M26 not working
Beta Firmware
    Minion
    I am calling macro to start print with certain offset:
    M23 PrintTest.gcode
    M26 S10070
    M24
    Error I get:
    Error: Failed to execute M26: [NullReferenceException] Object reference not set to an instance of an object.
    Same thing runs as expected on non-beta setup of mine. Is there something else I am missing?
    undefined 1 Reply Last reply 16 Dec 2019, 18:03 Reply Quote 0
      Phaedrux Moderator @Minion
      @Minion said in M26 not working:
      M26 S10070
      How did you arrive at S10070?
      undefined 1 Reply Last reply 17 Dec 2019, 08:02 Reply Quote 0
        gtj0
        Assuming you're trying to start 10070 bytes into the file... M26 is broken.
        You should report it at https://github.com/chrishamm/DuetSoftwareFramework/issues
          Minion @Phaedrux
          @Phaedrux I've paused the print and used M27 to see the current offset. I can not get "resurrect" to generate (should be automatic every time print is paused) thus I am making a workaround .
          @gtj0 thanks, will report it there.
          undefined 1 Reply Last reply 17 Dec 2019, 13:12 Reply Quote 0
            droftarts administrators @Minion
            @Minion Can you post what firmware versions (beta that doesn't work, non-beta that does) you are using?
            undefined 1 Reply Last reply 17 Dec 2019, 13:23 Reply Quote 0
              Minion @droftarts
              @droftarts
              Experimental:
              firmwareName":"RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0","boardName":"MB6HC","firmwareVersion":"3.0beta12+1","firmwareDate":"2019-11-11b1
              Normal:
              firmwareName":"RepRapFirmware for Duet 2 WiFi/Ethernet","firmwareVersion":"2.02(RTOS)","firmwareDate":"2018-12-24b1
                Minion
                chrishamm replied via DSF issue board confirming that M26 is buggy and will be fixed in next release.
                5 out of 7
