerundefined
                                wilriker @Shaun
                                @Shaun That just gives the minimum and maximum coordinates this print will reach for every axes. In this case your part is 10mm high according to these comments.
                                Manuel
                                My Tool Collection
                                  grizewald @Shaun
                                  And there I was feeling silly after wilriker's comment, but I was fairly sure that in all the pictures I'd seen of the CR10, it was using a lead screw and not a threaded rod.
                                  I feel vindicated! 🙂
                                  Hope it fixes your Z height problem.
                                  • wilrikerundefined
                                    wilriker @grizewald
                                    Ooops! Besides being the wise-guy that I am sometimes (=most of the time 😂 ) I actually wanted to express that I think you were right. Sorry I did not bring that across. 🤦
                                    Manuel
                                    My Tool Collection
                                    • Shaunundefined
                                      Shaun
                                      Still struggling to get this resolved, any other ideas i could try? Thinking i should scrap Cura and try something else to see if it resolves the problem.
                                      burtoogleundefined 1 Reply Last reply Reply Quote 0
                                      • burtoogleundefined
                                        burtoogle @Shaun
                                        Can you please make the entire gcode file available, thanks.
                                        • Shaunundefined
                                          Shaun @burtoogle
                                          @burtoogle said in Cura 4.2.1 Config help:
                                          Here’s a link to “CCR10_Golf_Green_Marker.gcode” in my Dropbox:
                                          https://www.dropbox.com/s/j82sd95kngk4gjr/CCR10_Golf_Green_Marker.gcode?dl=0
                                            burtoogle
                                            Thanks for the gcode file. I can't immediately see any obvious issues with it. What exactly is the problem you are having?
