Can´t print with extruder 2.
It sounds to me a bit like a problem with the tool definitions and/or active/standby temperature settings. Can you post your config.g file and also your slicer start gcode commands (or the first part of a gcode file up to and including the first few moves).
G90
M82
M106 S0
M140 S30
M190 S30
M104 S210 T1
M109 S210 T1
G28 ; home all axes
G92 E0
G1 E-1.0000 F1800
G1 Z0.180 F1000
; layer 1, Z = 0.18
T1
; tool H0.200 W0.400
; skirt
G1 X135.491 Y138.003 F4800
G1 E0.0000 F540
G92 E0
G1 X138.003 Y135.491 E0.1063 F1800
G1 X138.224 Y135.400 E0.1135
G1 X161.776 Y135.400 E0.8185
G1 X161.997 Y135.491 E0.8256
G1 X164.509 Y138.003 E0.9320M111 S0 ; Debug off
M550 MHCoreXY ; Machine name and Netbios name (can be anything you like)
M551 xxxxx ; Machine password (used for FTP)
;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
;*** Wifi Networking
M552 P0.0.0.0 S1 ; Enable WiFiM555 P1 ; Set output to look like RepRapfirmware
;M575 P1 B57600 S1 ; Comms parameters for PanelDueG21 ; Work in millimetres
G90 ; Send absolute coordinates…
M667 S1 ; switch to CoreXY mode; Axis and motor configuration
M208 X300 Y300 Z440 S0 ; Set axis maxima
M569 P1 S0 ; Drive 1 goes forwards
M569 P2 S0 ; Drive 2 goes forwards
M574 X1 Y2 Z0 S0 ; set endstop configuration (all endstops at high end, active high)
;*** The homed height is deliberately set too high in the following - you will adjust it during calibration
M350 X16 Y16 Z16 E16:16 I1 ; Set 16x microstepping with interpolation
M92 X100 Y100 Z1600 ; Set axis steps/mm
M906 X1200 Y1200 Z1200 E400:400 I30 ; Set motor currents (mA) and increase idle current to 60%
M201 X1000 Y1000 Z100 E2000:2000 ; Accelerations (mm/s^2)
M203 X6000 Y6000 Z800 E12000:12000 ; Maximum speeds (mm/min)
M566 X600 Y600 Z60 E2400:E2400 ; Maximum instant speed changes mm/minute
M84 S30; Thermistors heaters
M143 S260 ; Set maximum heater temperature to 280C
M305 P0 T100000 B4138 C0.0000000000000000 R4700 L0 H0 ; Set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4388 C0.0000000000000000 R4700 L0 H0 ; Set thermistor + ADC parameters for heater 1
M305 P2 T100000 B4388 C0.0000000000000000 R4700 L0 H0 ; Set thermistor + ADC parameters for heater 2
M570 S180 ; Hot end may be a little slow to heat up so allow it 180 seconds
M570 H1 P10 T15
M570 H2 P10 T15
M307 H1 A295.5 C122.8 D9.4 B0
M307 H2 A295.5 C122.8 D9.4 B0; Tool definitions
M563 P0 D0 H1 ; Define tool 0
G10 P0 X0 Y0 ; Set tool 0 axis offsets
G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
;*** If you have a single-nozzle build, comment the next 2 lines
M563 P1 D1 H2 ; Define tool 1
G10 P1 X18 Y0 ; Set tool 1 axis offsets
G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
M92 E154:154 ; Set extruder steps per mm; Z probe and compensation definition
;*** If you have a switch instead of an IR probe, change P1 to P4 in the following M558 command
M558 P1 X0 Y0 Z0 H3 F300 T12000 ; Z probe is an IR probe and is not used for homing any axes
G31 X0 Y0 Z1.39 P500 ; Set the zprobe height and threshold (put your own values here);*** If you are using axis compensation, put the figures in the following command
M556 S78 X0 Y0 Z0 ; Axis compensation hereT0 ; select first hot end
OK This is how it looks to me. In your config.g you have two tools, P0 and P1 and the operating and standby temperatures are set to 0 deg C for both tools (G10 P0 S0 R0 and the same for P1). That's fine because you don't want the tool to start heating as soon as you turn the machine on. Now in the start gcode you heat tool 1 (M109 S210 T1) but not tool 0. So when you switch to tool 0, it'll wait until it reaches 0 degC because that is what the operating (active) temperature is set to in your config.g and there isn't another command to override it.
