    XYZ carriage rise without reason
    1.1k
    • MrOppipundefined
      MrOppip
      I put the .json because you could see all the configuration from the browser.
      here are the individual files:
      tpre0.g tpost0.g tfree0.g stop.g sleep.g retractprobe.g resume.g pause.g homez.g homey.g homex.g homeall.g deployprobe.g config.json config.g bed.g
      • Vetiundefined
        Veti
        in your homex.g do you see the commands to lift the z up and down?
        ; homex.g
        ; called to home the X axis
        ; generated by RepRapFirmware Configuration Tool v2.0.4 on Tue Sep 24 2019 00:04:06 GMT+0200 (Ora legale dell’Europa centrale)
        G91 ; relative positioning
        G1 S1 X-305 F3000 ; move quickly to X axis endstop and stop there (first pass)
        G1 X5 F6000 ; go back a few mm
        G1 S1 X-305 F300 ; move slowly to X axis endstop once more (second pass)
        G1 Z-5 F6000 S2 ; lower Z again
        G90 ; absolute positioning
        also unless there is a specific reason, you should go with x16 and interpolation.
        do you have 0.9 or 1.8 degree steppers?
        MrOppipundefined 1 Reply Last reply Reply Quote 0
        • MrOppipundefined
          MrOppip @Veti
          @Veti I know, that means it rises 5mm before x home .... but it rises more.
          1.8 degrees.
          In the configurator I set x256. I will do the test with x16 but I don't think that's the reason
          • Vetiundefined
            Veti @MrOppip
            @MrOppip said in XYZ carriage rise without reason:
            measure the exact distance with a ruler. more does not give any clues as to what the difference is using the manual movements from the web interface.
            • MrOppipundefined
              MrOppip
              you were right. it was enough to set x16 and the right steps to fix the z shift.
              strange, I didn't understand because with x256 it moved too much.
              thanks for the advice
              now another problem has arrived. The extruder does not work.
              I warmed up, I enabled the tool, but the extruder does not send the filament forward or backward.
              The engine works well because I tried to connect it to x driver.
              so I think that the E0 driver is broken.
              I tried to use E1 modifying the config like this:
              M569 P4 S0
              M584 X0 Y1 Z2 E4
              But it did not work.
              Is it possible also the E1 driver is broken?
              When I had the duet on another printer I found the extruder motor cable fused. Could the E0 and E1 drivers be broken?
              How can I check?
              • Vetiundefined
                Veti
                to rule out config problem reconfigure it e0 as x and connect the x stepper to it.
                see if you can home.
                Be aware the M584 has to be one of the first commands in the config.
                • MrOppipundefined
                  MrOppip @Veti
                  @Veti said in XYZ carriage rise without reason:
                  I did the test you told me.
                  E0 and E1 drivers work great with X and Y motors.
                  I put the connections as first ..... extruder does not move.
                  I also tried cold extrusions but it doesn't work.
                  what can I do?
                  tpre0.g tpost0.g tfree0.g stop.g sleep.g retractprobe.g resume.g pause.g homez.g homey.g homex.g homeall.g deployprobe.g config.g bed.g
                  • fcwiltundefined
                    fcwilt
                    Did you verify that the cables to the extruder motors are good?
                    • MrOppipundefined
                      MrOppip @fcwilt
                      @fcwilt said in XYZ carriage rise without reason:
                      The motor and cable works well because I tried to connect it to x driver.
                      • fcwiltundefined
                        fcwilt @MrOppip
                        I read that you tried the X,Y motors with the E0,E1 drivers. I missed where you tried the extruder motor with the X driver.
                        When trying to extrude via DWC do you have a tool selected?
                        • MrOppipundefined
                          MrOppip @fcwilt
                          it was written in the previous post
                          sure, otherwise the extrusion and protrusion button is disabled
                          • Vetiundefined
                            Veti
                            can you tell us step by step how you are trying to extrude? every button you press, every command you issue.
                            • MrOppipundefined
                              MrOppip @Veti
                              first method:
                              power on duet
                              home all
                              activated heater
                              heated 200 °
                              in "extruder control" pressed extrude
                              then retract.
                              second method:
                              power on duet
                              activated heater
                              in "gcode console" given command M302 P1
                              then G1 E50
                              then G1 E-50
                              nothing moves
                              • Vetiundefined
                                Veti
                                can you verify with a multimeter that the phases on the extruder stepper are correct.
                                i.e. one phase for red and blue and one for green and black.
                                • fcwiltundefined
                                  fcwilt @MrOppip
                                  @MrOppip
                                  I don't see where you selected the tool.
                                  • MrOppipundefined
                                    MrOppip @fcwilt
                                    @fcwilt
                                    activated the heater means the same as selected the tool.
                                    @Veti
                                    yes is the first thing I checked to run it correctly.
                                    I found that my hardware is perfect because I loaded the Creality Ender 3 Pro predefined configuration from the RepRapFirmware Configuration Tool and the extruder works.
                                    so there's something in myFW that doesn't make the extruder go.
                                    I have the BLTouch, connected to the heater 3 (disabled as in the tutorials).
                                    does it interfere in any way?
                                    in the meantime, thanks for the support
                                    • fcwiltundefined
                                      fcwilt @MrOppip
                                      @fcwilt
                                      Hmm...
                                      I cannot check right now but I'm pretty sure a tool can have it's heater in the standby state without the tool being active.
                                      • Vetiundefined
                                        Veti
                                        its shouldnt, but its an easy check. comment the line and try it.
                                        do you have a config-overwrite? because you have a M501 in your config.
                                        please post the config where it was working.
                                        • MrOppipundefined
                                          MrOppip @Veti
                                          I'm not sure if it's useful. I had enabled it along with the ability to save the print in the event of a blackout.
                                          config Ender.g
                                          checking it I saw that:
                                          M563 P0 D0 H1 F0
                                          in my CR10 file config D0 is not there.
                                          I don't know why the online configurator doesn't create it.
                                          can it be the cause? I haven't had time to try yet.
                                          • Vetiundefined
                                            Veti
                                            yes
                                            If there is no 'D' field the tool has no drives.
                                            MrOppipundefined 1 Reply Last reply Reply Quote 1
