    have problems with mesh bed leveling
    1.0k
    • lui2004undefined
      lui2004
      ok shit 😉
      can you recommend me a good bed ?
      • lui2004undefined
        lui2004
        today i have changed the bed and all is flat
        now,what i do first before i start print?
        G29 S1 ; Load Mesh
        G32 to Level the 2 independend Z-Motors
        and the start print is correct ? if yes my prints starts over the air if do this
        • fcwiltundefined
          fcwilt @lui2004
          @lui2004
          Well for my DBOT equipped with 3 Z-axis steppers and I am leveling the bed and/or creating the height map as separate operations via Macros
          For printing I:
          • warm the bed and extruder heater for several minutes
          • home all
          • set the "Z=0 Datum" using the Z-probe
          • load the height map
          • begin print
          • lui2004undefined
            lui2004
            for Simplify3d in Endscript is the code like this ?
            G28 ; home all axis
            G1 X110 Y110 ; Go to Center
            G30 ; Z=0 Datum
            G29 S1 ; Load Mesh
            • fcwiltundefined
              fcwilt @lui2004
              @lui2004
              The only gcode I have in S3D is to use M98 to invoke two macros, print_begin.g and print_end.g
              • lui2004undefined
                lui2004
                Hi
                i have never used macros, can you explain me ho to use it ?
                thanks a lot for your help
                grizewaldundefined 1 Reply Last reply Reply Quote 0
                • grizewaldundefined
                  grizewald @lui2004
                  @lui2004 said in have problems with mesh bed leveling:
                  Hi
                  A macro is just a file containing G-codes. You use M98 P"macro filename" to run a macro by name.
                  They are great for putting the code for a specific function which you might want to run from various places in one file so there's only one file to edit when you need to change things.
                  For example, you could have the code needed to home your X, Y and Z axes repeated in both homeall.g and the individual home macros. Or, you could just call the individual home macros from homeall.g
                  • lui2004undefined
                    lui2004
                    ok nice !
                    for example for z=Datum
                    Zdatum.g
                    G1 X110 Y110 ; Go to bed center
                    G30 ; Probe once
                    and then i can insert in Simplify3d in Startscript
                    M98 Zdatum.g
                    is it correct ?
                    infiniteloopundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                    • infiniteloopundefined
                      infiniteloop @lui2004
                      is it correct ?
                      You're very close:
                      M98 P"Datum.g"
                      • lui2004undefined
                        lui2004
                        yeah i will do my best ,i will learn 😉
                          infiniteloop
                          @infiniteloop said in have problems with mesh bed leveling:
                          You're very close:
                          ... as was I. Let's try it again:
                          M98 P"Zdatum.g"
                          Sorry.
                          • fcwiltundefined
                            fcwilt @lui2004
                            M98 Zdatum.g
                            As stated by the other poster your syntax is not quite correct.
                            But consider the approach of having just two calls in S3D to macros that do everything you need to start printing and to finish printing.
                            That those macro can call other macros if that makes things easier.
                            My goal is to minimize changes I have to make in S3D and keep all the changes in the Duet.
