    RepRapFirmware 3.0RC1 released
    Beta Firmware
    19
    77
    5.8k
    • 3dmntbighkerundefined
      3dmntbighker
      So, my config.g is shown above. But if I "select all" in the editor and paste into a standard text editor I get the following (ignore the extra stuff I had clipped out):
      0:/sys/config.g
      ; *** CoreXY sample config file for dc42 Duet firmware
      M111 S0				; Debug off
      M550 P"5Rails"                     ; Set machine name
      M552 P192.168.1.100 S1             ; Enable network set IP
      M553 P255.255.255.0                ; Netmask
      M554 P192.168.1.1                  ; Gateway
      M586 P0 S1                         ; Enable HTTP
      M586 P1 S0                         ; Disable FTP
      M586 P2 S0                         ; Disable Telnet
      M555 P2				; Set output to look like Marlin
      ; M575 P1 B57600 S1		; Comms parameters for PanelDue
      ; *** Machine configuration
      M569 P0 S1				; Drive 0 goes forwards (change to S0 to reverse it)
      M569 P1 S1				; Drive 1 goes forwards
      M569 P2 S0				; Drive 2 goes backwards
      M569 P3 S1				; Drive 3 goes forwards
      M569 P4 S1				; Drive 4 goes forwards
      ; *** If you use an endstop switch for Z homing, change Z0 to Z1 in the following line, and see also M558 command later in this file
      M574 X1 S0 P"xstop"   ; X min active low endstop switch
      M574 Y1 S0 P"ystop"   ; Y min active low endstop switch
      M574 Z1 S0 P"zstop"   ; Z min active low endstop switch
      M591 D0 P2 C"e0_stop" S1	; E0 filament sensor active high
      ; M915 X Y S5 R0 F0 	; set X and Y to sensitivity 5, do nothing when stall, unfiltered... NOT on Maestro :-(
      M669 K1					; set CoreXY mode
      M564 H0					; Allow moves prior to homing
      M92 X100 Y100 Z1000			; Set axis steps/mm
      M92 E415				; Set extruder steps/mm
      ; M203 X15000 Y15000 Z1500 E3600	; Maximum speeds (mm/sec)
      ; M566 X600 Y600 Z50 E900		; Maximum jerk speeds mm/sec
      M350 X16 Y16 Z16 E16 I1			; Configure microstepping with interpolation
      M906 X1000 Y1000 Z800 E800 I50	        ; Set motor currents (mA)
      M201 X1000 Y1000 Z100 E900		; Accelerations (mm/s^2)
      ; M203 X40000 Y30000 Z800 E1800		; Maximum speeds (mm/sec)
      M203 X4000 Y3000 Z800 E1800		; Maximum speeds (mm/sec)
      M566 X800 Y800 Z50 E800			; Maximum jerk speeds mm/sec
      M208 X300 Y275 Z330			; set axis maxima (adjust to suit your machine)
      M208 X0 Y0 Z0 S1			; set axis minima (adjust to make X=0 and Y=0 the edges of the bed)
      G21					; Work in millimetres
      G90					; Send absolute coordinates...
