Using Duet 3Mainboard with external stepper drivers
34
3.0k
    T3P3Tony administrators @FBG
    @fbg you can add a lot of expansion boards. If we decide to put 3 external driver connections on each then potentially up to 8 of those expansion boards = 24 drivers!
    undefined 1 Reply Last reply 18 Aug 2019, 11:01 Reply Quote 0
      FBG @T3P3Tony
      @t3p3tony No words.... incredible
        mpentenr @dc42
        @dc42 Are there any news on this topic ?
        undefined 1 Reply Last reply 18 Oct 2019, 14:36 Reply Quote 0
          dc42 administrators @mpentenr
          @mpentenr said in Using Duet 3Mainboard with external stepper drivers:
          Not yet. Now that we have the prototype Tool Board, there are two ways we could support external drivers without needing a new main board:
          1. Do a version of the EXP3HC board with outputs for 3 or just possibly 4 external stepper drivers instead of on-board drivers. This would probably be best for those who are actually using external drivers, not step-servo motors. But we don't expect many people to need external drivers with Duet 3.
          2. Do a version of the Tool Board that has a single set of step/dir/enable outputs, to drive a single external driver or step-servo drive. I think this might be better for those using step-servo motors with built-in controllers.
          undefined 1 Reply Last reply 18 Oct 2019, 15:30 Reply Quote 0
            mpentenr @dc42
            @dc42 said in Using Duet 3Mainboard with external stepper drivers:
            That would be my favorite, because of my 2pt100(bed) and 3K-Type Thermocouple (Pellet Extruder) which I cant connect to the tool board or is it possible to use thermo connectors on one board and step/dir/ena on another board for one "axis/extruder"? I also would need 2 of these boards, because of the 3 (X/Y/Z)axis with external drivers and up to 3 external drivers for the (pellet)extruders.
            1. Do a version of the Tool Board that has a single set of step/dir/enable outputs, to drive a single external driver or step-servo drive. I think this might be better for those using step-servo motors with built-in controllers.
            Please take into account, that the Vin for example for my pellet extruder is 48V, when designing the driverless Tool Board with step/dir/ena output.
            Thanks
            Marc Pentenrieder
              @mpentenr, what motors and drivers do you plan to use on that machine? Although we don't support as much as 48V at present, we are considering making variations of main and/or expansion boards that support up to about 54V. The TMC5160 drivers can take 60V, it's just the voltage regulators we use that limit us to around 35V.
              undefined 1 Reply Last reply 18 Oct 2019, 16:21 Reply Quote 0
                mpentenr @dc42
                @dc42 Hi, on the 3 axis I am using 1KW 380V Servo Motors and on the pellet extruder, I am using the following:
                Motor Driver: https://us.nanotec.com/products/1768-c5-e-2-09-motor-controllerdrive-for-canopen-or-usb/
                Stepper motor: https://us.nanotec.com/products/574-st8918m6708-a/
                  Thanks. Are you using the encoder input on the stepper driver for the pellet extruder? What is the maximum rotation speed needed by the pellet extruder motor? Have you established that you really do need 48V to drive it?
                  undefined 1 Reply Last reply 18 Oct 2019, 16:36 Reply Quote 0
                    mpentenr @dc42
                    No, I am not using the encoder input (at the moment, perhaps I need to).
                    The max rotational speed will be around 500 rpm, because of an 10:1 gearbox on the stepper, so up to 50 rpm at the pelletextruderspindle
                    undefined 1 Reply Last reply 18 Oct 2019, 16:39 Reply Quote 0
                      mpentenr @mpentenr
                      The max rotational speed will be arounf 500 rpm, because of an 10:1 gearbox on the stepper, so up to 50 rpm at the pelletextruderspindle
                      At the moment the pellet extruder is highly experimental, so I don't know the exact values. Time and experiments will show 😉
                        mpentenr
                        Hi dc42, are there any news on driverless duet3 or addon boards for driving motors with external drivers ?!
                        undefined 1 Reply Last reply 10 Feb 2020, 17:24 Reply Quote 0
                          We have a few tool board prototypes modified to drive a single external driver at 5V signals levels. We will turn this into a production item. We still need to lay it out on a PCB, but that shouldn't take long, because the design is based on our Tool Board.
                          We haven't yet made a decision on whether to make a driverless version of the main board.
                            Kyle_55
                            DC42,
                            I would be interested in a driver-less version as well. Don't get me wrong, those 5160's are nice but I already have $200 invested in my hobby CNC's external drivers and when / if I make the switch from the UC100 to the Duet , I will also be getting a Duet wifi for my 3d printer. The thought of spending $400 + on the upgrade while shelving $400 in parts with no use is a real bummer. And I get that an $800 hit is nothing for most, but for a guy just trying to learn a new hobby....
                            Kyle
                              wi10008
                              Hi @dc42,
                              I'm interested in triggering camera exposures that synchronise with the X/Y axis motors. My camera has a 5V logic trigger input. Would the driverless Tool Board work to drive the camera as if it were an extuder?
                              I'd like to use the steps/mm setting as "exposures"/mm.
                              • Danalundefined
                                Danal
                                Yes.
                                But you can do this today. There are plenty of IO ports with outputs. These are 3.3V, but 3.3 V out to 5 V in logic almost always works.
                                You then trigger the camera with M42
                                undefined 1 Reply Last reply 24 Feb 2020, 21:32 Reply Quote 0
                                  dc42 administrators @Danal
                                  @Danal said in Using Duet 3Mainboard with external stepper drivers:
                                  Yes.
                                  On the v1.0 Duet 3 main boards there is also the output marked Laser/VFD, which is 5V.
                                    FBG
                                    Any news about this?
                                    For the moment there are not possibility of connect a external stepper/servo driver?
                                    It is the only thing that blocks me from buying Duet3, and I must continue buying Duet2 with expansion board.
                                    And the Duet3 have important things that i want start to approach immediately.
                                    Best Regards
                                    • alil2096undefined
                                      alil2096
                                      Good orning, any news for this expansion board?
                                      Because I use the duet 2 wifi for 2 external motor..
                                      if even the duet 3 had the possibility to connect I would buy it immediately!
                                      Thanks,
                                      Andrea
                                      www.lillia.net
                                      Facebook page
                                      • nhofundefined
                                        nhof
                                        @dc42 I am also interested in external drivers for Duet 3.
                                        Any update on plans / schedule?
                                        undefined 1 Reply Last reply 29 Apr 2020, 21:28 Reply Quote 0
                                          dc42 administrators @nhof
                                          @nhof said in Using Duet 3Mainboard with external stepper drivers:
                                          The prototype external stepper driver boards were ordered some time ago. They are taking a little longer than usual because both the assembly companies we use had to shut down temporarily in order to rearrange their production lines to facilitate social distancing, and even now are probably operating at reduced capacity. We should be getting them soon.
