    Scara Problem
    Firmware installation
    2.1k
    • JoergS5undefined
      JoergS5 @Mauxx
      @Mauxx can you show me what Simplify3D has in his communication window after you made the moves?
      Mauxxundefined 1 Reply Last reply Reply Quote 0
      • JoergS5undefined
        JoergS5 @Mauxx
        @Mauxx Ok. Let's proceed on monday. I'm curious about the reason. I am sure, we will find the reason.
        • Mauxxundefined
          Mauxx @JoergS5
          @JoergS5 i'll show you on monday, when i go in my "lab"
          • Mauxxundefined
            Mauxx @JoergS5
            @JoergS5 I hope!!!
            • Mauxxundefined
              Mauxx
              @JoergS5 everything works except this thing
              • JoergS5undefined
                JoergS5 @Mauxx
                @Mauxx I have an additional idea: (removed, this was not the reason)
                • Mauxxundefined
                  Mauxx
                  I try to work with 800x800 area with 0,0 at centre of tower (X-400,X400; Y-400,Y400) and this problem is in all 4 central axis
                  Probably you're right, so how i can set my config?
                  • JoergS5undefined
                    JoergS5 @Mauxx
                    @Mauxx is the angle limit a physical limit or can you change the limit in the configuration?
                    If it's a physical limit, you could place the printer nearer to an edge and/or further away from the print bed. This should give you a bigger print area.
                    For optimal placement I cannot give a recommendation, but it's worth to search, e.g. this document: https://www.researchgate.net/publication/298430720_Optimal_Placement_of_a_SCARA_Robot_-_Lab_Report
                    • Mauxxundefined
                      Mauxx
                      @JoergS5 Yes, max angle is physical limit
                      Sorry for my bad english...
                      • Mauxxundefined
                        Mauxx
                        @dc42 have you ever encountered this issue?
                        • Danalundefined
                          Danal
                          We've all focused on the stuff happening along X while Y=0.
                          None of that explains what happens at 3:10 or so in the video, the move from X90Y220 to X60Y220 also draws an arc. An arc that falls outside the printable area as specified by M208. None of the joints are anywhere near a limit.
                          • Mauxxundefined
                            Mauxx
                            it's really very strange
                            thank you all for your help!!!
                            • JoergS5undefined
                              JoergS5 @Danal
                              @Danal said in Scara Problem:
                              That's a valid point. Maybe multiple reasons.
                              My ideas for things to analyze:
                              • the communication log of Simplify3D
                              • belt connection between steppers and Axes: maybe slipping or other problem. Slipping belt could explain curves at strange positions. => one more idea: maybe acceleration and speed too high, so belt starts slipping. You can test setting speed and acceleration lower
                              Is it a toothed belt or a non-toothed one? If it doesn't have teeth, you can check whether the belt slips at the stepper pulley when the printer makes a curve. The pulley itself could slip also (pulley on the stepper axis). You use a method which I know as ServoBelt, this produces high tension, needs high torque and may lead to slipping pulley.
                              @Mauxx which Duet hardware, firmware versions are you using?
                              • Mauxxundefined
                                Mauxx
                                Scara give same issue also with Arduino IDE and with RepetierHost draw a Triangle...
                                I'm sure the belt doesn't slip, i have GT2 toothed Belt
                                I'm using RRF Lpc on Skr V.1.3 board
                                When printer draw arc Y motor doesn't move at all
                                JoergS5undefined 2 Replies Last reply Reply Quote 0
                                • JoergS5undefined
                                  JoergS5 @Mauxx
                                  @Mauxx Maybe the scara code is another one than I checked, because I looked into David's code. Where did you download your firmware RRF LPC code? I will check it then.
                                  • JoergS5undefined
                                    JoergS5 @Mauxx
                                    @Mauxx said in Scara Problem:
                                    What do you mean with triangle?
                                    • Mauxxundefined
                                      Mauxx
                                      When i start print, instead a cube (only in central area) it draw a triangle (half cube)
                                      • JoergS5undefined
                                        JoergS5 @Mauxx
                                        @Mauxx I don't understand it, do you have an image?
                                        But more important is, which software you are using, so I can check the source. Do you use the sdavi CoreLPC4 port?
                                        • Mauxxundefined
                                          Mauxx @JoergS5
                                          @JoergS5 Thank you very much!!!
                                          for the moment I own Skr Board but am willing to buy a Duet
                                          I just wanted to verify that everything worked properly
                                          I practically tried all the firmware (marlin, smoothie) and RRF is the best !!!
                                          • Mauxxundefined
                                            Mauxx @JoergS5
                                            @JoergS5 i'm using this https://github.com/sdavi/RepRapFirmware/releases/tag/LPC_RRFv2.04
