    Home all not working
    2.0k
      deckingman @Corexy
      @Corexy In your homeall, after the G30, you have G1 S2 Z5 F100. Take out the S2 because Z has already been homed (and you should be using H2 in any case).
      Basically, unless have M564 H0 anywhere, the default behaviour is that you can't make any G1 moves unless the axis you are trying to move has been homed. So in our homing files, where we want to move say Z, before homing X or Y, we have to use an H2 to allow that Z axis move. Then we can use H1 to move the other (X or Y) axes and sense when the end stop has triggered. But as soon as that happens, that axis is then flagged as homed. So any subsequent moves after the initial H1 move for that axis can simply be G1 without any S or H parameters.
      To edit you homing homing files, use any text editor. Notepad++ is a good one and it's free.
      • Corexyundefined
        Corexy
        Cheers guys,
        So is there any harm in me just copying my old files (config.g, homeall.g, etc) across to my new SD card?
        Is it only the firmware that gets updated?
          deckingman @Corexy
          @Corexy said in Home all not working:
          Cheers guys,
          No. There is no harm in copying your old files to a new SD card. Make sure that you put them in the right folder of the SD card - (config and homing files go in the .sys folder).
          Actually, given that SD cards aren't the most reliable storage media (as well as the fact that they are easily lost), what I do is keep everything in a folder on my PC which has exactly the same structure as the SD card. This folder is backed up to a NAS and also to cloud storage. So I always have a (backed up) working copy of the contents of my SD card on my PC. Then if I want to change anything or edit a file, I do it on my PC and upload it to the SD card (or remove the SD card, put it in my PC and copy across).
          Edit. To elaborate - initially I copied the entire contents of my SD card to a new folder on my PC. This is the folder that I modify as required then transfer any changes to the SD card.
          • Corexyundefined
            Corexy
            @deckingman
            So that didn't go so well...
            I've put my old config.g file on the SD card, and now it's all pretty much unresponsive.
            I've got 2000 degC on my extruder temp, yet my M305 is set to "X200" for a PT100 sensor.
            The wifi module does not start when I turn the machine on, I can only activate it with YAT, then it works fine.
            When I activate it through YAT and connect to the DWC, I see I've got the following firmware:
            DWC 2.0.4
            Firmware 2.04
            Duet wifi version 1.23
            The machine does not respond to any movement commands at all now, which is strange as this is the exact config.g file I've used for years on this same machine.
            Pretty stressful this...
            Here's my config.g file as it stands right now:
            ; Configuration file for Duet WiFi
            ; generated by RepRapFirmware Configuration Tool on Sat Oct 22 2016 18:28:19 GMT+1100 (AUS Eastern Daylight Time)
            M111 S0 ; Debugging off
            G21 ; Work in millimetres
            M555 P2 ; Set firmware compatibility to look like Marlin
            M208 X195 Y195 Z175 S0 ; Set axis maxima
            M557 X20:180 Y20:180 S40
            M574 Z0 S0 ; Define active low and unused microswitches
            M574 X1 Y1 S1 ; Define active high microswitches
            M558 P1 X0 Y0 Z1 H5 F600 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
            G31 P500 X0 Y0 Z2.4 ; Set Z probe trigger value, offset and trigger height
            M569 P3 S0 ; Drive 3 goes backwards
            M350 X16 Y16 Z16 E16 I1 ; Configure microstepping without interpolation
            M92 X80 Y80 Z800 E127 ; Set steps per mm
            M566 X1600 Y1600 Z12 E800 ; Set maximum instantaneous speed changes (mm/min)
            M203 X18000 Y18000 Z1200 E8000 ; Set maximum speeds (mm/min)
            M201 X1200 Y1200 Z20 E1200 ; Set accelerations (mm/s^2)
            M906 X1100 Y1100 Z800 E600 I30 ; Set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M143 S280 ; Set maximum extruder temperature to 280C
            M143 H0 S140 ; Set maximum bed temperature to 140C
            M305 P0 T100000 B4000 C0 R4700 L0 H0 ; Set thermistor + ADC parameters for heater 0
            M305 P1 T100000 B4138 C0 R4700 L0 H0 X200 ; Set thermistor + ADC parameters for heater 1 and remap it to channel 200
            M307 H0 A144.9 C625.3 D1.0 B0
            M307 H1 A999.7 C377.6 D13.5 B0
            M563 P0 D0 H1 ; Define tool 0
            G10 P0 X0 Y0 ; Set tool 0 axis offsets
            T0
            M550 PZortrax M200 ; Set machine name
            M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
            M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
            M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
            M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
            • fcwiltundefined
              fcwilt
              Do you have a Duet WiFi or a Duet Ethernet board?
