    Scara Problem
    Firmware installation
    2.1k
    • Mauxxundefined
      Mauxx
      @JoergS5 everything works except this thing
      • JoergS5undefined
        JoergS5 @Mauxx
        @Mauxx I have an additional idea: (removed, this was not the reason)
        • Mauxxundefined
          Mauxx
          I try to work with 800x800 area with 0,0 at centre of tower (X-400,X400; Y-400,Y400) and this problem is in all 4 central axis
          Probably you're right, so how i can set my config?
          • JoergS5undefined
            JoergS5 @Mauxx
            @Mauxx is the angle limit a physical limit or can you change the limit in the configuration?
            If it's a physical limit, you could place the printer nearer to an edge and/or further away from the print bed. This should give you a bigger print area.
            For optimal placement I cannot give a recommendation, but it's worth to search, e.g. this document: https://www.researchgate.net/publication/298430720_Optimal_Placement_of_a_SCARA_Robot_-_Lab_Report
            • Mauxxundefined
              Mauxx
              @JoergS5 Yes, max angle is physical limit
              Sorry for my bad english...
              • Mauxxundefined
                Mauxx
                @dc42 have you ever encountered this issue?
                • Danalundefined
                  Danal
                  We've all focused on the stuff happening along X while Y=0.
                  None of that explains what happens at 3:10 or so in the video, the move from X90Y220 to X60Y220 also draws an arc. An arc that falls outside the printable area as specified by M208. None of the joints are anywhere near a limit.
                  • Mauxxundefined
                    Mauxx
                    it's really very strange
                    thank you all for your help!!!
                    • JoergS5undefined
                      JoergS5 @Danal
                      @Danal said in Scara Problem:
                      That's a valid point. Maybe multiple reasons.
                      My ideas for things to analyze:
                      • the communication log of Simplify3D
                      • belt connection between steppers and Axes: maybe slipping or other problem. Slipping belt could explain curves at strange positions. => one more idea: maybe acceleration and speed too high, so belt starts slipping. You can test setting speed and acceleration lower
                      Is it a toothed belt or a non-toothed one? If it doesn't have teeth, you can check whether the belt slips at the stepper pulley when the printer makes a curve. The pulley itself could slip also (pulley on the stepper axis). You use a method which I know as ServoBelt, this produces high tension, needs high torque and may lead to slipping pulley.
                      @Mauxx which Duet hardware, firmware versions are you using?
                      • Mauxxundefined
                        Mauxx
                        Scara give same issue also with Arduino IDE and with RepetierHost draw a Triangle...
                        I'm sure the belt doesn't slip, i have GT2 toothed Belt
                        I'm using RRF Lpc on Skr V.1.3 board
                        When printer draw arc Y motor doesn't move at all
                        JoergS5undefined 2 Replies Last reply Reply Quote 0
                        • JoergS5undefined
                          JoergS5 @Mauxx
                          @Mauxx Maybe the scara code is another one than I checked, because I looked into David's code. Where did you download your firmware RRF LPC code? I will check it then.
                          Mauxxundefined 1 Reply Last reply Reply Quote 0
                          • JoergS5undefined
                            JoergS5 @Mauxx
                            @Mauxx said in Scara Problem:
                            What do you mean with triangle?
                            • Mauxxundefined
                              Mauxx
                              When i start print, instead a cube (only in central area) it draw a triangle (half cube)
                              • JoergS5undefined
                                JoergS5 @Mauxx
                                @Mauxx I don't understand it, do you have an image?
                                But more important is, which software you are using, so I can check the source. Do you use the sdavi CoreLPC4 port?
                                • Mauxxundefined
                                  Mauxx @JoergS5
                                  @JoergS5 Thank you very much!!!
                                  for the moment I own Skr Board but am willing to buy a Duet
                                  I just wanted to verify that everything worked properly
                                  I practically tried all the firmware (marlin, smoothie) and RRF is the best !!!
                                  • Mauxxundefined
                                    Mauxx @JoergS5
                                    @JoergS5 i'm using this https://github.com/sdavi/RepRapFirmware/releases/tag/LPC_RRFv2.04
                                    • JoergS5undefined
                                      JoergS5 @Mauxx
                                      @Mauxx Thanks for the code basis. The included ScaraKinematics seems to be the same like in the official code base, so this is propably not the problem.
                                      One possible reason ... (removed, this was not the reason...)
                                      • Mauxxundefined
                                        Mauxx
                                        So with a Duet Board i will solve this problem? Great!!!☺
                                        Which board do you suggest?
                                        • JoergS5undefined
                                          JoergS5 @Mauxx
                                          @Mauxx I would choose Duet2 Wifi or Ethernet. The new Duet 3 is not needed for the application. The Maestro doesn't have FPU, and floating point algorithms are used in Scara. If you want to experiment a lot in the future, a Duet 3 is an option of course. It is a matter of budget also of course.
                                          I have personally a Duet 2 Wifi and Duet 3+Pi 4 and both are great.
                                          • Mauxxundefined
                                            Mauxx
                                            nice!!!
                                            if you tell me that with duet there's no issues, i trust you
