    Firmware(ahhhhhh) Gotta be an easier way!
    Firmware installation
    719
    • Danalundefined
      Danal
      @Styler93gsx said in Firmware(ahhhhhh) Gotta be an easier way!:
      #3 I even started with a different freshly formatted SD card and still can't get he 1.02 to update to anything other than 1.02
      When I send M115 I get
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b2
      2.03 is your firmware version and 2019-06-13b2 is the date of that firmware version's build.
      1.02 is your 'electronics'. That is, the board. The hardware. It will NEVER change (unless you buy new/different hardware).
      • Danalundefined
        Danal @Styler93gsx
        @aidar
        If is not a valid command why does it say OK?
        I've tried it with M552 S0 and M552 S-0
        Both respond with ok.
        The part that you read up above I copy and pasted the entire dialog and as you can see when I typed M552 S-0 it responded with ok.
        I've tried M552 I don't know how many times and at one point it was saying the wifi module is idle but now it just keeps saying wifi module is starting.
        It might say OK, but S-0 is not the documented format of the command and none of us can have any idea what S-0 does (or does not) do. For now, please stick to S0 for idle.
        • Danalundefined
          Danal
          And, a couple of notes:
          • The erase button on the main board erases the flash memory in the CPU of the main board. It does NOT erase the WiFi module. There is no way to erase WiFi; instead, overwrite it.
          • When executing the various recovery options, your SD should look like:
          sys/Duet2CombinedFirmware.bin
          sys/iap4e.bin
          sys/DuetWiFiServer.bin
          www/ (will look more or less like screenshot below)
          • Connect with YAT (or other terminal) and issue:
          M997 S0:1
          This updates BOTH the main board and the WiFi together. That is more likely to work. If for some reason it does not, you can try M997 S0 and M997 S1 separately.
          At that point, you should have good firmware. From there, you should be able to get on your network via:
          https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
            droftarts administrators
            @Styler93gsx
            M552 S-1 turns the WiFi module off. M552 S0 turns it on, and sets it to idle mode. M552 S1 activates it to connect to any WiFi access point that it has been configured to connect to. I'm guessing M552 S-0 is interpreted as S0.
            As @Danal says, your firmware version is 2.0.3. Your Duet board revision is 1.0.2. I expect you are continuously updating the board with the same firmware version, 2.0.3. Try this one instead: https://github.com/dc42/RepRapFirmware/releases/tag/2.04
            zaptaundefined 1 Reply Last reply Reply Quote 1
            • zaptaundefined
              zapta @droftarts
              @droftarts said in Firmware(ahhhhhh) Gotta be an easier way!:
              I find the firmware release more confusing than needed, having to sift through a list of files, most of them non relevant to majority of the users. Could be simplified along these lines:
              Duet2 Wifi
              board_firmware_xyz.zip
              panel_due_xyz.zip
              Maestro
              (similar)
              And a link to a repository where the developer oriented files can be found.
              • Styler93gsxundefined
                Styler93gsx
                Ok I have 2.04 installed and Wifi Module is going into idle again. But I'm still getting Errror retrieving Wifi status message: SPI timout.
                M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04 running on Duet WiFi 1.02 or later
                Board ID: 08DAM-9K9K2-NGNS0-7JKDL-3SJ6J-K70HL
                Used output buffers: 1 of 24 (1 max)
                Static ram: 25680
                Dynamic ram: 92696 of which 0 recycled
                Exception stack ram used: 288
                Never used ram: 12408
                Tasks: NETWORK(ready,1280) HEAT(blocked,1208) MAIN(running,3808) IDLE(ready,200)
                Owned mutexes: WiFi(NETWORK)
                Last reset 00:02:07 ago, cause: software
                Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11444 bytes (slot 2)
                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04433000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                Error status: 0
                Free file entries: 10
                SD card 0 detected, interface speed: 12.0MBytes/sec
                MCU temperature: min 29.2, current 30.6, max 30.8
                Supply voltage: min 0.4, current 0.5, max 0.6, under voltage events: 0, over voltage events: 0, power good: no
                Driver 0: ok, SG min/max not available
                Driver 1: ok, SG min/max not available
                Driver 2: ok, SG min/max not available
                Driver 3: ok, SG min/max not available
                Driver 4: ok, SG min/max not available
                Cache data hit count 808438268
                Slowest loop: 392.09ms; fastest: 0.05ms
                Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
                === DDARing ===
                Segments left: 0
                Movement lock held by null
                http is idle in state(s) 0
                telnet is idle in state(s) 0
                file is idle in state(s) 0
                serial is ready with "M122" in state(s) 0
                aux is idle in state(s) 0
                daemon is idle in state(s) 0
                queue is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Slowest loop: 401.11ms; fastest: 0.00ms
                HTTP sessions: 0 of 8
                • WiFi -
                  Network state is running
                  WiFi module is idle
                  Failed messages: pending 0, notready 0, noresp 471
                  Error retrieving WiFi status message: SPI timeout
                  Failed to get WiFi status
                  ok
                • Danalundefined
                  Danal
                  OK, @dc42 is going to have to ring in here. At this moment, it looks to me like a hardware problem.
                  Just as a final check, issue
                  M997 S1
                  and post the response (it may take several minutes).
                    If you have already reinstalled the WiFi firmware, then I agree, probable hardware problem. Looks like the WiFi module needs to be replaced.
                    Styler93gsxundefined 1 Reply Last reply Reply Quote 0
                      Styler93gsx @dc42
                      @dc42 Will one of these work
                      https://www.amazon.com/Sunhokey-ESP8266-Wireless-ESP-07S-Industrial/dp/B07KRZWZQV/ref=sr_1_1?keywords=ESP-07S&qid=1575561604&sr=8-1
                      https://www.amazon.com/HiLetgo-ESP8266-Serial-Wireless-Module/dp/B00WG9HM7W/ref=sr_1_4?keywords=ESP-07S&qid=1575561604&sr=8-4
                      With this antenna
                      https://www.amazon.com/gp/product/B01KBU61S8/ref=ox_sc_act_title_1?smid=A169Z7QURE8JMH&psc=1
                      The 6dBi antenna looked as though it would fit my home situation the best. Indoor 1-50M with excellent reception
                      Or would I be better off just getting the one with an internal Antenna?
                        droftarts administrators @Styler93gsx
                        @Styler93gsx See this thread https://forum.duet3d.com/topic/2825/converting-the-duet-wifi-to-use-an-external-antenna