              The commands you have in your OLD config.g file are trying to enable the network on a Duet Ethernet board.
              I think you may be a "victim" of the configuration tool. By that I mean the config tool sort of shields you from the nitty gritty of the commands needed to get a machine up and running.
              Life gets much easier, printer wise, when you fully grasp the purpose of every line in your config.g file. And a good way to get that education is by constructing your own config.g file with an editor. Just the process of typing it in helps you learn even if you start with a basic config file from some other source and make changes as needed.
              Anyway enough of that - let us know what kind of board you have.
              • Corexyundefined
                Corexy
                Mate that's most kind of you.
                Poor old David and Deckingham have been enduring me for years lol, and I end up in this situation if ever I touch the thing. I do build a very tough and straight printer mechanically by the way, it''s just this stage that takes me down every time.
                I did use the config tool with my json file uploaded into it, and you are correct, I've got a Duet wifi 2. That would explain the connection issues!
                Are you referring to M552? This is what I have now:
                So yes please, tell me what I need to change to correct the connection issues for starters.
                I do appreciate the help I get on here, and my love/hate relationship with this printer is more love than hate.
                • fcwiltundefined
                  fcwilt
                  From the docs for M552:
                  Parameters for Duet 2 WiFi
                  P"ssid" (optional, RepRapFirmware 1.20 and later) SSID of network to connect to. The SSID and password must already have been registered using M587. If this parameter is not present, the Duet 2 WiFi will try to connect to the strongest network that is broadcasting its SSID and whose SSID has been registered using M587.
                  Snnn 0 = disable networking, 1 = enable networking as a client, 2 = enable networking as an access point , -1 = disable WiFi module
                  • Danalundefined
                    Danal
                    Try just "M552 S1", assuming you want the IP assigned by your router.
                    Here's the relevant part of my Duet2 config files:
                    M550 PDanal's BFD               ; Set machine name
                    M551 P                          ; Set password
                    M552 S1                         ; Enable network
                    ;*** Desired SSID is configured manually via M587, once only, do not put M587 in config.g
                    M586 P0 S1                      ; Enable HTTP
                    M586 P1 S0                      ; Disable FTP
                    M586 P2 S0                      ; Disable Telnet
                      In regards to your original problem with G30 S-1, do you by chance have a deployprobe.g and retractprobe.g files in your /sys folder? If so, delete them, and I think your probing problem will be resolved.
                      Did you happen to backup the config files you were working on before reverting to the old ones? Your old firmware was quite old and there are likely several changes that would need to be made to get the old config to work on the new firmware. Mainly that you won't be able to move any axis before it is homed, which also means that your homing files will need to be updated. The new set of config files you got from the configurator would have had all those changes in place already.
                      • Corexyundefined
                        Corexy
                        Guys,
                        I don't know how to multiquote (I think we've established that I'm not the computery type), but these were all very helpful tips, and a couple of problems are now resolved.
                        fcwilt/Danal,
                        Yes, it was just a matter of making it "M552 S1" and it all lights up and connects almost instantly. Very happy, thank you.
                        Phaedrux,
                        Same for you mate, deleted those 2 files and it's homing on all 3 axis's. I haven't time for setting nozzle height right now as I'm headed out. Feeling confident it's more happy now.
                        I did keep backups, but I've gotten all flustered and mixed them all up. When I get this all sorted, I'll back a good copy onto my laptop.
                        I do really appreciate the help I'm getting on here, and thank you all for your time.
                        Of course I've got another post following this one with my next problem...
                        • Corexyundefined
                          Corexy
                          Guys,
                          My next problem seems to be my extruder heater setting.
                          I've got a reading of 2000 degC, but it's also in a purple box, whatever that means?
                          My M305 is set to X200, as I have a PT100 sensor fitted, but the text my have extras added by the configurator. Could you please help me out with this one, as after that I think it's pretty much a case of starting to print.
                          Please see below:
                          T0
                          M552 S1 ; Enable network and acquire dynamic address via DHCP
                            Phaedrux Moderator @Corexy
                            Remove all the T B C R L H stuff and just use M305 P1 X200
                            Corexyundefined 1 Reply Last reply Reply Quote 0
                            • Corexyundefined
                              Corexy @Phaedrux
                              @Phaedrux said in Home all not working:
                              And of course that fixed it, thank you again.
                              As we've had a couple of cases of excessive text causing problems here, do you see any other lines that could be cleaned up? I'm keen to scrape this right back to just what it needs now, as I run the old one with all sorts of extra folders in there, and it did start up fiddly sometimes. I want to make this one dead clean and back it all up on my laptop to avoid this drama moving forward.
                              G31 P500 X0 Y0 Z2.78 ; Set Z probe trigger value, offset and trigger height
                              M305 P1 X200 ; Set thermistor + ADC parameters for heater 1 and remap it to channel 200
                              T0
                                It looks ok otherwise.
