    Connecting multiple Z probes for multiple independent Z axis
    1.7k
      dc42 administrators @georgepaul
      @georgepaul said in Connecting multiple Z probes for multiple independent Z axis:
      what about on the hardware side... where can i put the additional probe pins?
      On Duet 2 you can connect digital-output Z probes to any endstop input as well as to the Z probe connector. On Duet 3 you can connect them to any of the nine IO_x connectors.
      • georgepaulundefined
        georgepaul
        so even a capacitive probe, working on 12V will not harm the Duet if the signal pin of probe is connected to any endstop STP pin.
        • Vetiundefined
          Veti
          only on a duet2 v1.04 and up
            georgepaul
            mine says;
            M115
            FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.0(RTOS) ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2018-06-05b3
            so I guess it's not compatible!
            • Vetiundefined
              Veti @georgepaul
              @georgepaul
              the firmware can not see which hardware revision you have, at those changes are independant of the firmware.
              its printed on the pcb
                georgepaul
                ok then im safe... my hardware says Duet2 V1.04... yippie🤗
                  georgepaul
                  Ok so i did connect a Zprobe and got it working. I made the following changes and it worked for the NPN inductive sensor that I scavenged.
                  I made the following wiring. I used the IN4007 because i dint have anything else on me.
                  The following config changes were done;
                  **; Endstops
                  M574 X1 Y1 U1 S0 ; Set active low and disabled endstops
                  M574 Z1 S2
                  M558 P1 I1 H5 F120 T6000
                  M557 X25:0 Y25:0 S20 ; Define mesh grid**
                  and it worked fine.
                    georgepaul
                    Then i tried using theProbe for the U axis and i made this tiny change in the config.g file;
                    M574 X1 Y1 Z1 S0 ; Set active low and disabled endstops
                    M574 U1 S2
                    And that too worked fine
                      georgepaul
                      my doubt is whether this can be done;
                      and if i wanted to connect two probes can one more be connected in the E0 endstop STP pin for the U axis?
                        georgepaul
                        i am just making sure i don't fry the board by doing something wrong😇
