    have problems with mesh bed leveling
    1.0k
    • fcwiltundefined
      fcwilt @lui2004
      @lui2004
      Why are all of the commands in your bed.g commented out?
      As to getting G29 to do a simplified 4 point probe try M557 X5:215 Y9:210 P2.
      Those values are determined by the values in your bed.g file. In that file you specify the first two points as X215,Y210 and X215,Y9 with the X of the third point as X5. So I am using the X range (5 to 215) and the Y range (9 to 210) to specify the four points of a rectangle which would give you a simplified height map showing just the overall levelness of the bed.
      Now I don't recall if the M557 command needs to be set taking into account the probe offset or not.
      I don't use the bed leveling assistant as I find it hard to turn the adjustment screws just the amount reported.
      I just use G29 with 4 point probing near the corners of the bed. Then I can look at the values reported in the height map and tweak the adjustment screws. It takes a number of runs of G29 but I find that I can get the four points adjusted within 0.005 mm easily and within 0.001 mm with a bit more work.
      One I have the bed leveled to my satisfaction then I use G29 with multi-point probing to determine the actual mesh compensation to use during printing.
      • lui2004undefined
        lui2004
        i still try it
        thanks
        • lui2004undefined
          lui2004
          it seems almost perfect 😉
          epRapFirmware height map file v2 generated at 2019-10-03 19:25, min error 0.000, max error 0.017, mean 0.009, deviation 0.008
          xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum
          5.00,215.00,9.00,210.00,-1.00,210.00,201.00,2,2
            0.017,  0.000
            0.017,  0.002
          • fcwiltundefined
            fcwilt
            Were you actually running the bed.g file with all of the commands commented out?
            • lui2004undefined
              lui2004
              my bed.g is like this:
              ;; bed.g
              ; generated by RepRapFirmware Configuration Tool v2 on Mon Apr 29 2019 10:01:00 GMT+0200 (Mitteleuropäische Sommerzeit)
              G28 ; home
              M401 ; deploy Z probe
              G30 P0 X215 Y210 Z-99999 ; probe near an adjusting screw
              G30 P1 X215 Y9 Z-99999 ; probe near an adjusting screw
              G30 P2 X5 Y114 Z-99999 S3 ; probe near an adjusting screw and report adjustments needed
              M402 ; retract probe
              • lui2004undefined
                lui2004
                G29 with multi-point probing i got this output
                  T3P3Tony administrators
                  If you compare the simple 4 points, with the multi point it certainly looks like your bed has a huge bulge. try rotating the surface or flipping it over to confirm it is a physical issue with the bed surface.
                  • lui2004undefined
                    lui2004
                    ok shit 😉
                    can you recommend me a good bed ?
                    • lui2004undefined
                      lui2004
                      today i have changed the bed and all is flat
                      now,what i do first before i start print?
                      G29 S1 ; Load Mesh
                      G32 to Level the 2 independend Z-Motors
                      and the start print is correct ? if yes my prints starts over the air if do this
                      • fcwiltundefined
                        fcwilt @lui2004
                        @lui2004
                        Well for my DBOT equipped with 3 Z-axis steppers and I am leveling the bed and/or creating the height map as separate operations via Macros
                        For printing I:
                        • warm the bed and extruder heater for several minutes
                        • home all
                        • set the "Z=0 Datum" using the Z-probe
                        • load the height map
                        • begin print
                        • lui2004undefined
                          lui2004
                          for Simplify3d in Endscript is the code like this ?
                          G28 ; home all axis
                          G1 X110 Y110 ; Go to Center
                          G30 ; Z=0 Datum
                          G29 S1 ; Load Mesh
                          • fcwiltundefined
                            fcwilt @lui2004
                            @lui2004
                            The only gcode I have in S3D is to use M98 to invoke two macros, print_begin.g and print_end.g
                            • lui2004undefined
                              lui2004
                              Hi
                              i have never used macros, can you explain me ho to use it ?
                              thanks a lot for your help
                              grizewaldundefined 1 Reply Last reply Reply Quote 0
                              • grizewaldundefined
                                grizewald @lui2004
                                @lui2004 said in have problems with mesh bed leveling:
                                Hi
                                A macro is just a file containing G-codes. You use M98 P"macro filename" to run a macro by name.
                                They are great for putting the code for a specific function which you might want to run from various places in one file so there's only one file to edit when you need to change things.
                                For example, you could have the code needed to home your X, Y and Z axes repeated in both homeall.g and the individual home macros. Or, you could just call the individual home macros from homeall.g
                                • lui2004undefined
                                  lui2004
                                  ok nice !
                                  for example for z=Datum
                                  Zdatum.g
                                  G1 X110 Y110 ; Go to bed center
                                  G30 ; Probe once
                                  and then i can insert in Simplify3d in Startscript
                                  M98 Zdatum.g
                                  is it correct ?
                                  infiniteloopundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                                  • infiniteloopundefined
                                    infiniteloop @lui2004
                                    is it correct ?
                                    You're very close:
                                    M98 P"Datum.g"
                                    • lui2004undefined
                                      lui2004
                                      yeah i will do my best ,i will learn 😉
                                        infiniteloop
                                        @infiniteloop said in have problems with mesh bed leveling:
                                        You're very close:
                                        ... as was I. Let's try it again:
                                        M98 P"Zdatum.g"
                                        Sorry.
                                        • fcwiltundefined
                                          fcwilt @lui2004
                                          M98 Zdatum.g
                                          As stated by the other poster your syntax is not quite correct.
                                          But consider the approach of having just two calls in S3D to macros that do everything you need to start printing and to finish printing.
                                          That those macro can call other macros if that makes things easier.
                                          My goal is to minimize changes I have to make in S3D and keep all the changes in the Duet.
