    Nozzle gets smashed against the bed
    Other control boards
    2.6k
    • MJCTundefined
      MJCT
      I think I found the reason why I never see a config-override file...
      *****“dc42 ADMINISTRATORS 10 Jun 2017, 23:18
      If you created your config.g file using configtool, you will have selected whether or not config-override.g is processed.”*****
      When I did my config with the config toll I didn’t select the “Read config-override.g file at end of startup process” box at “General”.
      One doubt less, but still doesn’t solve my problem
      • fcwiltundefined
        fcwilt @MJCT
        @MJCT
        The file config-override is created if you have executed a M500 command.
        I don't have one as created it to have access to the two line of code that were generated by heater tuning.
        I copied those lines into config.g and deleted config-override.g
        • MJCTundefined
          MJCT
          My BL is new. Version 3.1, the pin deploys fully and the results are consistent.
          The problem seems to be that the values that I impute are not taken in to account and the real distance from the nozzle to the bed doesn’t correspond to the distance displayed at the Dashboard for the Z (dashboard always displays a positive value, say 2mm, when the nozzle is already touching the bed).
          • fcwiltundefined
            fcwilt
            After you do a single G30 does the reported value seem to be correct? Does the gap between nozzle and bed seem to match the reported value?
            MJCTundefined 1 Reply Last reply Reply Quote 0
            • MJCTundefined
              MJCT @fcwilt
              @fcwilt ~
              Nop, last 2 times that that I sent G30 the nozzle smashed the bed
              • fcwiltundefined
                fcwilt @MJCT
                @MJCT said in Nozzle gets smashed against the bed:
                @fcwilt ~
                When that happened did the pin drop down at the start?
                • MJCTundefined
                  MJCT @fcwilt
                  @fcwilt
                  Yes
                  • fcwiltundefined
                    fcwilt @MJCT
                    @fcwilt
                    Yes
                    Did the pin retract when it touched the bed?
                    It's possible you have an intermittent connection in the wires that carry the signal from the probe back to the Duet.
                    • MJCTundefined
                      MJCT @fcwilt
                      @fcwilt
                      Yes, the pin retract when it touches the bed
                      • fcwiltundefined
                        fcwilt @MJCT
                        @fcwilt
                        But the motion did not stop?
                        When the pin is in the down position how far below the nozzle does it extend?
                        • MJCTundefined
                          MJCT
                          My last test returned this value
                          https://drive.google.com/file/d/1EH_a5huQdowrXaahItpsKx0ADAuLq9RX/view?usp=sharing
                          should I input
                          G31 P25 X25 Y0 Z0.229
                          or
                          G31 P25 X25 Y0 Z2.29 ?
                          • MJCTundefined
                            MJCT @fcwilt
                            @fcwilt
                            @fcwilt said in Nozzle gets smashed against the bed:
                            Yes the motion stoped.
                            The pin gets +- 3.3mm below the nozle
                            • fcwiltundefined
                              fcwilt @MJCT
                              @fcwilt
                              Well if the motion stopped how did the nozzle hit the bed?
                              • fcwiltundefined
                                fcwilt
                                And you enter the value just as displayed.
                                • MJCTundefined
                                  MJCT @fcwilt
                                  @fcwilt
                                  the problem now is that this thread is getting to long and I’m starting to get confused with all the questions. Kind off... you where asking about the G30, when I home the Z, When I start the machine....???
                                  Well, I entered the value as displayed “G31 P25 X25 Y0 Z0.229”
                                  Seems to work at the beginning. First layer a little bit far from bed, corrected it with baby steps, and printed the rest of the first layer fine.
                                  Second layer moved a lot above what was expected and started to print in the air.
                                  May be the “G31 P25 X25 Y0 Z0.229” was right from the beginning and the problem is Cura?
                                  What other slicers do you use for reprap?
                                  Now I’m going home, long day! Thank you all, I really appreciate all your effort!
                                    jay_s_uk
                                    If it moved further than expected, have you got your z steps correct for your machine?
                                    MJCTundefined 1 Reply Last reply Reply Quote 1
                                      Phaedrux Moderator @MJCT
                                      M92 X80.00 Y80.00 Z4000.00 E96.94 ; set steps per mm
                                      Z steps per mm of 4000 doesn't sound correct.
                                      Z_steps_per_mm = (motor_steps_per_rev * driver_microstep) / screw_lead
                                      • MJCTundefined
                                        MJCT @jay_s_uk
                                        @jay_s_uk
                                        @jay_s_uk said in Nozzle gets smashed against the bed:
                                        Yes, I tested it before I started asking questions. Any way If you read this
                                        "Well, I entered the value as displayed “G31 P25 X25 Y0 Z0.229”
                                        Second layer moved a lot above what was expected and started to print in the air."
                                        you know that the problem is not Z steps
                                          Please fill out the formula above for determining Z steps per mm and show how you arrive at 4000. Thanks.
                                          MJCTundefined 2 Replies Last reply Reply Quote 0
                                          • MJCTundefined
                                            MJCT @Phaedrux
                                            @Phaedrux
                                            I tried to use the formula when I was using the config tool, but that value was provided by the manufacturer. But I will double cheek it tomorrow
