    3D GCode Viewer integrated with DWC
    Duet Web Control wishlist
    42
    284
    31.1k
    • Sindariusundefined
      Sindarius
      I have a branch set up here for anyone interested in playing with this.
      https://github.com/Sindarius/DuetWebControl/tree/3DViewer
      and you can download a test version from here
      https://juan-rosario.com/DuetWebControl.zip
      I brought this up to date with the new master.
      • JoergS5undefined
        JoergS5
        This is really great, please keep going!
          Sindarius
          I've been playing around with the code a little bit while I wait for a plugin system to be put in place. Recently added the ability to change the bed size and have the release on GitHub for anyone who wants to play with this. I use it fairly often at this point.
          https://github.com/Sindarius/DuetWebControl/releases
          hestiahuangundefined 1 Reply Last reply Reply Quote 3
            Sindarius
            Forgot to mention that I am looking at adding a toggle to move the layer height slider based off the current print height this weekend hopefully.
            • Exerqtorundefined
              Exerqtor
              Awesome! This is getting installed right after the ongoing print is done for sure!
              Hope it get's integrated to the master asap!
              • AS-3D Druckundefined
                AS-3D Druck
                This is awesome
                Is this Client or DWC based?
                Best regards
                AS-3D Druck / Andre
                Sindariusundefined 1 Reply Last reply Reply Quote 0
                  Sindarius @AS-3D Druck
                  @AS-3D-Druck this is DWC based. Opens a new browser window to launch the 3D viewer but no special installation beyond the branch I have with it integrated.
                  AS-3D Druckundefined 1 Reply Last reply Reply Quote 0
                    AS-3D Druck @Sindarius
                    @Sindarius Ok, what i tryed to say is does it get calculated by a Script on the Client or Duet Side?
                    Best regards
                    AS-3D Druck / Andre
                      @AS-3D-Druck itโ€™s javascript based so it is client side. The viewer downloads the file and renders it.
                      AS-3D Druckundefined 1 Reply Last reply Reply Quote 1
                        @Sindarius Cool so it can be used even during a print Job right?
                        (without negative effecting the print Job)
                        Best regards
                        AS-3D Druck / Andre
                          @AS-3D-Druck I use it while printing all the time. Only one Duet based printer at the moment ๐Ÿ™‚ the file download doesnโ€™t impact the print from what I have seen.
                          • Exerqtorundefined
                            Exerqtor
                            Have you tried it with DWC 2.0.4 btw? I see that it's still realeased based on 2.0.0 ?
                            Sindariusundefined 2 Replies Last reply Reply Quote 0
                              Sindarius @Exerqtor
                              @Exerqtor Iโ€™ll look into updating the baseline with the latest. My changes on the DWC itself are very minimal. Just what is necessary to make the 3D Viewer link in the gcode list
                                Sindarius @Exerqtor
                                @Exerqtor I have a release that is now updated to 2.0.4
                                Exerqtorundefined 1 Reply Last reply Reply Quote 0
                                • Exerqtorundefined
                                  Exerqtor @Sindarius
                                  @Sindarius
                                  Yeah i got the notification from Github earlier! ๐Ÿ˜ƒ
                                  Just installed it, and it works but the extruder colors don't apply to the renders for some reason. There static gray (just tried with single extruder slices so far) no matter what i change the colors to.
                                    Sindarius @Exerqtor
                                    @Exerqtor This could be one of two things.
                                    1. After you change the extruder colors are you hitting the "Reload Scene" button?
                                    2. In the menu under stats if it switches from Mesh Rendering to Line Rendering the model is probably too large so it switches to line render mode which does not show the colors very well. This is something I plan to revisit to see if I can make the line colors a little more pronounced.
                                    Edit
                                    There is a 3rd possibility that I need to double check. It's possible that there is no T# call anywhere in the gcode for single extruder prints which may be throwing off what extruder it should be using.
                                    Edit 2
                                    It was the 3rd possibility. If there is no tool selected or M567 it will default to Extruder 0 in the next build.
                                    • Exerqtorundefined
                                      Exerqtor @Sindarius
                                      @Sindarius
                                      Yeah i've tried to "Reload Scene" a couple times, also closing the 3D viewer and opening it again.
                                      It's on Mesh Rendering to with T# defined in the gcode several places. ๐Ÿ˜“
                                        Sindarius @Exerqtor
                                        @Exerqtor What slicer did you use and can you get me the gcode so I can dig into it?
                                        • Exerqtorundefined
                                          Exerqtor @Sindarius
                                          @Sindarius
                                          It's sliced with S3D 4.1.2, sure here you go:
                                          https://mega.nz/#!cR1jXLRA!9eZoYY-lZ7a8RdKR87jEwkwRBLeF4Bmy5oPojnggE1g
                                          I've tried several gcodes and the same happens in all of them.
                                            Sindarius @Exerqtor
                                            @Exerqtor Thanks, I'll take a look at it!
