    Hello, am new here but not a newbie as such.
    7.9k
    • FuseDeepundefined
      FuseDeep
      I get great results with blue tape on normal glass bed and use a decent brim. never had any problems. I print mostly vase prints anyway for speed so even more reliable stress wise in the part printing.
        deckingman @FuseDeep
        @FuseDeep Then you should get a really long run time on battery power. I wouldn't worry too much about lightening the gantry as any savings from reducing the motor current by sat 100mA will be minimal IMO. My CoreXYUVAB with all 6 motors (two of which are Nema 23s) showed a voltage drop of about 0.5 V after over an hour and that was starting with batteries in there "as received" charge state.
        FuseDeepundefined 1 Reply Last reply Reply Quote 0
        • FuseDeepundefined
          FuseDeep @deckingman
          @deckingman The gantry lightening effort (as above) is more about suitability for purpose.
          The IGUS set up is incredible but too tough for the dynamic needed imo, it has 20mm width M5 or 6 teeth pitch set up for example on a 600mm square set up! Just too much resistance. I may be proved wrong. But my feeling is to keep it simple/simpler.
          Am going for 9mm GT3 M5 belts and looking forward to making an openbuild/v wheel wheel roller set up as I have a Tonka alu frame set up already.
          Nice tech. simple too. Most likely ordering from ooznest.
            @FuseDeep Again for info, my CoreXYUVAB is built using OpenBuilds VSlot and has a moving mass of around 5Kgs split between 2 gantries which all works just fine using 6mm belts. I can also say that I've always had great service from Ooznest.
            • FuseDeepundefined
              @deckingman Cool, thanks . Will report...
              • FuseDeepundefined
                FuseDeep
                OK, have ordered a DUET 2 and wifi antennae plus the 5" screen. I did wonder if there was a connector bundle to go with it? looking at the board connections. I do have plug maker here, but find the pin work painful!
                • Danalundefined
                  Danal @FuseDeep
                  @FuseDeep said in Hello, am new here but not a newbie as such.:
                  A connector kit comes with. You will need a simple crimper, nothing fancy. Something like this:
                  https://www.amazon.com/IWISS-Harness-Crimping-Computer-Automotive/dp/B01M1YK5FM/
                  • FuseDeepundefined
                    FuseDeep @Danal
                    In general, going OK, am fully rehashing the XY gantry with open beam. Nice and simple meccano for grown ups. Enjoying belting up too, combining GT2 on a nema 17 and GT3 on both sides of X.
                    Looks like it will be 2x Nema 23 for X and 1x NEMA17 for Y so will be looking to run 2 Nema 23 at full power from either the same signal (one reversed) or use two Duet outputs, one reversed.
                    Have not even started to look at a DUET file yet. IS there an example file of a fairly normal Cartesian set up file I can start to get my head round please?
                    Also need to look at links above in relation to the basics. will do.
                    Cheers R
                      dc42 administrators @FuseDeep
                      Use the configuration tool at https://configtool.reprapfirmware.org/Start to get you started. Read https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinte when you want to understand what the file contents mean.
                      • FuseDeepundefined
                        FuseDeep
                        No article found at that url:
                        R
                          https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter
                          • FuseDeepundefined
                            FuseDeep @Phaedrux
                            There is a suggestion running 2 stepper in series (but one reversed?) is best for the Z set up. I assume I could reassign Z to my X and use the twin set up?
                            I think the Duet wifi does not have a spare stepper output other than the twin Z. So I could mirror the 2 X axis stepper motors.
                            • FuseDeepundefined
                              FuseDeep
                              Where is the idiots guide to DUET set up please?
                              For example I am not sure how or what the SD card is meant to be connected to to configure (wifi or in my laptop) . Do I have to be connected to the wife of the board to do the config?
                              Plus, I have 2 SD cards as one with the screen. The board based one is key as I understand it.
                              It'll make sense once I have don it...but have never done a DUET.
                              Bit at a loss currently. I do get the impression I might be a stepper driver short on Duet wifi, running two on X (as opposed to Z)
                                A lot of the interaction with the Duet is through the web control interface. The documentation for that is here: https://duet3d.dozuki.com/Wiki/Duet_Web_Control_Manual
                                The Duet Wifi would typically be connected to a wifi network, and then you would connect to the Duet through the web interface in your browser. Alternatively, the Duet can be configured to create its own wifi network, which you could then connect to.
                                A lot of the basics of getting started can be found here: https://duet3d.dozuki.com/Wiki/Step_by_step_guide
                                The SD card that comes with the board will have a very basic default configuration used for testing at the factory. You'll need to provide a set of configuration files specific to your printer. This would normally be created with the online configuration tool. https://configtool.reprapfirmware.org/Start
                                This would provide a basic configuration. More advanced configuration of specific features would then need to be completed manually by editing the configuration files.
                                If you're already connected to the board over the network and have access to the web control you can upload the resulting config set and edit the configuration files right there in the browser, or you can use your PC to edit them and put them on the SD card first.
                                The SD card slot on the board itself would typically hold your configuration files and where the uploaded gcode files would go. The SD card slot on the PanelDue is accessible when the PanelDue is connected via the 10-pin ribbon cable and it can be used to load gcode files in the traditional manner of placing the sliced gcode file on the SD card using a PC and then physically transferring the SD card into the PanelDue slot. You'd then use the web interface or the PanelDue to locate your gcode file for printing.
                                The Za and Zb drivers are wired in series and are not individually addressable since it's a single driver. There are 2 separate extruder drivers, so if you only need one extruder, you can use the other extruder driver as another X/Y/Z axis driver.
                                FuseDeepundefined 1 Reply Last reply Reply Quote 1
                                • FuseDeepundefined
                                  FuseDeep @Phaedrux
                                  @Phaedrux Awesome thanks. I'll work through this as things progress. Thanks again.
                                    No problem. The duet and reprap firmware are a little different than you might be used to and it will be a learning curve. We'll be glad to answer any questions you may have.
                                    • FuseDeepundefined
                                      FuseDeep @Phaedrux
                                      @Phaedrux Appreciate that. It might have been too late in the evening to start looking at it last night, hence the gripe. Apologies.
                                      Getting the gantry built then get serious end of the week with code/DUET. I'll try and go through the steps more constructively. I'll also ask my DUET experienced buddy locally to dive in, will save many questions no doubt.
                                      R
                                      • FuseDeepundefined
                                        FuseDeep
                                        OK, @FuseDeep fully re built. Next step, mount DUET board and screen for initial wire up then start firmware settings...
                                        What is the simplest way to contra rotate two stepper motors on one axis please? How do I assign a spare E (extruder) axis to be the second X?
                                        Probably start initial firmware settings tomorrow afternoon or Monday. Images to follow.
                                        R
                                        • Danalundefined
                                          Danal
                                          Do build an initial config with the online tool: https://configtool.reprapfirmware.org/Start
                                          Do expect to tweak that.
                                          To your question about multiple motors, see: https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
                                          It is intended for multiple Z, but it is not too hard to see how to do multiple on any axis from the examples.
                                          FuseDeepundefined 2 Replies Last reply Reply Quote 0
                                          • FuseDeepundefined
                                            FuseDeep
                                            Thanks, again:
                                            Updates, last few days entirely new XY gantry , cable guide chain, filament distribution and extruder set up, with 3 fan initial layout that needs testing (and is too wide)!
                                            Images:
                                            https://1drv.ms/u/s!AuQg3tWVwb4nlW_WoWFeaheKuNBf?e=Y3itWM
                                            R
                                            Ps:
                                            Thanks again @Danal , will look at board hook up today and then start config etc
