    have problems with mesh bed leveling
    1.0k
    • lui2004undefined
      lui2004
      it seems almost perfect 😉
      epRapFirmware height map file v2 generated at 2019-10-03 19:25, min error 0.000, max error 0.017, mean 0.009, deviation 0.008
      xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum
      5.00,215.00,9.00,210.00,-1.00,210.00,201.00,2,2
        0.017,  0.000
        0.017,  0.002
      • fcwiltundefined
        fcwilt
        Were you actually running the bed.g file with all of the commands commented out?
        • lui2004undefined
          lui2004
          my bed.g is like this:
          ;; bed.g
          ; generated by RepRapFirmware Configuration Tool v2 on Mon Apr 29 2019 10:01:00 GMT+0200 (Mitteleuropäische Sommerzeit)
          G28 ; home
          M401 ; deploy Z probe
          G30 P0 X215 Y210 Z-99999 ; probe near an adjusting screw
          G30 P1 X215 Y9 Z-99999 ; probe near an adjusting screw
          G30 P2 X5 Y114 Z-99999 S3 ; probe near an adjusting screw and report adjustments needed
          M402 ; retract probe
          • lui2004undefined
            lui2004
            G29 with multi-point probing i got this output
              T3P3Tony administrators
              If you compare the simple 4 points, with the multi point it certainly looks like your bed has a huge bulge. try rotating the surface or flipping it over to confirm it is a physical issue with the bed surface.
              • lui2004undefined
                lui2004
                ok shit 😉
                can you recommend me a good bed ?
                • lui2004undefined
                  lui2004
                  today i have changed the bed and all is flat
                  now,what i do first before i start print?
                  G29 S1 ; Load Mesh
                  G32 to Level the 2 independend Z-Motors
                  and the start print is correct ? if yes my prints starts over the air if do this
                  • fcwiltundefined
                    fcwilt @lui2004
                    @lui2004
                    Well for my DBOT equipped with 3 Z-axis steppers and I am leveling the bed and/or creating the height map as separate operations via Macros
                    For printing I:
                    • warm the bed and extruder heater for several minutes
                    • home all
                    • set the "Z=0 Datum" using the Z-probe
                    • load the height map
                    • begin print
                    • lui2004undefined
                      lui2004
                      for Simplify3d in Endscript is the code like this ?
                      G28 ; home all axis
                      G1 X110 Y110 ; Go to Center
                      G30 ; Z=0 Datum
                      G29 S1 ; Load Mesh
                      • fcwiltundefined
                        fcwilt @lui2004
                        @lui2004
                        The only gcode I have in S3D is to use M98 to invoke two macros, print_begin.g and print_end.g
                        • lui2004undefined
                          lui2004
                          Hi
                          i have never used macros, can you explain me ho to use it ?
                          thanks a lot for your help
                          grizewaldundefined 1 Reply Last reply Reply Quote 0
                          • grizewaldundefined
                            grizewald @lui2004
                            @lui2004 said in have problems with mesh bed leveling:
                            Hi
                            A macro is just a file containing G-codes. You use M98 P"macro filename" to run a macro by name.
                            They are great for putting the code for a specific function which you might want to run from various places in one file so there's only one file to edit when you need to change things.
                            For example, you could have the code needed to home your X, Y and Z axes repeated in both homeall.g and the individual home macros. Or, you could just call the individual home macros from homeall.g
                            • lui2004undefined
                              lui2004
                              ok nice !
                              for example for z=Datum
                              Zdatum.g
                              G1 X110 Y110 ; Go to bed center
                              G30 ; Probe once
                              and then i can insert in Simplify3d in Startscript
                              M98 Zdatum.g
                              is it correct ?
                              infiniteloopundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                              • infiniteloopundefined
                                infiniteloop @lui2004
                                is it correct ?
                                You're very close:
                                M98 P"Datum.g"
                                • lui2004undefined
                                  lui2004
                                  yeah i will do my best ,i will learn 😉
                                    infiniteloop
                                    @infiniteloop said in have problems with mesh bed leveling:
                                    You're very close:
                                    ... as was I. Let's try it again:
                                    M98 P"Zdatum.g"
                                    Sorry.
                                    • fcwiltundefined
                                      fcwilt @lui2004
                                      M98 Zdatum.g
                                      As stated by the other poster your syntax is not quite correct.
                                      But consider the approach of having just two calls in S3D to macros that do everything you need to start printing and to finish printing.
                                      That those macro can call other macros if that makes things easier.
                                      My goal is to minimize changes I have to make in S3D and keep all the changes in the Duet.
