    Duet Web Control 2.0 released
    Duet Web Control
    12
    22
    1.8k
    • chas2706undefined
      chas2706
      @DeltaCon In DWC1 I can open a macro for instance, copy some selected content by individually highlighting it and then paste it into a new macro.
      In any version of DWC2 I can not do this. The content I wish to copy will not individually highlight.
      I don't know why you fail to see.
      If I right click on the page, the options I get are:
      Paste
      Select All
      Print
      Read Aloud
      Selecting Select All highlights everything then right clicking I can select Copy.
      I can then paste everything into the new macro but I only want to copy selections that I needed to highlight not the hole lot.
      Dougal1957undefined tekkydaveundefined DeltaConundefined 3 Replies Last reply Reply Quote 0
      • burtoogleundefined
        burtoogle @burtoogle
        @burtoogle said in Duet Web Control 2.0 released:
        The 2.0.0 release seems to have removed the "Print Another" button. Why is that?
        I should have made clear that this is a change from 2.0.0-RC7, not from 1.22.
        • Dougal1957undefined
          Dougal1957 @chas2706
          @chas2706 said in Duet Web Control 2.0 released:
          Paste
          Select All
          Print
          Read Aloud
          it works ok for me
          • tekkydaveundefined
            tekkydave @chas2706
            @chas2706 I have found that sometimes selection doesn't work if dragging from the start of a line. Try starting at the end of the last line you want to select.
            ~ tekkydave ~
            D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
            FreeCAD, PrusaSlicer
              Dougal1957 @tekkydave
              @tekkydave said in Duet Web Control 2.0 released:
              that could well be it as that is the way I always do it.
              • chas2706undefined
                chas2706
                Oh right. No bug then you just have to select backwards.
                  tekkydave
                  No bug as far as I can tell. I've just tested it on my Duet2 using DWC V2.0. It just seems very fussy about where you click to start the selection. If you start in the margin area to the left of the first character the selection doesn't work. If you are spot on the first character it works as expected. It is sometimes easier to select backwards then you don't need to be so accurate with your mouse positioning.
                  ~ tekkydave ~
                    T3P3Tony administrators
                    @chrishamm I think it would be a good idea if we could increase the margins for cut and paste. I also get a bit frustrated by not being able to select from the left of the first character in a line unless i am very careful with mouse positioning.
                    • chas2706undefined
                      chas2706
                      @T3P3Tony Thanks for recognising this. It is frustrating and I don't like backward highlighting!
                      BTW when you do scroll backwards the DWC is not fussy at all where you start!
                        T3P3Tony administrators @chas2706
                        @chas2706 yep, its just the margin settings in that box are too strict.
                        • Nuramoriundefined
                          Nuramori
                          I'm not entirely sure it's related, or would be, but I'll ask just to make sure. Since updating, I am having connection issues with my network. The update is the only thing that has changed, nothing in terms of my printer has been modified that may contribute to the error. My network checks out, and also hasn't changed.
                          My network DOES now show that the connection to the printer has a high level of WiFi retries, which isn't happening with any of the other devices on the same network. Thoughts in what I can do to try and ascertain the issue and remove the printer or the update as the cultrpit?
                          • DeltaConundefined
                            DeltaCon @chas2706
                            Because of the word "still" in your phrase:
                            Nice to see some bugs ironed out but still annoying that copy and paste still does not work! Cant copy gcode from one file to another.
                            I falsly assumed it already did not work for you in DWC 1.x, hence my comment. I have not used DWC 2.x myself so I can't comment on that. I would try DWC with pleasure but I don't know if that is going to be problematic since I use the old Duet 0.6...
                            If you think trial and error is dangerous, try routine. That's even more so!
                            • DocTruckerundefined
                              DocTrucker @DeltaCon
                              @DeltaCon I've been using DWC2_rc7 on my v0.6 and v0.8.5 machines with no problems other than it not being quite as obvious how to do firmware upgrades. That may have cleared up in the most recent release.
                              I was just looking on the forums for some news about another release candidate or full release when I found this thread.
                                DocTrucker
                                DWC is now on 2.0.2
                                There is a comment on the change list saying 'print another' has been fixed.