                                  droftarts administrators
                                  You don't have an M584 command, which sets the drive mapping. This should be the first command in the "Drives" section. However, you're using the standard mapping (M584 X0 Y1 Z2 E3), so it's not necessary. If you have two Z motors (currently individually connected to ZA and ZB, or wired together) you could split them, which would allow for X gantry levelling. But that might sound difficult to you!
                                  You can remove:
                                  • M111 S0 as debugging is off by default
                                  • G21 as working in millimetres is default
                                  • M555 P2 as compatibility with Marlin is default
                                  I'd move:
                                  • Endstop section to after the Drives section (though it doesn't really matter) and include M208 commands
                                  • Network to the beginning (if any command in config.g causes the config.g to abort, at least you get network!), and put machine name in quotes (good practice for string parameters). You can even remove the M586 commands as HTTP is enabled by default, FTP and Telnet are disabled by default
                                  • Probe settings into it's own section after endstops, and include M557 (bed probing grid).
                                  This should bring most settings into sensible sections, and in order of importance. So it would end up looking like:
                                  M550 P"Zortrax M200" ; Set machine name
                                  M584 X0 Y1 Z2 E3 ; Set drive mapping
                                  T0
                                  Hope that helps!
                                  • Corexyundefined
                                    Corexy
                                    Mate that helps a lot.
                                    I've had visitors for a few days and haven't had a chance to look at this, but I'm assuming this going to be more tidy and efficient?
                                    I'll have to have a look at my bed and homing files as well.
                                    And to be honest I just copied and pasted this in and it's working a treat. Thanks for that!
                                    • Corexyundefined
                                      Corexy
                                      Before I fire this all up again, I haven't done anything with my bed and homing files, and the configurator definitely changed all of them. Before I had it doing a autolevelling routine at the start of a print, and then I had it putting the tool off the the left/back at the end, but I'm pretty sure most of the commands for that are entered in my slicer (S3D).
                                      bed.g
                                      This is what I had before:
                                      ; bed.g
                                      ; Clear any bed transform
                                      G29 S2
                                      ; Home all
                                      G28
                                      ; Probe the bed
                                      G29
                                      ; Absolute positioning
                                      G90
                                      ; Go to center bed probe point and home the Z axis
                                      G1 X97.5 Y97.5 F4800
                                      G30
                                      ; Uncomment the following line to lift the nozzle after probing
                                      G1 Z50 F500
                                      ; bed.g
                                      ; generated by RepRapFirmware Configuration Tool v2.1.2 on Thu Nov 21 2019 10:53:55 GMT+1100 (Australian Eastern Daylight Time)
                                      G29 ; probe the bed and enable compensation
                                      homeall.g
                                      ; homeall.g
                                      ; called to home all axes
                                      ; Relative positioning
                                      G91
                                      ; Lift Z
                                      G1 Z1 F1200
                                      ; Move towards X and Y axis endstops (first pass)
                                      G1 X-200 Y-200 F4800 S1
                                      ; Go back a few mm
                                      G1 X5 Y5 F4800
                                      ; Move slowly to axis endstops once more (second pass)
                                      G1 X-200 Y-200 F360 S1
                                      G90
                                      G30
                                      G1 Z50 F1200
                                      ; homeall.g
                                      ; generated by RepRapFirmware Configuration Tool v2.1.2 on Thu Nov 21 2019 10:53:58 GMT+1100 (Australian Eastern Daylight Time)
                                      G91 ; relative positioning
                                      G1 H1 X-200 Y-200 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                                      G1 H2 X5 Y5 F6000 ; go back a few mm
                                      G1 H1 X-200 Y-200 F360 ; move slowly to X and Y axis endstops once more (second pass)
                                      G90 ; absolute positioning
                                      G1 H2 X97.5 Y97.5 F6000 ; go to first bed probe point and home Z
                                      G1 S2 Z5 F100 ; lift Z relative to current position
                                      I'm wondering if I should be looking at all these as well?
                                        The old bed.g file looks like you could continue using it.
                                        The old homeall.g file lacks the H2 parameter for the initial Z axis lift. This would throw an error in recent firmware for trying to move an axis before it's been homed. But otherwise they are basically the same, so you should probably just keep using the new one.
                                        • Corexyundefined
                                          Corexy
                                          Cheers Phaedrux,
                                          So I might as well just keep using the new bed and homing files? They're the one's it's running at the moment, so if there's no reason to change I won't. Just looking at what can be tidied up before I save a copy of this.
                                          I've also got a "homedelta.g" file in there. Can that be deleted?
                                            Yes If you do not have a delta you can delete it.
