Attempt to move motors when VIN is not in range
It's a little hard to see in the photos, but what LEDs are illuminated?
What happens if you disconnect the USB cable?
@Phaedrux VIN, 5v, 3.3V, X stop, Y stop, Z stop, USB power, Diag, and ESP.
When I disconnect USB only VIN says lit
That multi meter is showing minus 13.07.
@deckingman Probably cause I miswired the multimeter. If I flip the VIN and GND the reading says 0
@nerdiator said in Attempt to move motors when VIN is not in range:
that doesnt seem right.
@nerdiator So Vin is either minus 13 or zero?
@nerdiator, check the 7.5A fuse.
@deckingman If I flip the wires then it reads 0.
@dc42 Will do when I get home. Where is this fuse?
@nerdiator Its Heater and Stepper Fuse. https://duet3d.dozuki.com/Wiki/Hardware_Overview
@aidar Ah yeah both fuses are blown. I'll try later with new ones
