    PanelDue firmware 1.16 released
    Firmware installation
    2.4k
      See https://github.com/dc42/PanelDueFirmware/releases/tag/v1.16 for release notes and binaries.
      • baballuciundefined
        baballuci
        Thanks
        • Russ Griesundefined
          Russ Gries
          rock on!
          where should we post request for new features for the PanelDue? this thread?
          Thank you David! will update shortly!!
          ~Russ
          One Day At A Time…
          My Main Research Page:
          http://rwgresearch.com/open-projects/3d-printing-research/
            Russ Gries
            oh also, we still can not update this through the duet correct?
            ~Russ
            One Day At A Time…
              Russ Gries
              ok, i got it updated using Win 10.
              using Command line bossac found here: https://github.com/dc42/RepRapFirmware/tree/dev/Tools/Windows
              win 10… oh boy...
              any how, i havent updated sence V 1.13 i think it was, and the colors i have on my screen from 1.13 to the last 1.16...
              well the colors are total wack IMO. they look " puke'e"
              is this normal?
              here is the one from your site, it looks SO much better?
              Thanks!
              ~Russ
              One Day At A Time…
                Looks like you've loaded 5" firmware when you have a 7" screen, or vice versa.
                  Russ Gries
                  the file i uploaded was labeled : "PanelDue-7.0-1.16.bin"
                  Ill try it again Monday. this is a 7"
                  any other ideas let me know…
                  Thanks David
                  ~Russ
                  One Day At A Time…
                  • stripsundefined
                    strips
                    Awesome! Will flash this just because the Emergency button 🙂
                    Ender 5 Plus, E3D Bigbox Dual
                      Russ Gries
                      ok, all is fine now that i put the 5" LCD firmware on the 5" LCD…
                      haha i must have lost my marbles...
                      all is well,
                      ~Russ
                      One Day At A Time…
                      • stripsundefined
                        strips
                        So far so good 🙂 I only wish the emergency button would be visible on the "Move head" screen as well.
                          Russ Gries
                          While i was doing a bed level i tried to hit the STOP on the Panel Due.
                          it did not respond.
                          can some one else check this?
                          it should stop correct?
                          Thanks!
                          ~Russ
                          One Day At A Time…
                            Which firmware are you running on the Duet? You need version 1.18 to get a fast response from the emergency stop button on PaneDue.
                            A true emergency stop button is an electrical switch that disconnects the power to the printer.
                              Russ Gries
                              1.18.1 duet WIFI
                              I hit it over and over to try to get it to respond but it never did. ( press and held it)
                              just wanted to point this out.
                              it responded right away on the web interface..
                              I decided to run some G code and try it. (octagon-test-delta.gcode)
                              it responded right away also.
                              but when doing a mesh grid ruteine it works fine. everything stops.
                              its only when I'm running a bed level ruteine.
                              ok, now I'm confused… now after Manny restarts its working fine now.
                              wonder if anyone else has come across this??
                              ~Russ
                              100% agreed!
                              One Day At A Time…
                              • jnolan72undefined
                                jnolan72
                                I have not updated to 116 Yet but I am on 115C
                                I do not know if this feature is already in the PanelDue.
                                But I would like for the PanelDue to read the Default Heater Temperatures and Default Bed and Chamber Temperatures setting.
                                That I configed through the Duet Wifi web site,
                                Do I can choose them for the Bed and hot-end temp
                                Thanks
                                  Do you mean the settings that you have set the heaters to? Or do you mean the selections available on the drop down list?
                                  I use macros to set the bed and hot end temperatures for the filaments that I commonly use.
