    Nozzle gets smashed against the bed
    Other control boards
    2.6k
    • MJCTundefined
      MJCT
      Where do I find "config-override.g " file, maybe is because of that. Maybe it always overrides my new imputes.
      fcwiltundefined droftartsundefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @MJCT
        @MJCT said in Nozzle gets smashed against the bed:
        If it exists it is right there next to config.g.
        MJCTundefined 1 Reply Last reply Reply Quote 0
        • MJCTundefined
          MJCT @fcwilt
          @fcwilt
          @fcwilt said in Nozzle gets smashed against the bed:
          Well, to me, it never existed. Still it appears at the wiki
          “9. Open config-override.g and check that there are no G31 commands in it. If you find any, delete those lines and save the file.”
          And it’s not the first time that I see the wiki page referring to it, and that’s why I don’t trust wiki
            droftarts administrators @MJCT
            You don't have M501 (read stored parameters) in your config.g, so it won't be loading config-override.g (which is usually in the sys folder, where config.g is). You'll only have a config-override.g if you have sent an M500 to store
            How old is your BL Touch? I have heard that after a while they can get 'sticky', with the pin not deploying fully, and giving variable results. I believe you can take them apart and give them a clean.
            • MJCTundefined
              MJCT
              I think I found the reason why I never see a config-override file...
              *****“dc42 ADMINISTRATORS 10 Jun 2017, 23:18
              If you created your config.g file using configtool, you will have selected whether or not config-override.g is processed.”*****
              When I did my config with the config toll I didn’t select the “Read config-override.g file at end of startup process” box at “General”.
              One doubt less, but still doesn’t solve my problem
              • fcwiltundefined
                fcwilt @MJCT
                @MJCT
                The file config-override is created if you have executed a M500 command.
                I don't have one as created it to have access to the two line of code that were generated by heater tuning.
                I copied those lines into config.g and deleted config-override.g
                • MJCTundefined
                  MJCT
                  My BL is new. Version 3.1, the pin deploys fully and the results are consistent.
                  The problem seems to be that the values that I impute are not taken in to account and the real distance from the nozzle to the bed doesn’t correspond to the distance displayed at the Dashboard for the Z (dashboard always displays a positive value, say 2mm, when the nozzle is already touching the bed).
                  • fcwiltundefined
                    fcwilt
                    After you do a single G30 does the reported value seem to be correct? Does the gap between nozzle and bed seem to match the reported value?
                    • MJCTundefined
                      MJCT @fcwilt
                      @fcwilt ~
                      Nop, last 2 times that that I sent G30 the nozzle smashed the bed
                      • fcwiltundefined
                        fcwilt @MJCT
                        @fcwilt ~
                        When that happened did the pin drop down at the start?
                        • MJCTundefined
                          MJCT @fcwilt
                          @fcwilt
                          Yes
                          • fcwiltundefined
                            fcwilt @MJCT
                            @fcwilt
                            Yes
                            Did the pin retract when it touched the bed?
                            It's possible you have an intermittent connection in the wires that carry the signal from the probe back to the Duet.
                            • MJCTundefined
                              MJCT @fcwilt
                              @fcwilt
                              Yes, the pin retract when it touches the bed
                              • fcwiltundefined
                                fcwilt @MJCT
                                @fcwilt
                                But the motion did not stop?
                                When the pin is in the down position how far below the nozzle does it extend?
                                • MJCTundefined
                                  MJCT
                                  My last test returned this value
                                  https://drive.google.com/file/d/1EH_a5huQdowrXaahItpsKx0ADAuLq9RX/view?usp=sharing
                                  should I input
                                  G31 P25 X25 Y0 Z0.229
                                  or
                                  G31 P25 X25 Y0 Z2.29 ?
                                  • MJCTundefined
                                    MJCT @fcwilt
                                    @fcwilt
                                    Yes the motion stoped.
                                    The pin gets +- 3.3mm below the nozle
                                    • fcwiltundefined
                                      fcwilt @MJCT
                                      @fcwilt
                                      Well if the motion stopped how did the nozzle hit the bed?
                                      • fcwiltundefined
                                        fcwilt
                                        And you enter the value just as displayed.
                                        • MJCTundefined
                                          MJCT @fcwilt
                                          @fcwilt
                                          the problem now is that this thread is getting to long and I’m starting to get confused with all the questions. Kind off... you where asking about the G30, when I home the Z, When I start the machine....???
                                          Well, I entered the value as displayed “G31 P25 X25 Y0 Z0.229”
                                          Seems to work at the beginning. First layer a little bit far from bed, corrected it with baby steps, and printed the rest of the first layer fine.
                                          Second layer moved a lot above what was expected and started to print in the air.
                                          May be the “G31 P25 X25 Y0 Z0.229” was right from the beginning and the problem is Cura?
                                          What other slicers do you use for reprap?
                                          Now I’m going home, long day! Thank you all, I really appreciate all your effort!
                                            jay_s_uk
                                            If it moved further than expected, have you got your z steps correct for your machine?
                                            MJCTundefined 1 Reply Last reply Reply Quote 1
