Firmware(ahhhhhh) Gotta be an easier way!
This is killing me. I had the printer on wifi at my old house but not running. I could home and web control worked. I'm at my new house and haven't been able to touch my printer in months. Well its all leveled out now and I can finally sit down and have a little fun.
I have been down the firmware rapids and yat bossa rumble. I am stumped.
I```
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
Board ID: 08DAM-9K9K2-NGNS0-7JKDL-3SJ6J-K70HL
Used output buffers: 1 of 24 (10 max)
Static ram: 25680
Dynamic ram: 93636 of which 0 recycled
Exception stack ram used: 304
Never used ram: 11452
Tasks: NETWORK(ready,548) HEAT(blocked,1172) MAIN(running,3844) IDLE(ready,160)
Owned mutexes:
Last reset 00:13:54 ago, cause: software
Last software reset at 2019-01-22 23:57, reason: User, spinning module GCodes, available RAM 5672 bytes (slot 1)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0xffffffff
Error status: 0
Free file entries: 10
SD card 0 detected, interface speed: 12.0MBytes/sec
MCU temperature: min 28.9, current 30.2, max 30.5
Supply voltage: min 0.5, current 0.5, max 0.6, under voltage events: 0, over voltage events: 0, power good: no
Driver 0: ok, SG min/max not available
Driver 1: ok, SG min/max not available
Driver 2: ok, SG min/max not available
Driver 3: ok, SG min/max not available
Driver 4: ok, SG min/max not available
Cache data hit count 1610437237
Slowest loop: 1.09ms; fastest: 0.07ms
Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
=== DDARing ===
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is ready with "m122" in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 2137.36ms; fastest: 0.00ms
HTTP sessions: 0 of 8- WiFi -
Network state is disabled
WiFi module is disabled
Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485
ok
I have had the module idle although it won't idle now.
I downloaded the three files 2.03 from the firmware page
[0_1575446666755_DuetWiFiServer.bin](Uploading 100%) [0_1575446670220_iap4e.bin](Uploading 100%) [0_1575446678921_Duet2CombinedFirmware.bin](Uploading 100%)Formatted a fresh SD card (Completely blank)
made a new folder called "sys"
copied those three files into it and safely removed the usb
removed the sd card from my usb reader
powered the board on and hit the erase button (not reset)
opened yat and the board would not communicate (just to verify the firmware had been erased)
pulled the usb cord
installed the sd card into the board
plugged the usb cord in
turned power main on
opened bossa
clicked the boxes for (erase all)(lock)(boot to flash)
hit the refresh button and it showed up on com4 (instead of 3)
browsed to C:\Users\stacy\OneDrive\Desktop\sys\Duet2CombinedFirmware.bin
hit the write button
hit the verify button
waited till it was done
opened YAT
hit M115
hit M997 S0
hit M997 S1
hit M552 (disabled)
hit M552 S1 (ok)
hit M552 (module is starting)
waited
waited
Hit M552 S0
before I wend down this road at least I would get a return of (wifi module is idle)
still shows old wifi firmware
I cannot get the wifiserver firmware to update even after hitting the erase buttonThis is what I get
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b2
I have tried multiple duetwifiserver.bin files and it will always says 1.02
- WiFi -
1.02 is the version of the Duet board you have! Not the WifiServer version. That's in M122, towards the end in the Network section, but the WiFi needs to be enabled to see it. Try sending:
M552 S-1 ; disable wifi module
M553 S0 ; put wifi into idle mode
M122 ; print diagnosticsThen look at the Network section of M122, and/or post it here.
eg
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04 running on Duet WiFi 1.0 or 1.01 Board ID: 08DAM-999TL-NL5T8-6JTD8-3SD6T-KP67L Used output buffers: 3 of 24 (6 max) ... snip ... === Network === Slowest loop: 15.82ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 1 of 8 - WiFi - Network state is running WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.23 WiFi MAC address 5c:cf:7f:1a:9c:3b WiFi Vcc 3.34, reset reason Turned on by main processor WiFi flash size 4194304, free heap 25352 WiFi IP address 192.168.0.10 WiFi signal strength -62dBm, reconnections 0, sleep mode modem Socket states: 0 0 0 0 0 0 0 0
"WiFi firmware version 1.23"
If you can't get the WiFi module to go into idle mode, it probably is incompatible with the main firmware. See this section of the firmware update instructions: https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_How_to_recover_if_the_main_firmware_and_WiFi_firmware_versions_get_out_of_step_on_your_Duet_2_WiFi
M552 S-1
ok
M552 S-0
ok
M122
Static ram: 25680
Exception stack ram used: 312
Never used ram: 11444
Tasks: NETWORK(ready,548) HEAT(blocked,1172) MAIN(running,3832) IDLE(ready,160)
Owned mutexes:
Last reset 07:17:54 ago, cause: software
Error status: 0
MCU temperature: min 28.7, current 29.8, max 32.3
Slowest loop: 99.59ms; fastest: 0.07ms
=== DDARing ===
Segments left: 0
serial is ready with "M122" in state(s) 0
=== Network ===
Slowest loop: 0.20ms; fastest: 0.00ms
Network state is starting
ok
- WiFi -
@Styler93gsx said in Firmware(ahhhhhh) Gotta be an easier way!:
M552 S-0
This is not valid command, use M552 S0 to put wifi module to idle mode
@droftarts
I had it in idle mode last night for abou a few hours. I sent M997 S0 M997 S1 M552 M552 S1 M552 S0 M552 more times than I can count and not all it that particular order. I really think my M key on my keyboard is about worn out. I've pulled my Micro SD card and formatted, copy pasted, watched numerous youtube videos and have read on the WIKI till I started seeing double. Took a three hour nap an only think I can say that has gone right is after the three hour nap I"m not seeing double anymore.I've explored fallback firmware #1 #2 & #3
#3 I even started with a different freshly formatted SD card and still can't get he 1.02 to update to anything other than 1.02
When I send M115 I get
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b2I have uploaded firmwares 2.05RC all the way down to 2.03. But it always says Duet Wifi 1.02
If that 1.02 is referring to my board then how do I actually check my wifi server bin version
When I send M122 This is what I get.M122
Static ram: 25680
Owned mutexes:
Error status: 0
=== DDARing ===
Segments left: 0
=== Network ===
ok
- WiFi -
@aidar
If is not a valid command why does it say OK?I've tried it with M552 S0 and M552 S-0
Both respond with ok.
