    Auto Bed vs. Mesh Grid Compensation
    3.4k
    • martinchoundefined
      martincho @Phaedrux
      @Phaedrux I saw your other response and dug into it, thanks.
      I guess I am now wondering if my firmware is out of date? The "Auto Bed Compensation" button --which I thought would probe and then enable compensation-- only seemed to do the first half of that. The only evidence I have in support of this is that it wasn't until I added probing code to the start of every part that my first layer became predictable and reliable.
      My problem is solved now. I am only continuing to dig in this discussion for the potential benefit of others who might run into this. This issue cost me weeks of pulling my hair trying to figure out what I was doing wrong.
      It would be nice if someone from Duet could answer and explain what the various buttons do in that menu.
        Well there is this
        https://duet3d.dozuki.com/Wiki/Duet_Web_Control_Manual#Section_Probing_the_Bed
          martincho
          Ah, OK, thanks for that. The button isn't labeled correctly then. Even then, the whole thing is really confusing because it runs "bed.g", which has G29 in it.
          Per the documentation on "Auto Bed Compensation" button:
          The "Auto Bed Compensation" button on a Cartesian or "Auto Delta Calibration" button runs G32.
          This has different functions . On a Cartesian/CoreXY/SCARA machine it is used for
          Bed levelling using multiple independent Z motors.
          Yet, if you look at documentation for G32:
          The firmware executes macro file bed.g if present instead of using the M557 coordinates.
          What does "bed.g" contain?
          bed.g
          ; generated by RepRapFirmware Configuration Tool v2 on Wed Aug 14 2019 16:30:15 GMT-0700 (Pacific Daylight Time)
          G28  ; home all axes
          G29  ; probe the bed and enable compensation
          So...G32 really runs G29 but it seems it doesn't enable mesh compensation, for that you would need:
          G29 S1
          I don't know, the feeling I am getting is that the documentation isn't correct somewhere, the "Auto Bed Leveling" button isn't labeled correctly and the documentation sends in into a circular trip devoid of clarity. The fact that I was able to fix a bunch of problems by effectively adding just the "S1" portion to the G29 command tells me this might warrant a look by the Duet guys.
          This has caused weeks of consternation on my part. I am sure I'm not the only one who read "Auto Bed Compensation" and thought, well, that's what the button was for. Then, after using it, when the printer has problems, the last thing you think about is bed leveling...because you've already done it, including seeing the nice pop-up graphic showing you the measurements. You look at the documentation and it goes in circles, pretty much confirming that, again, you did the right thing. Until you notice "S1", try it, and all problems go away instantly.
          @dc42 a bit of wisdom on this might help. Thanks.
          • fcwiltundefined
            fcwilt
            I am using the most recent Duet WiFi firmware.
            For me G29 probes AND enables mesh compensation.
            As to the "Auto Bed Compensation" button: Yes it invokes the bed.g file (if it exists) but the contents of that file is up to you. The contents you have listed will do mesh compensation but it can be created using other commands to do other things - like auto bed leveling using multiple Z-axis steppers.
            • tekkydaveundefined
              tekkydave
              This confused me at first until I realised there was a difference between "Bed Levelling" and "Mesh Compensation".
              Bed Levelling (G32) is to do with physically levelling the bed via the motion of the z-axis steppers. For instance on my D-Bot I have 3 z-axis leadscrews controlled by 3 independent motors (see Bed_levelling_using_multiple_independent_Z_motors).
              In my bed.g I have:
              G28				; home
              G30 P0 X10  Y60  Z-99999 	; probe near a leadscrew
              G30 P1 X290 Y60  Z-99999 	; probe near a leadscrew
              G30 P2 X150 Y290 Z-99999 S3 	; probe near a leadscrew and calibrate 3 motors
              ; re-home z axis in case it has shifted
              G28 Z
              When this runs it probes the bed adjacent to each screw and then moves 1 or more z motors to physically level the bed.
              There is no reason to use G32 on a Cartesian or core-xy printer unless you have multiple z-axis motors that can physically adjust the bed levelling.
              Then there is Mesh Compensation (G29). This is to do with ironing out the imperfections in your (already levelled) bed.
              The Z motors will move the bed up & down as the head moves in x & y to simulate a perfectly flat, level bed.
              I run everything from a single macro rather than call G32 from the drop-down in DWC. It levels the bed using G32 then does a G29 probe in a 3x3 grid.
