Dead Duet Wifi
4.3k
    crc1337
    It seems my Duet Wifi has decided to give up the ghost. The PanelDue is no longer able to connect to it and I'm not able to connect to it over USB or Wifi. I've disconnected everything from the board, pulled it out of the machine and powered it via USB and still can't get any response from it. The two LEDs on either side of the usb connector light up solid, as do the 3.3v and 5v ones. I've checked the SD card, it's ok. I've commented out wifi, per the instructions on the wiki. Is there anything else I should try? How do I go about getting a replacement?
      InSanity
      You didn't hit the reset button by accident by chance ? Does it show up as a USB device at all when you plug it in , that nice little sound you get when plugging in USB devices ?
      Edit: Meant to say Erase button.
      Jeff
      Duet WiFi Powered FFCP with E3D legends hotend system. BLTouch grid leveling.
        crc1337
        Nope. I've tried the reset button (not the erase button), it seems to do absolutely nothing. It doesn't show up as a USB device and there is no sound when I plug it in.
          ShadowX
          You might have hit the "erase" button that cleared the firmware. Follow the instructions on installing the firmware using SAM-BA and it might come back to life (backup procedure #3).
          https://duet3d.com/wiki/Updating_main_firmware
          BTW. I think that erase button is the dumbest idea. It should use jumpers similar to clearing CMOS on a computer so people never accidentally hit that button. Putting that button next to the reset button is just asking for it to pressed by accident.
            crc1337
            Thanks, I'll give it a try and report back.
              crc1337
              Yeah, so this doesn't work since the USB device isn't being recognized. I've tried on two different machines.
                ShadowX
                Did you hit the "erase" button and then the "reset" button while its connected to the USB (to supply power to the board only).
                  crc1337
                  Unfortunately, yes. This seems to have no effect.
                  I would love to know what happened to the board. I've checked and rechecked my wiring. The board has been running in this machine for several months with no real issues. This morning I installed a new extruder and stepper, but the machine was actually running fine afterward and was all closed up at when it died. I had run through a few calibration runs with the new extruder and was getting ready to try a test print when it died.
                    Have you read https://duet3d.com/wiki/What_to_do_if_your_Duet_or_Duet_WiFi_won%27t_respond ?
                      T3P3Tony administrators
                      @ShadowX:
                      Indeed. I did the design when we still did not know how well the whole upload&flash over network would work and wanted to be able to get to it from the edge of the board in an installed position in case we needed to manually erase before each firmware reflash. #hindsight
                        crc1337
                        @dc42:
                        Yes, I have gone through all of those steps. I will try the last step one more time this evening, but I'm fairly certain I did hold down the erase button for a few seconds followed by a reset at some point while I was troubleshooting yesterday.
                          Are the LEDs correctly lit? Is the microcontroller chip getting hot?
                            crc1337
                            The LED's are correctly lit - the 3.3v and 5v are lit in addition to the two LEDs directly on either side of the USB connector. The only thing I noticed getting warm to the touch was the wifi module, but I'll be able to verify that again in a couple of hours.
                              crc1337
                              Just to confirm, the micro is not getting warm. The wifi module does, however, get quite warm (I don't recall whether or not this was the case before). I also re-checked the Erase then Reset procedure, and that is a no-go. At this point I'm just going to get a new board on order tomorrow as I need to get the machine back up and running. Still, I'd feel a lot better about putting in the replacement if I knew exactly what happened to this one.
                                It's normal for the WiFi module to get warm.
                                I'm wondering whether the USB cable is faulty. Have you tried another one?
                                  crc1337
                                  Yes I had the same thought last night so I tried another one, same result.
                                    I think it's time for you to ask your supplier for a replacement under warranty.
                                      InSanity
                                      I assume you guys will be doing autopsies on the dead Duet's to see what killed them ? Not a simple task that I know, but perhaps a pattern will emerge.
                                      Jeff
                                        elmoret
                                        Yes, they're all being returned to T3P3. Worth noting that the current failure rate is 3% - and some of those may have been caused by issues outside the Duet itself such as wiring or user error.
                                          InSanity
                                          @elmoret:
                                          Probably would have been nice to see some TVSS, MOV's, etc. in certain areas to try and keep problems down. I know the micro has some very limited protection against static and such, but it's not much. I think the biggest problem will be people with bad wiring on motors tossing hundreds or thousands of volt spikes around and perhaps inducing voltages into endstop wires, thermistors, etc. I killed my micro , I know how I did and I replaced the chip…no biggie, I've also seen some really stupid videos on You-Tube on how to crimp wires, if people follow some of these "tutorials" I can see failure rates increasing.
                                          Edit: Not a reflection on the OP.
                                          Jeff
                                          5 out of 29
