    Configuring RepRapFirmware SCARAPrinter
    394
    • JoergS5undefined
      JoergS5 @Mauxx
      @Mauxx An additional idea: microstepping means low torque. I don't know how you realized your gear (does it have a hight friction?), but maybe at this position the torque is too low or friction too high for an angle change and the change "drags on" and produces the curve. You could try setting the steppers to full step to test it.
      Mauxxundefined 1 Reply Last reply Reply Quote 0
      • Mauxxundefined
        Mauxx
        @JoergS5 thank you for answer me
        I change H in S in homing config
        But the motorstepping should be right
        I have both arm of 200mm and 1/32
        Printer work bad only in centre of area, seem that Distal joint doesn't move when draw central cube
        • Mauxxundefined
          Mauxx @JoergS5
          @JoergS5 Tomorrow i'll try your advice
          Thank you!!!
          • Mauxxundefined
            Mauxx @JoergS5
            @JoergS5 nonsquare object work nice
            • JoergS5undefined
              JoergS5 @Mauxx
              @Mauxx I don't understand "nonsquare object work nice", do you mean it is ok in the middle?
              What do you mean by Distal joint doesn't move: is the force of the stepper too low or is it a software problem? Could you make an image of the arms, hinges and gears?
              • Mauxxundefined
                Mauxx
                @dc42 could be a kinematic problem?
                • JoergS5undefined
                  JoergS5 @Mauxx
                  @Mauxx I think the algorithms in the firmware are correct, they are simple trigonometric functions. No place for errors IMHO. I expect wrong measurement in arm length, angle or similar (maybe a hinge with play). So I could have an idea if I see your printer arms, hinges, gears.
                  • oliofundefined
                    oliof
                    Are those G0 or G1 moves? IIRC, some point-to-point gcode is not interpreted as a straight line in SCARA mode.
                    • Mauxxundefined
                      Mauxx
                      G1 moves
                      But in the picture i put 3 cube in print with Simplify3D and the only one not square is in the axis
                      • Mauxxundefined
                        Mauxx
                        Tomorrow i'll make some video, so you understand better