              Calibrate.g
              ; Warm Hotend and Bed
              T0			        ; Select Tool 0
              M104 S130		; Set Tool 0 temperature to 130 - no wait
              M190 S60		; Set Bed temperature to 60 - wait
              ; Clear Values
              G29 S2			; Clear Mesh Compensation Values
              M290 R0 S0      	; Clear Baby-stepping
              ; Home all Axes
              G28
              ; Bed levelling (G32)
              G30 P0 X10  Y50  Z-99999 	; probe near a leadscrew
              G30 P1 X290 Y48  Z-99999 	; probe near a leadscrew
              G30 P2 X148 Y284 Z-99999 S3 	; probe near a leadscrew and calibrate 3 motors
              ; Re-home z axis in case it has shifted
              G28 Z
              M557 X25:275 Y25:275 S125:125             ; Define mesh grid (3x3)
              ; Mesh Compensation (G29)
              G29			; Run Mesh Compensation
              G1 Z30 F310             ; Move bed down
              G1 X150 Y145 F15600	; Move to centre
              In my slicer startup gcode I have
              G29 S1                          	; Load Mesh Compensation Settings from file
              amongst other things, to reload the Mesh Compensation Height Map created by the G29 in Calibration.g.
              This way I only need to run the calibration once at power-on then simply re-home between prints.
              ~ tekkydave ~
              D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
              FreeCAD, PrusaSlicer
                martincho
                Thanks for the input.
                I should clarify that my bed.g file is what was created by configtool.reprapfirmware.org. In other words, it's precisely what someone who goes to use a Duet for the first time on a custom build or retrofit is likely to end-up with.
                Now I know better, of course. However, the default bed.g created by this config tool seems to be, if I may be so bold to say, wrong.
                I'll bet if you polled 100 people as to what "Auto Bed Leveling" does or means they are likely to describe mesh leveling. I'll also bet that not one of them would conclude that the button does NOT load and activate the mesh leveling function.
                Anyhow, I figured this out after weeks of hair pulling. I am only posting this for the benefit of others who might be confused by first layer and other problems thinking they are doing everything correctly when, in reality, that button and the configuration file associated with it are part of the problem.
                  tekkydave
                  My initial bed.g as downloaded from the configurator contained:
                  ; bed.g
                  ; generated by RepRapFirmware Configuration Tool on Thu Dec 28 2017 14:34:20 GMT+0000 (GMT)
                  G28  ; home all axes
                  ; Probe the bed at 4 points
                  G30 P0 X60 Y60 H0 Z-99999
                  G30 P1 X60 Y220 H0 Z-99999
                  G30 P2 X240 Y220 H0 Z-99999
                  G30 P3 X240 Y60 H0 Z-99999 S
                  At the time I had no idea what it was meant to do.
                  ~ tekkydave ~
                  • fcwiltundefined
                    fcwilt @martincho
                    @martincho said in Auto Bed vs. Mesh Grid Compensation:
                    While it may be a bit confusing It's not wrong. The bed.g file is used for different things depending on your printer type and hardware.
                    For a simple Cartesian the created bed.g simply gives you the ability to click the "Auto Bed Compensation" button to do mesh compensation. Mesh compensation is a more advanced approach replacing the older method.
                    The configurator generates different bed.g depending on settings you enter.
                    Select a delta printer and it will generate a bed.g file appropriate for a delta printer. Specify a CoreXY printer and you will get yet a different bed.g file - one that is out of date, I think.
                    I went back and ran the tool again for a Cartesian printer and got that same bed.g - a different one from the first run.
                    I suspect the tool needs some work.
                    I never used the configurator tool. The Duet WiFi comes with example config files. I studied those to get an idea of what my config file needed to contain and I created my own. There is knowledge to be gained doing that way.
                    Glad to hear you finally got it sorted out.
                      martincho
                      The default bed.g I got for the cartesian configuration does not enable mesh compensation. It runs everything but the map is never loaded. It's all the theatrics without the final functionality being enabled.
                      This requires G29 S01, which is not included in the default bed.g.
                      That was the root of the problem. G29 vs. G29 S01.
                      BTW, I am not blaming anyone. This is just part of learning. My only input is that someone needs to consider that this might have become quite confusing and convoluted over time.
                      As an aerospace engineer I don't think I am a dummy, and this had me going around in circles for quite some time because things would look like they worked better at times and then they would inexplicably break. Adding "S01" made the difference between an inconsistent printer and one I don't have to worry about any more. Surely I am not the only one who has fallen into this trap.
                      • fcwiltundefined
                        fcwilt @martincho
                        Then how do you explain that on my printer I don't need G29 S1 (I assume you mean S1) to enable mesh compensation.
                        I can run the mesh bed probing and check if mesh compensation is enable and it is.
                        Are you using the most recent firmware?
                        martinchoundefined 1 Reply Last reply Reply Quote 0
                          martincho @fcwilt
                          @fcwilt said in Auto Bed vs. Mesh Grid Compensation:
                          I can't explain it. That's why I asked @dc42 to chip in if possible. I'll check my firmware tomorrow, long day.
                          Ex3DPundefined 1 Reply Last reply Reply Quote 1
                          • Ex3DPundefined
                            Ex3DP @martincho
                            @martincho Hello,
                            Please share your firmware if possible. I am stuck with the same problem. Appreciated in advance.
                              jay_s_uk @Ex3DP
                              @ex3dp please open a new thread, don't resurrect an old one