      M83					; ...but relative extruder moves
      ; Z probe type
      M558 P8 I1 R2 A5 F400 T3000 H5              ; Peizo Z probe, also used for homing the Z axis
      G31 Z0.2 P600                      ; Set the probe height and threshold (put your own values here)
      ; The following M557 commands are not needed if you are using a bed.g file to perform bed compensation
      ; *** Adjust the XY coordinates in the following M557 commands to suit your build and the position of the Z probe
      M557 X25:275 Y15:265 S50                      ;
      M375                                        ; Load heightmap.csv
      M376 H10                                    ; Taper off bed compensation up to 10mm
      ; Thermistors and heaters
      ; *** If you have a Duet board with 1K thermistor series resistors, change R4700 to R1000 to the following M305 commands
      ; You can also use S and B parameters to define the parameters of the thermistors you are using
      M308 S0 P"bed_temp" Y"thermistor" R2200 T100000 B3950	; Put your own H and/or L values here to set the bed thermistor ADC correction
      M308 S1 Y"rtd-max31865" R400 P"spi.cs1" F60			; Activate PT100 hotend temp sensor
      M950 H0 C"bed_heat" T0 ; heater 0 uses the bed_heat pin, sensor 0
      M950 H1 C"e0_heat" T1 ; heater 1 uses the e0_heat pin and sensor 1
      ; M305 P1 R4700 H0 L0			; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
      ; M305 P2 R4700 H0 L0			; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
      ; M301 H1 P10 I0.10 D100 T0.50 S1.0	; PID settings for extruder 0
      ; M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1 ; Old bed heater PID settings
      ; M307 H1 A497.3 C234.6 D3.7 B0		; ***Auto tune derived 30W preferred extruder 0 PID settings ***
      ; M308 P101 X1001 S"DuetDriversTemp"	; Virtual heater to display stepper driver over temp flags
      M501                                    ; Load config_override.g for 40W Auto tune
      ; M301 H2 P10 I0.10 D100 T0.50 S1.0	; PID settings for extruder 1
      ; Tool definition
      M563 P0 D0 H1				; Define tool 0
      G10 P0 S0 R0			; Set tool 0 operating and standby temperatures
      ; *** If you have a dual-nozzle build, un-comment the following 3 lines
      ; M563 P1 D1 H2				; Define tool 1
      ; G10 P1 S0 R0				; Set tool 1 operating and standby temperatures
      ; *** If you are using axis compensation, put the figures in the following command
      M556 S78 X0 Y0 Z0			; Axis compensation here
      ; M98 PStartup.g                  ; Play tune
      T0				; select first hot end
      5Rails
      Send code...
      Status
      Idle
      Mode: FFF
      Tool Position
      X
      20.0
      Y
      0.0
      Z
      0.01
      Extruder Drives
      Drive 0
      0.0
      Speeds
      Requested Speed
      0 mm/s
      Top Speed
      0 mm/s
      Sensors
      Vin
      24.2 V
      MCU Temperature
      40.5 C
       Tools
       Extra
       Control All
      Tool	Heater	Current	Active	Standby
      Tool 0
      T0 - PLA	Heater 1
      active	23.2 C
      0
      0
      Bed	Heater 0
      off	22.5 C
      0
      0
      Temperature Chart
      System Directory
      Is the extra stuff at the end normal?
      Scratch built CoreXY with Maestro
      Heavily modified Ender 3 with Maestro
      MPCNC work in progress with Duet WiFi
      • gtj0undefined
        gtj0
        @3dmntbighker said in RepRapFirmware 3.0RC1 released:
        I think the stuff after the T0 is just from copying from the DWC web page.
        In any case, try putting the "M669 K1" at the top of the file. I don't think it'll make a difference but it may.
        3dmntbighkerundefined 1 Reply Last reply Reply Quote 0
          This is covered In the upgrade notes. S0 is no longer supported in M574. Use S1 and invert the pin using ! at the start of the pin name.
            3dmntbighker @gtj0
            @gtj0 said in RepRapFirmware 3.0RC1 released:
            Yeah, looking at the file directly on the SD card it looks normal. I can enter M669 K1 in the console and no difference. It really seems to be an issue with M574? There seems to be no way to change the end stop from active high to active low. Changing M574 it always acts the same.
              3dmntbighker @dc42
              @dc42 said in RepRapFirmware 3.0RC1 released:
              It's not noted in the M574 section of the RepRap changes document. Nor on the main G-code page. Which does have many notations about RRF3.
              Thanks, I'm operational now. I had some issues with the Piezo sensor but I resolved those.
              deckingmanundefined 1 Reply Last reply Reply Quote 1
                deckingman @3dmntbighker
                @3dmntbighker TBH, I didn't know that S0 had been withdrawn either. I was going by this thread https://forum.duet3d.com/topic/13136/m574-usage-on-rrf-3 where David said his intention was not to withdraw S0.
