    New RepRapFirmware config tool
    79
    10.3k
      The online configurator doesn't cover advanced configurations such as IDEX. You will need to edit the config.g file to create the new axis and assign the correct fans. See https://duet3d.dozuki.com/Wiki/ConfiguringMultipleIndependentXcarriagesCartesian
      • imrjundefined
        imrj
        Great work!!
        • botundefined
          bot @dc42
          @dc42 thanks, I will make my own files.
          *not actually a robot
            You can use the configurator to generate most of the commands, by telling it you have a dual extruder machine. Then edit the resulting files to account for IDEX.
            • botundefined
              bot
              That is what I ended up doing. I'm well on my way and finally getting a hang of all the changes since I last configured a new printer.
              • DunstonUKundefined
                DunstonUK
                It is using the old M667 S1 command for CoreXY where I believe it should be M669 K1.
                Also, all files in the homing files list items such as; " lift Z relative to current position" when the bed drops as the gantry is fixed, is this not possible to be corrected so the file wording reflects what it actually does.
                Life’s bucket list is never ending. Remember someone else is always better than you.
                  T3P3Tony administrators @DunstonUK
                  @DunstonUK said in New RepRapFirmware config tool:
                  This is correct in my view because Z increases as the bed drops on a printer with a bed that movers in Z. Bed down is equivalent to gantry up, and the firmware does not know what configuration your hardware is in. A possible clarification would be "Increase Z distance..." Rather than " Lift Z...."
                  DunstonUKundefined 1 Reply Last reply Reply Quote 0
                    DunstonUK @T3P3Tony
                    @T3P3Tony
                    Yes, but also you have to select what type of printer you have at the start, and as I do not see CoreXY as a choice its always "Custom configuration", which is chosen, unless you have one of the ones listed, also for those who have lets say a Corxy with 3 x Z rods/screws/rails, there is no tool selection for that type or not? I am relatively new to 3D printing, but I do see that these tools and configurators are not always made with the novice in mind, who may not fully grasp the wording used, because the wording used is not always clear and can lead to more confusion and more posts asking the same questions over and over again. Please do not misunderstand me, these tools are a godsend, without it I would be posting even more questions that I do, and I tip my hat to those who have written it with full respect.
                      @DunstonUK sure - custom configuration and then choose corexy at some point in the future we will hopefully have more corexy printer types: Railcore II, e3d Toolchanger, H Bot etc but unless you had one of those you would still need to use custom, then coreXY.
                      no advanced options like that are not yet part of the config tool.
                      • OBELIKSundefined
                        OBELIKS
                        Can you check CoreXY implementation, it gives out
                        M667 S1                                 ; select CoreXY mode
                        instead of
                        M669 K1                                 ; select CoreXY mode
                        It would have saved me a LOT of head scratching 😄
                        P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
                        Original Prusa i3 MK3S
                        • Vetiundefined
                          Veti
                          currently the firmware will translate the M667 to the appropriate M669 command.
                          • steevebeckerundefined
                            steevebecker
                            Hi
                            the arrival of Duet 3 Mainboard is a great news,
                            have you already planned a date for its integration in the Config Tool ?
                            thanks
                            plant your ideas, water suggestions and questions, collect progress and do great things.
                              droftarts administrators
                              Plans, yes! In Board type, "Duet 3 (coming soon)".
                              But really it depends on getting RRF 3 configuration working. In Firmware version, "3.xx (coming soon)". No date when this is expected, as far as I'm aware.
                              • Wallabearundefined
                                Wallabear
                                Will there be an updated config tool for the Duet 3? If yes will it also work with the Duet 2 as well? With the added flexibility of the Duet 3 it would be really nice if the config too would be able to configure advanced options like adding an axis or two or 5. Not that going into the .g files and configuring the special setups is hard or anything but it would be really nice if a config tool existed for advanced options to handle most of the set up and then jumping into the .g files for final tweaking.
                                  steevebecker
                                  Hi
                                  I'm starting to work on the Duet 3, to ease my discovery, is there any one who can share a simple .g file ?? for a standard machine like : cartesian /200x200x250/simple extrudeur/heated bed/z probe. it could help a lot, thanks in advance.
                                    A Former User @steevebecker
                                    @steevebecker I can share a simple config.g file for ender5 but duet2 with RRF 3 if that helps
                                    steevebeckerundefined 1 Reply Last reply Reply Quote 0
                                      steevebecker @A Former User
                                      @smece hi taht could be good as a first step 🙂
                                      i don't how the .g will be different between duet E vs Duet 3.
                                      of course pin out will be different but not sur sure what is the impact on conf ...
                                      dc42undefined A Former User? 3 Replies Last reply Reply Quote 0
                                        dc42 administrators @steevebecker
                                        Please note, the nine IO_ connectors don't all have the same capabilities. I have documented them at https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview#Section_IO. Summary:
                                        • Don't use IO_0 for now
                                        • Don't connect an analog Z probe or a BLTouch to IO_0, IO_1 or IO_2
                                          steevebecker @dc42
                                          @dc42 thanks for this. I need a lot of I/O so it's good to know.
                                            @steevebecker said in New RepRapFirmware config tool:
                                            Apart from pin names, the main difference is that there are some default pin assignments for endstops, zprobe and fans in RRF3 for Duet 2, but none in RRF3 for Duet 3. See https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Default_pin_assignments. So on Duet 2, you may need to use GCode commands to free up some of those pins if you want to use them for something else; whereas on Duet 3 you always need to declare what pins to use for fans, endstops and Z probe.
                                            PS - I am starting to add Duet 3 pin connections to the documentation pages on wiring. For example, I have already added them to the page on connecting Z probes.
