Mesh bed compensation with E3D Kraken
@jens55 said in Mesh bed compensation with E3D Kraken:
Has anybody ever published hard figures about x and y registration accuracy for different tool heads ?
not that i am aware of but repeat-ability on the kinematic couplings is reported by e3d as better than single digit microns.
Unless the figure is properly published, it's just marketing speak. I would also be concerned with the fact of it being just the coupling rather than the overall system. It seems that only the coupling should cause errors but I do not know what other errors are added by the time we get to the tool tip.
It still strikes me as odd that they chose sensorless homing for the X and Y endstops.
when they (e3d) pushed initial story about the system there were numbers published (repeatability was awesome) but than after they start selling (and they changed some stuff, for e.g. carbon fiber plate is gone) I don't see any numbers any more but I assume they will vary from machine to machine as you do need to do manually a lot of stuff yourself... I'm these days ordering one so..
as for mesh compensation with multihead, I used some self designed (not very good) dual extruder and try-struder (3 heads) many years ago and the only way I found it work acceptable is to print a big raft out of soluble material (hips or pva or.. I even tried with PLA as support) as the main reason for dual nozzle was main and support and for try-struder main, support, soft (flex or pp for hinges) so I always had one support nozzle available
... that worked good, you disolve that raft later easily and after raft you have ideal surface to print on so mesh compensation required (not that any of the firmware's supported mesh compensation back in the day
) ... the only downside is the waste of support material for the raft, but as modern slicers can use soluble support only for the contact layer (I was not smart enough to do that myself back in the day) the waste would not be that big
I was not aware that they chose that method and yes, it is a bit odd.
I think this is one of those little details that will be worked out with time but it certainly makes you think the system isn't quite right for prime time yet.
In general, I think it is unrealistic to expect a new device to arrive without the need for some tweaking. My thought/hope is that by this time next year the initial teething issues might be mostly sorted. I just hope that with cost being so high, it won't drag the timeline for sorting initial issues for longer than a year. -
@jens55 regarding high cost, you could look at @poofjunior 's Jubilee project. I think @Danal has made one.
https://github.com/machineagency/jubilee -
Yes, I've built a Jubilee. It's a CoreXY with up to four tools. Could easily be extended for more. It is E3D tool compatible. Jubilee prints with no purge blocks.
E3D used metal plates and metal pins for their kinematic coupling and locks, which makes wear a long term proposition; repeatability across a few days is quite good (I don't have any hard numbers). Jubilee uses metal kinematics, but printed plastic locks, and has some good engineering that makes that work well even though it wears.
Cost? About the same as any other well built corexy, plus a small increment for the tool lock, plus the cost of each tool. Not "expensive" by any stretch, for what it does.
At this moment, mine is producing excellent single tool prints, and OK-ish multi tool prints. I need further tweaking and tuning to get to excellent multi tool.
One landmark recently crossed is/was getting very good reliability on changes themselves. I have now completed several prints that contain two to three thousand tool changes, with absolutely no faults. I couldn't have said that a few weeks ago.
Feel free to ask any questions.
@Danal said in Mesh bed compensation with E3D Kraken:
What part of multi tool prints causes issues for you? Is it mechanical or operator/software issues ?
What were the issues that needed improving ?
Thanks !
Getting to excellent multi tool is mostly a matter of aligning the tools. So sort of both.
At the moment, there is no automation to measure the tools themselves. Z is done for each tool the old fashioned paper way, and the Z offset is placed in a G10 command in the configuration (actually, I put it in an external file so I can be sure it is consistent). This actually works well enough; doesn't take that long.
X and Y, so far, I've been printing a vernier. www.thingiverse.com/thing:2847643 Then make an adjustment to the G10 values. I'm not finding this very satisfactory.
There's been lots of discussion about automating probing. Heat and wipe nozzle, then touch it to metal plate for Z, then drop it in square hole and probe for X and Y. OR... USB microscope. OR... piezo with a square sticking up, etc, etc. So far, this is all talk, nobody's implemented anything. I MIGHT, if I get some free time (ha ha) give a shot to one of these methods, implemented on the Pi on a Duet 3.
Summary: Multi Tool Alignment.
What were the issues that needed improving [to get reliable toolchanges]?
My personal first use of RR3 firmware. Learning curve. I seemed to have a very hard time with RR3 concepts. Perhaps been using 2 too long. Anyway, once it "clicked" I do believe the new naming of pins and gathering things up to form a tool is MUCH better than the old way. I'm just thickheaded about some things.
Not that many weeks back, RR3 documentation was a lot more sparse than it is today. It has really improved a lot in a short time.
A bug or two in the beta. Again, lots of improvement in a short time.
My first toolchanger. Learning curve.
A couple of mistakes I made reading the instructions and/or Bill-Of-Materials that resulted in the tool-lock ALMOST working. The original designer, @poofjunior is on a discord and is very responsive. Once I had a few "Aha!" moments, and changed it to what the plans/instructions actually said, it started working much better.
My first laser cuts (to make certain delrin parts). I'm really loving that, what a great new capability in the arsenal.
I hand cut a bed on a bandsaw from an expensive piece of aluminum plate... with a PDF pattern glued on... a pattern that had printed just a FEW percent too small... SH*T!!. Very disheartening. Second attempt: CNC cut with many passes on a CNC router. Worked GREAT. Again, a new learning and a new capability. What fun building these things.
By the way, the delrin parts and the machined bed are now available from a couple of suppliers.
Summary: Learning curve.
- And, what I'd call "normal" tuning. Getting the XY of the parking stalls really truly matching physical reality.
Thanks for the thorough run down on the issues encountered.
I think that once a reliable and accurate method of tool locating has been implemented it will be a great setup ! -
Personally, bearing in mind the issues one nozzle can throw up, adding any more is not something I ever see the point of!
To give this context, fast printing for an item that can then be textured and artworked is far superior, IMO, to a half decent print in 2 to 4 basic colours.
Obviously multi nozzle printing has novelty value...but seems a long way round to achieve it, technically.