The part that you read up above I copy and pasted the entire dialog and as you can see when I typed M552 S-0 it responded with ok.
I've tried M552 I don't know how many times and at one point it was saying the wifi module is idle but now it just keeps saying wifi module is starting.
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b22.03 is your firmware version and 2019-06-13b2 is the date of that firmware version's build.
1.02 is your 'electronics'. That is, the board. The hardware. It will NEVER change (unless you buy new/different hardware).
@aidar
It might say OK, but S-0 is not the documented format of the command and none of us can have any idea what S-0 does (or does not) do. For now, please stick to S0 for idle.
And, a couple of notes:
The erase button on the main board erases the flash memory in the CPU of the main board. It does NOT erase the WiFi module. There is no way to erase WiFi; instead, overwrite it.
When executing the various recovery options, your SD should look like:
sys/Duet2CombinedFirmware.bin
sys/iap4e.bin
sys/DuetWiFiServer.bin
www/ (will look more or less like screenshot below)
- Connect with YAT (or other terminal) and issue:
M997 S0:1
This updates BOTH the main board and the WiFi together. That is more likely to work. If for some reason it does not, you can try M997 S0 and M997 S1 separately.
At that point, you should have good firmware. From there, you should be able to get on your network via:
https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
M552 S-1 turns the WiFi module off. M552 S0 turns it on, and sets it to idle mode. M552 S1 activates it to connect to any WiFi access point that it has been configured to connect to. I'm guessing M552 S-0 is interpreted as S0.
As @Danal says, your firmware version is 2.0.3. Your Duet board revision is 1.0.2. I expect you are continuously updating the board with the same firmware version, 2.0.3. Try this one instead: https://github.com/dc42/RepRapFirmware/releases/tag/2.04
@droftarts said in Firmware(ahhhhhh) Gotta be an easier way!:
I find the firmware release more confusing than needed, having to sift through a list of files, most of them non relevant to majority of the users. Could be simplified along these lines:
Duet2 Wifi
board_firmware_xyz.zip
panel_due_xyz.zipMaestro
(similar)
And a link to a repository where the developer oriented files can be found.
Ok I have 2.04 installed and Wifi Module is going into idle again. But I'm still getting Errror retrieving Wifi status message: SPI timout.
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04 running on Duet WiFi 1.02 or later
Used output buffers: 1 of 24 (1 max)
Static ram: 25680
Dynamic ram: 92696 of which 0 recycled
Exception stack ram used: 288
Never used ram: 12408
Tasks: NETWORK(ready,1280) HEAT(blocked,1208) MAIN(running,3808) IDLE(ready,200)
Owned mutexes: WiFi(NETWORK)
Last reset 00:02:07 ago, cause: software
Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11444 bytes (slot 2)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04433000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
Error status: 0
MCU temperature: min 29.2, current 30.6, max 30.8
Supply voltage: min 0.4, current 0.5, max 0.6, under voltage events: 0, over voltage events: 0, power good: no
Cache data hit count 808438268
Slowest loop: 392.09ms; fastest: 0.05ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
=== DDARing ===
Segments left: 0
=== Network ===
Slowest loop: 401.11ms; fastest: 0.00ms
WiFi module is idle
Failed messages: pending 0, notready 0, noresp 471
Error retrieving WiFi status message: SPI timeout
Failed to get WiFi status
ok
- WiFi -
OK, @dc42 is going to have to ring in here. At this moment, it looks to me like a hardware problem.
Just as a final check, issue
M997 S1
and post the response (it may take several minutes).
If you have already reinstalled the WiFi firmware, then I agree, probable hardware problem. Looks like the WiFi module needs to be replaced.
@dc42 Will one of these work
With this antenna
https://www.amazon.com/gp/product/B01KBU61S8/ref=ox_sc_act_title_1?smid=A169Z7QURE8JMH&psc=1
The 6dBi antenna looked as though it would fit my home situation the best. Indoor 1-50M with excellent reception
Or would I be better off just getting the one with an internal Antenna?
