    Duet V3 Expansion Boards
    • mattbakerundefined
      mattbaker
      Does anyone have any idea when the expansion boards will be a valuable? I want to use 3 z motors, and dual extruders.
      Or maybe someone will know how to adapt existing boards to work?
        T3P3Tony administrators @mattbaker
        @mattbaker We are targeting November for a pre production run to sync in with the wider availability of the Duet 3 6HC mainboard.
        mattbakerundefined 1 Reply Last reply Reply Quote 0
          mattbaker @T3P3Tony
          @T3P3Tony Is there a way to link a Duet Ethernet to the V3?
            @mattbaker no - they use CAN-FD to connect.
            The core elements of the Duet 2 Family (The Duet 2 Wifi/Ethernet and the Duex5) are not compatible with the core elements of the Duet 3 family (The Duet 3 Mainboard(s), Expansion board(s) and Tool board(s)).
            Things like the Temperature Daughter-boards, the smart effector and filament monitors are compatible between families.
            samlogan87undefined 1 Reply Last reply Reply Quote 0
            • samlogan87undefined
              samlogan87 @T3P3Tony
              @T3P3Tony
              Do you intend on adding pt100 functionality on the tool boards?
              Regards
              Sam
              Custom Core-XY
                @samlogan87 said in Duet V3 Expansion Boards:
                @T3P3Tony
                Regards
                Sam
                Only if an OEM asks for it, because the concept tool board already supports PT1000. Adding PT100 support would increase the cost significantly.