So, what you need to do set the operating and standby temperatures for both tools in you start gcode. You could set them both the same i.e G10 P0 S210 R210 and G10 P1 S210 R210. If you do that, then when you change tools it will continue to print with no delay. However, you may find that you get filament oozing form the tool that isn't in use. So what most people do is set the standby temperature lower to (say 170) or whatever temperature you can use with no oozing. Then when you change tools, there will be a delay while the new tool heats up from standby (170) to active (210) then it will continue to print.
Finally, you should add G10 P0 S-273 R-273 (or just 0) and G10 P1 S-273 R-273 to your end gcode to reset the active and standby temperatures at the end of the print.
HTH
Just one more thing. I'm assuming you gcode file switches between T1 and T0. Not T1 and T2 because you haven't got a T2. By default the first tool in firmware is T0, the second T1, etc but many slicers use T1 for the first tool and T2 for the second. You change the behaviour of the firmware by using M563 S1 which effectively add 1 to every tool number. Then you can use T1 and T2 in you gode files but otherwise you need to use T0 and T1.
Tried this and it didn´t work.
And since I thought that I had something wrong in my toolchanging files I deleted these and just using extruder 2 (T1) at the moment, I have no T0 (Extruder 1) command anywhere right now just T1(even changed the last row in config to T1)
And still the same problem. -
OK so it looks like it isn't to do with tool changes. As I understand it from your first post, the tool heats OK, it starts to print and then it freezes and the web display shows the print progress as 100%, as if the print has finished. This only happens with T1 and never with T0, is that correct?
Yes that's correct, never happens with T0, have had many successed prints when only using T0. I'm now trying with exactly the same g code, just changed T0 to T1 and the problem occurred
Is it possible there is a T0 command somewhere later in the Gcode?
Also does it freeze at eactly the same point each time?
searched the whole code no T0, freezes at the same point every time, freezes on a normal G1 movement.
It could indicate a short in the extruder 1 or heater 2 wiring. Does heater 2 show a stable temperature?
When the print freezes, do the axes show as no longer homed in DWC? This would indicate that the Duet is resetting. If so, run M122 to see the last reset time and reason.
And yet if you run the same G-code with the initial T1 replaced with T0 it works fine?
Can you replicate this working with T0, not working with T1 on a different gcode file?
Is there anything other than a reset that could cause the print progress to go to 100%? If not, then I guess it has to be wiring issue on T1 that is triggering the reset, so a short or some such?
Heater 2 is showing a stable temperature.
When freezing the whole webinterface freezes, can´t do anything (and all axis show homed)Just tried an other g code with the same problem, working with T0 but not with T1, this time it freezes by the first layer doing the first G1.
The privious file froze at layer 4 -
(with the board powered down)
try swapping T0 and T1 and see if the fault moves or stays the same.
If there is a short this must be on the board, since I have tried switching the heaters/thermistors on the board.
Both heaters works as T0 but not T1 -
Tried to run one of the g codes that crashed earlier once more, this time manually line by line in the web interface and surprisingly it didn´t crash.
How can it be that everything freezes when I run the code in auto and not when I run it manually row by row? -
The buffer for the gcode may have a glitch,
Now it actually happened with T0 as well (for the first time), crashed with five layers remaining at a five-hour spiral vase print.
I'm going nuts, what can cause these crashes?
As I´ve said before, it happens every time with T1 but almost never with T0 (this was the first).
I can´t see anything wrong in the config or g codes (but I´m no expert needs to be said).
And I don´t think that it´s a wiring issue since the problem follows that extruder that is connected as T1 on the board.
Anyone else that experience mid-print faults, that might have a solution to my problem?
Could it be something wrong with my board? -
Could it be something wrong with my board?Please explain what you mean by "crashes". Does the board reset? Run M122 to find out. If the "Last reset time" corresponds to when the print stopped unexpectedly, instead of before you started the print, tell us what it shows for "Last reset reason" and "Last software reset code".
With crashes I mean that everything freezes, web interface showes 100% progress and then everything freezes.
I have noted that if I wait a couple of seconds then I´m able to disconnect and then reconnect and when I run M122 these are the resets codes:
Last reset 00:00:11 ago, cause: software
Last software reset code: 0x5004, available RAM 24636 bytes (slot 0)