                  3dmntbighker @deckingman
                  @deckingman said in RepRapFirmware 3.0RC1 released:
                  That's what we get for being bleeding edge. I don't ask for apologies 😉
                  DC is "the man". He's done as much for my 3D printing as anyone.
                    Yes, I changed my mind. I found an inconsistency in how local and remote endstops configured using S0 were treated, and that led me to decide that providing two ways of doing the same thing was an unecessary complication.
                      deckingman @dc42
                      Fair enough. @droftarts or someone needs to update the Gcode documentation to reflect that. https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_RepRapFirmware_Num_3
                        dc42 administrators @deckingman
                        @deckingman, that's already in hand.
                          droftarts administrators @dc42
                          @dc42 @deckingman Done!
                          • c310undefined
                            c310
                            need configuration help to connect PT100 via board to DuetWiFi 2 v1.03
                            after upgrade to rrf-3 i changed config and everything works but the extruder temp sensor. it shows 2000 deg...
                            downgrading to 2.05 shows correct temperature.
                            here are related lines:
                            old RRF2 config
                            M305 P1 S"T0" X200 R395 W2
                            M143 H1 S350 A0 				; max temp 350 on heater 1, fault if above
                            M570 S60 H1 P10 T15 				; Hot end may be a little slow to heat
                            M563 P0 D0 H1 F2                                ; tool definition
                            RRF-3
                            M308 S1 P"e0_temp" Y"rtd-max31865" R395 F50
                            w
                              deckingman @droftarts
                              @droftarts said in RepRapFirmware 3.0RC1 released:
                                3dmntbighker @c310
                                @c310 said in RepRapFirmware 3.0RC1 released:
                                old RRF2 config
                                RRF-3
                                w
                                M308 S1 P"spi.cs1" Y"rtd-max31865" R395 F50
                                c310undefined 1 Reply Last reply Reply Quote 1
                                • Edgars Batnaundefined
                                  Edgars Batna
                                  Oh yeah, a versioning discussion!
                                  I'm waiting for final 3.0 release to finally get to merging some stuff into it. Do we have any significant non-functional (e.g. performance) improvements over 2.x? I've seen some threads discussing similar stuff, but nothing concrete in the release notes. I'm that guy running crazy PA values with many motors on high speeds so the Duet 2 CPU struggles (not complaining at the moment, just wondering).
                                  • c310undefined
                                    c310 @3dmntbighker
                                    @3dmntbighker WoW! thanks!!!
                                      3dmntbighker @c310
                                      I had to "guess" the same thing 2 days ago because they didn't include those port names under Maestro? I presumed the names would be the same as on Duet WiFi (which I also have with a PT100).
                                      • c310undefined
                                        c310
                                        another temperature / pin question:
                                        in RRF3 which ID should i assign to CPU temp sensor?
                                        in RRF2 it was
                                        M106 P1 L30 T44:63 H100:101 C"System"
                                        1riundefined 1 Reply Last reply Reply Quote 0
                                        • 1riundefined
                                          1ri @c310
                                          @c310
                                          i use this commands to declare the "virtual" sensors
                                          M308 S20 Y"mcu-temp" A"CPU" ; Defineix sensor S20 com a temperatura de la CPU
                                          M308 S21 Y"drivers" A"Duet_drv" ; Defineix sensor S21 com a temperatura dels drivers de la duet
                                          M308 S22 Y"drivers-duex" A"Duex_drv" ; Defineix sensor S22 com a temperatura dels drivers de la duex5
                                          In this case, sensors 20 to 22 to declare mcu & drivers.
                                          After that, use it as a standard sensor.
                                          Hope it helps you. I'm runing 3.0RC1 on a DuetWifi + Duex5 and there is no issue at all. A little tricky to configure but not impossible, using Reprap config tool as a start point.
                                            In the Upgrade Notes for RRF 3.0RC1 I forgot to mention that on Duet 3, there is no longer a default bed heater configured. Use M140 to configure one, for example M140 H0 will usee Heater 0 as the bed heater.
