    Using Duet 3Mainboard with external stepper drivers
    34
    3.0k
      dc42 administrators @mpentenr
      @mpentenr said in Using Duet 3Mainboard with external stepper drivers:
      @dc42 Are there any news on this topic ?
      Not yet. Now that we have the prototype Tool Board, there are two ways we could support external drivers without needing a new main board:
      1. Do a version of the EXP3HC board with outputs for 3 or just possibly 4 external stepper drivers instead of on-board drivers. This would probably be best for those who are actually using external drivers, not step-servo motors. But we don't expect many people to need external drivers with Duet 3.
      2. Do a version of the Tool Board that has a single set of step/dir/enable outputs, to drive a single external driver or step-servo drive. I think this might be better for those using step-servo motors with built-in controllers.
      mpentenrundefined 1 Reply Last reply Reply Quote 0
      • mpentenrundefined
        mpentenr @dc42
        @dc42 said in Using Duet 3Mainboard with external stepper drivers:
        That would be my favorite, because of my 2pt100(bed) and 3K-Type Thermocouple (Pellet Extruder) which I cant connect to the tool board or is it possible to use thermo connectors on one board and step/dir/ena on another board for one "axis/extruder"? I also would need 2 of these boards, because of the 3 (X/Y/Z)axis with external drivers and up to 3 external drivers for the (pellet)extruders.
        1. Do a version of the Tool Board that has a single set of step/dir/enable outputs, to drive a single external driver or step-servo drive. I think this might be better for those using step-servo motors with built-in controllers.
        Please take into account, that the Vin for example for my pellet extruder is 48V, when designing the driverless Tool Board with step/dir/ena output.
        Thanks
        Marc Pentenrieder
          @mpentenr, what motors and drivers do you plan to use on that machine? Although we don't support as much as 48V at present, we are considering making variations of main and/or expansion boards that support up to about 54V. The TMC5160 drivers can take 60V, it's just the voltage regulators we use that limit us to around 35V.
          • mpentenrundefined
            mpentenr @dc42
            @dc42 Hi, on the 3 axis I am using 1KW 380V Servo Motors and on the pellet extruder, I am using the following:
            Motor Driver: https://us.nanotec.com/products/1768-c5-e-2-09-motor-controllerdrive-for-canopen-or-usb/
            Stepper motor: https://us.nanotec.com/products/574-st8918m6708-a/
              Thanks. Are you using the encoder input on the stepper driver for the pellet extruder? What is the maximum rotation speed needed by the pellet extruder motor? Have you established that you really do need 48V to drive it?
              • mpentenrundefined
                mpentenr @dc42
                No, I am not using the encoder input (at the moment, perhaps I need to).
                The max rotational speed will be around 500 rpm, because of an 10:1 gearbox on the stepper, so up to 50 rpm at the pelletextruderspindle
                • mpentenrundefined
                  mpentenr @mpentenr
                  The max rotational speed will be arounf 500 rpm, because of an 10:1 gearbox on the stepper, so up to 50 rpm at the pelletextruderspindle
                  At the moment the pellet extruder is highly experimental, so I don't know the exact values. Time and experiments will show 😉
                  • mpentenrundefined
                    mpentenr
                    Hi dc42, are there any news on driverless duet3 or addon boards for driving motors with external drivers ?!
                      We have a few tool board prototypes modified to drive a single external driver at 5V signals levels. We will turn this into a production item. We still need to lay it out on a PCB, but that shouldn't take long, because the design is based on our Tool Board.
                      We haven't yet made a decision on whether to make a driverless version of the main board.
                      • Kyle_55undefined
                        Kyle_55
                        DC42,
                        I would be interested in a driver-less version as well. Don't get me wrong, those 5160's are nice but I already have $200 invested in my hobby CNC's external drivers and when / if I make the switch from the UC100 to the Duet , I will also be getting a Duet wifi for my 3d printer. The thought of spending $400 + on the upgrade while shelving $400 in parts with no use is a real bummer. And I get that an $800 hit is nothing for most, but for a guy just trying to learn a new hobby....
                        Kyle
                        • wi10008undefined
                          wi10008
                          Hi @dc42,
                          I'm interested in triggering camera exposures that synchronise with the X/Y axis motors. My camera has a 5V logic trigger input. Would the driverless Tool Board work to drive the camera as if it were an extuder?
                          I'd like to use the steps/mm setting as "exposures"/mm.
                          • Danalundefined
                            Danal
                            Yes.
                            But you can do this today. There are plenty of IO ports with outputs. These are 3.3V, but 3.3 V out to 5 V in logic almost always works.
                            You then trigger the camera with M42
                              dc42 administrators @Danal
                              @Danal said in Using Duet 3Mainboard with external stepper drivers:
                              Yes.
                              On the v1.0 Duet 3 main boards there is also the output marked Laser/VFD, which is 5V.
                              • FBGundefined
                                FBG
                                Any news about this?
                                For the moment there are not possibility of connect a external stepper/servo driver?
                                It is the only thing that blocks me from buying Duet3, and I must continue buying Duet2 with expansion board.
                                And the Duet3 have important things that i want start to approach immediately.
                                Best Regards
                                • alil2096undefined
                                  alil2096
                                  Good orning, any news for this expansion board?
                                  Because I use the duet 2 wifi for 2 external motor..
                                  if even the duet 3 had the possibility to connect I would buy it immediately!
                                  Thanks,
                                  Andrea
                                  www.lillia.net
                                  Facebook page
                                  • nhofundefined
                                    nhof
                                    @dc42 I am also interested in external drivers for Duet 3.
                                    Any update on plans / schedule?
                                      dc42 administrators @nhof
                                      @nhof said in Using Duet 3Mainboard with external stepper drivers:
                                      The prototype external stepper driver boards were ordered some time ago. They are taking a little longer than usual because both the assembly companies we use had to shut down temporarily in order to rearrange their production lines to facilitate social distancing, and even now are probably operating at reduced capacity. We should be getting them soon.
                                      • drackundefined
                                        drack
                                        I am also wanting to use my duet 3 board for an application that uses hybrid stepper motor drivers. Unfortunately it looks like I will have to use the board on a project that has small enough motors for the onboard drivers until you make an expansion board.
                                          If you want to use a Duet 3 but not wait for the expansion boards, then these https://www.chip45.com/products/sammy-c21-1.0_atmel_smart_arm_sam_module_board_samc21_usb_dual_two_can.php are likely to be an option soon. I already have the firmware build for them and I have a couple on order for testing.
                                            Duet 3 external stepper driver prototype boards have arrived and passed all tests. https://duet3d.dozuki.com/Wiki/Duet_3_Expansion_1XD
                                            jballard86undefined 1 Reply Last reply Reply Quote 1
