    3D GCode Viewer integrated with DWC
    Duet Web Control wishlist
    42
    284
    30.5k
    • robmundefined
      robm
      Would be especially nice if can link to current layer being printed.
      Sindariusundefined 1 Reply Last reply Reply Quote 0
      • john parkundefined
        john park @Sindarius
        @sindarius Whoa... awesome !!
        • Nuramoriundefined
          Nuramori
          This is the only thing I was missing from octoprint. Having the gcode viewer would close the door on my need for it. .
          • Sindariusundefined
            Sindarius @robm
            @robm That's something I am looking at adding later, my main concern was making sure that I could get a good view working.
              Sindarius @Eumldeuml
              @eumldeuml I do a lot of multi-material & color mixing printing and one of the biggest problems I have is knowing how the extruders or m567 was setup on the print. Also this gives me the opportunity to setup the filament colors on each of the extruders to get an approximation of what the final result will roughly look. The code I wrote supports T# tool changes and M567 extruder %'s. Beyond that sometimes it's nice to see what you're about to print 🙂
              Eumldeumlundefined 1 Reply Last reply Reply Quote 1
              • Eumldeumlundefined
                Eumldeuml @Sindarius
                @sindarius I understand! Sounds very practical for your purposes 🙂
                • TLASundefined
                  TLAS
                  Great implementation, well done.
                  Gave me a though I might start another thread in - why not incorporate a slicer in at this point? You’ve got the 3D viewer, and on a pi, you could fairly easily run a slic3r program in the background from the server.
                  Thoughts?
                  • JimPBarberundefined
                    JimPBarber
                    That is too awesome! Yes, Yes, Yes.....
                      Sindarius
                      I have a branch set up here for anyone interested in playing with this.
                      https://github.com/Sindarius/DuetWebControl/tree/3DViewer
                      and you can download a test version from here
                      https://juan-rosario.com/DuetWebControl.zip
                      I brought this up to date with the new master.
                      • JoergS5undefined
                        JoergS5
                        This is really great, please keep going!
                          Sindarius
                          I've been playing around with the code a little bit while I wait for a plugin system to be put in place. Recently added the ability to change the bed size and have the release on GitHub for anyone who wants to play with this. I use it fairly often at this point.
                          https://github.com/Sindarius/DuetWebControl/releases
                          hestiahuangundefined 1 Reply Last reply Reply Quote 3
                            Sindarius
                            Forgot to mention that I am looking at adding a toggle to move the layer height slider based off the current print height this weekend hopefully.
                            • Exerqtorundefined
                              Exerqtor
                              Awesome! This is getting installed right after the ongoing print is done for sure!
                              Hope it get's integrated to the master asap!
                              • AS-3D Druckundefined
                                AS-3D Druck
                                This is awesome
                                Is this Client or DWC based?
                                Best regards
                                AS-3D Druck / Andre
                                  Sindarius @AS-3D Druck
                                  @AS-3D-Druck this is DWC based. Opens a new browser window to launch the 3D viewer but no special installation beyond the branch I have with it integrated.
                                  AS-3D Druckundefined 1 Reply Last reply Reply Quote 0
                                    AS-3D Druck @Sindarius
                                    @Sindarius Ok, what i tryed to say is does it get calculated by a Script on the Client or Duet Side?
                                    Best regards
                                    AS-3D Druck / Andre
                                      @AS-3D-Druck it’s javascript based so it is client side. The viewer downloads the file and renders it.
                                      AS-3D Druckundefined 1 Reply Last reply Reply Quote 1
                                        @Sindarius Cool so it can be used even during a print Job right?
                                        (without negative effecting the print Job)
                                        Best regards
                                        AS-3D Druck / Andre
                                          @AS-3D-Druck I use it while printing all the time. Only one Duet based printer at the moment 🙂 the file download doesn’t impact the print from what I have seen.
                                          • Exerqtorundefined
                                            Exerqtor
                                            Have you tried it with DWC 2.0.4 btw? I see that it's still realeased based on 2.0.0 ?
                                            Sindariusundefined 2 Replies Last reply Reply Quote 0
